Lenovo g50-80 charging led flashing but laptop not switching on
  • B2L_Repairs
    • Oct 2023
    • 18
    • South Africa
    I got a lenovo g50-80 that shows charging led (orange LED flashing) and when I press the power button the white LED comes on but the laptop doesn't switch on. The fan spins for 2 seconds when I press the power button then it stops. This problem started when my charging dock broke the connecting wires and i soldered these wires back but I might have mixed them. I ended up buying a new charging dock but laptop never switched on it just shows flashing orange LED when charger is connected. Could the super io be bad? I don't know how to go about diagnosing and I can't check any board view since this was my personal laptop that I was using. Please assist with where I should check (if soldering is need then don't worry about microsoldering I can solder and remove chips perfectly)
  • mon2
    • Dec 2019
    • 14747
    Connect the power adapter. Carefully measure the voltage to ground of each mosfet pin at pq301.
    Source
    Gate
    Drain
    This is the first dcin mosfet for the charger ic at PU301.
    • B2L_Repairs
      • Oct 2023
      • 18
      • South Africa
      Source
      Gate
      Drain
      At source i am getting 20v, gate i am get 5v and drain 20v
      • mon2
        • Dec 2019
        • 14747
        This is a p-channel mosfet so this is ok. The mosfet is enabled. Next test PQ302. Same measurements.
        Then remove all power, measure the resistance to ground of the main power rail (at ACN) of PU301. No power in resistance mode checks.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          You mean dc jack wires broke? Right?
          If so, there is a high probability od SIO goinf bad(AD_ID touched with main power rail).
          • B2L_Repairs
            • Oct 2023
            • 18
            • South Africa
            PQ 302 is also showing 20v on source, 5v gate and 20v drain. Which pins on PU301 must I measure for resistance (it got 12pins).
            • B2L_Repairs
              • Oct 2023
              • 18
              • South Africa
              Yes DC jack wires broke. How can I see if super io is bad or where can I measure to be sure it's the super io
              • B2L_Repairs
                • Oct 2023
                • 18
                • South Africa
                Which pins of the super ion must I check to verify of its really the issue
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  AD_ID
                  Usually, if the dc jack pin of 19V touches the central pin of dc jack(AD_ID)-sio definitely goes bad.
                  AD_ID pin from dc Jack goes to SIO and in turn it understands the rating of adapter being used.
                  So very very likely you need to Replace the SIO.
                  This SIO needs programming.
