Thinkbook 15 G2 ITL no ALW voltages after replace burned USB-C contoller
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    Hello.
    Have this Thinkbook 15 G2 ITL that have burned USB-C controller U24. After replace i have main VIN voltage, but no ALW voltage. PU301 have VIN but no LDO and other voltages. i relace ic but still the same.
    ic is SY8386. LDO should be working right after vin ?
    board code is LA-K052P
    any hint?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Logically yes but as long as there is no shorted/leaky component on LDO rail.
    What is the resistance to GND on LDO pin?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3622
      • slovakia
      no shorts on LDO or other rails
      • mon2
        • Dec 2019
        • 14631
        What is the exact resistance measurement to ground?
        Remove all power. Meter in DIODE mode. Red meter probe to ground. Black meter to the LDO rail that is without power. What is the exact measurement?
        • khaahk
          • Dec 2013
          • 806
          • Estonia
          From the schematics of K051 (hopefully similar) PU301 LDO output has enable pin. It gets a value from resistor voltage divider, might be worth checking out.
          • mon2
            • Dec 2019
            • 14631
            Good point khaahk
            Was this controller replaced with 100% of the same type? The suffix of the part # are important.
            Review the voltage to ground of EN2 pin # 8 = enable for the LDO rail.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3622
              • slovakia
              Originally posted by mon2
              Good point khaahk
              no signal to EN1 or EN2
              • mon2
                • Dec 2019
                • 14631
                Review the resistors that build up the enable line trigger for this LDO.
                Do you have the main voltage rail arriving at resistor @ PR508?
                  Lenovo ThinkBook ThinkBook 14s Yoga ITL Notebook Specification for Upgrade or Repair
                  This specification for the Lenovo ThinkBook ThinkBook 14s Yoga ITL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkBook 14s Yoga ITL boardview and ThinkBook 14s Yoga ITL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-07-2024, 04:10 AM
                • Capacitorial
                  Powersupply has all the voltages - Monitor still no power
                  by Capacitorial
                  Hello guys,
                  I have a Philips 240B7QPJEB. The monitor seems completely dead.
                  I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                  On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                  The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                  The weird thing is, that the Power LED is powered over the TCON board.
                  On The TCON...
                  12-28-2024, 02:12 PM
                  Lenovo ThinkBook 13s-IML Ci5 16/512 13.3IN W10P Notebook Specification for Upgrade or Repair
                  This specification for the Lenovo ThinkBook 13s-IML Ci5 16/512 13.3IN W10P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkBook 13s-IML Ci5 16/512 13.3IN W10P boardview and ThinkBook 13s-IML Ci5 16/512 13.3IN W10P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-06-2024, 02:24 PM
                • mikey5791
                  Need help to replace burned resistor in 350w atx psu
                  by mikey5791
                  Hi to all forum members,
                  Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                  The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                  Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                  Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                  12-26-2024, 04:55 AM
