Latitude 5420 Battery issue after repair
  • Logix_UK
    • Jan 2021
    • 22
    Hi , I had an issues with a 5420 Latitude, it would not boot and I tracked it down to the pmic which I changed and now the device boots. Now the battery is not detected, I get 1 white and 4 amber flashes when battery connected. I tried two batteries, one was new, and the issue persists. Can anyone point me in the right direction please ?
  • FriedFred
    • May 2024
    • 140
    Can have a reason that the communication does not work. Or that the battery voltage is not detected by the controller. I would check the communication and the voltage at the controller.
    • Logix_UK
      • Jan 2021
      • 22
      Hi FriedFred, I have looked at this but I have no comparison and it seems that this is a schematic that is hard to come by. I have ordered a new isl and will test with a new component.
      • mon2
        • 14660
        Measure the voltage to ground of each pin on the battery connector. Post the measurements.
        • mkdj
          by mkdj
          Mark and model: ASUS X571
          Tests already made:
          - I have removed...
          07-14-2025, 09:16 AM
        • code share
          Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
          by code share
          I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
          Here's what I've tried so far:
          • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
          • Booted successfully on AC power only with the battery disconnected
          • Visual inspection of the battery — no swelling, burn marks, or connector damage
          • Battery
          04-21-2025, 12:50 PM
        • huzo
          HP ELITE X2 1013 G3 weird battery issue
          by huzo
          Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
          01-31-2025, 12:09 AM
        • Simone Vergani
          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
          by Simone Vergani
          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
          To assist with troubleshooting, I'm attaching two power circuit schematics:
          • Power
          03-05-2025, 02:25 PM
        • ahmarzo
          Acer laptop battery draining issue
          by ahmarzo
          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
          08-02-2025, 06:39 AM
