Asus Vivobook - help identifying component
  • magneh
    • Apr 2014
    • 616
    • Portugal
    Hey guys
    Got an asus Vivobook 17X model K3704V with no power.
    Found a shorted line, got the shorted component near the battery connector area, but im unable to identify it to be able to replace.
    Its a 6 leg chip marking "5345 TEGW"
    No boardview or schematics available, board model X1505VA R 2.0
    Can someone assist ?
    Photo attached Click image for larger version
  • R_J
    • 9607
    It could be ESD5345E​
    • magneh
      • Apr 2014
      • 616
      • Portugal
      Thanks R_J!
      Could be it, indeed.
      Why is it so hard to source? Ive not seen anything on Ebay or Ali with tha reference...
      Only Alibaba...
      Not sure how I will get one of these , but I will check
      • mon2
        • Dec 2019
        • 14667
        This is a jellybean part and can be crossed to many other vendors. From where do you like to shop?
        Are you ok with Digikey / Mouser / Arrow electronics?
        One equivalent of many:
        https://www.mouser.ca/ProductDetail/...NIkCeKfg%3D%3D
        • FriedFred
          • May 2024
          • 140
          Hi, the board can work without this part. Do you have still the short?
          In order of a good repair practise, you should replace it. There are several vendors of this ESD protection device, all are compatible.
          • khaahk
            • Dec 2013
            • 812
            • Estonia
            From the picture i would say that the resistors to the right of the chip location are also toasted. The battery will not charge most likely. And there may be further damage which is not visual, the ec or charge controller.
            • magneh
              • Apr 2014
              • 616
              • Portugal
              Yes, Ive managed to turn on the board after removing the shorted chip.
              Then I noticed the EC chip also toasted with 2 shorted lines
              Waiting for the SIO to arrive
              • magneh
                • Apr 2014
                • 616
                • Portugal
                Yes I will check those resistors also.
                EC was indeed toasted. Waiting for replacement
                • magneh
                  • Apr 2014
                  • 616
                  • Portugal
                  Perfect, danke for the info.
                  I will try to source one of these from another board or something after I replace the SIO and check if the board is alive again.
                  • noname2024
                    • Aug 2024
                    • 294
                    • CỎ MỸ XỊN
                    Originally posted by magneh
                    Hey guys
                    try Click image for larger version
                    • FriedFred
                      • May 2024
                      • 140
                      It looks like a transient voltage suppressor diode array. Yes, I'm right - in your boardview you can see "TVS". :-)
                      Anyway, the board shall work also without this IC.
                      Which line is the shorted line? Please be more specific.
                      • magneh
                        • Apr 2014
                        • 616
                        • Portugal
                        Hello noname2024
                        Can you tell me the value of the 2 resistors betwwen the battery connector and the TVS chip ?
                        After replacing SIO and Charge IC laptop works but does not see the battery % nor it charges.
                        But it holds with the battery if I remove dcin.
                        So I think its data/communication issue, could be those 2 resistor.
                        They measure 0ohm both on the board.
                        Thanks if you can help!
                        • mon2
                          • Dec 2019
                          • 14667
                          The SMBUS line labels show 50 ohms. These will be any low resistance resistors that are used to current limit the lines in case of a short circuit. You can place 10R-100R without issues. We use 33R for a lot of our product designs for the same task.
                          • noname2024
                            • Aug 2024
                            • 294
                            • CỎ MỸ XỊN
                            Hello noname2024
                            yes 0hm Click image for larger version
                            • magneh
                              • Apr 2014
                              • 616
                              • Portugal
                              Yes I installed 50 ohm resistors , new SIO and new Charge ic.
                              Same result
                              Machine turns on with orange light, but when it posts it goes blinking white light in the battery LED.
                              It detects DC mode as when I remove the charger, laptop stays on, but shows 0% battery level and of course does not charge it.
                              Could this be firmware related?
                              Seems weird as all blown/defective components have been replaced.
                              Bit frustrating...
                              • magneh
                                • Apr 2014
                                • 616
                                • Portugal
                                Thank you noname2024
                                So they are good... not sure what else to do here... still same problem does not see the battery level or charges battery.
                                But machine stays on when I remove DC charger... so frustrating
                                Maybe firmware related, im running out of ideas....
                                • mon2
                                  • Dec 2019
                                  • 14667
                                  Measure the voltage to ground on each of these smbus lines. Post the measurements.
                                  • magneh
                                    • Apr 2014
                                    • 616
                                    • Portugal
                                    Hey mon2
                                    SMB0_CLK 0.133 (98 ohm)
                                    SMB0_DATA 0.082 (60 ohm)
                                    • mon2
                                      • Dec 2019
                                      • 14667
                                      Are these the voltages to ground using DC volts scale? The voltage and resistance is very low. Something is wrong here.
                                      Confirm it. Moving forward, highlight the same SMBUS lines and you should find a local ESD protection device. Often they are used to shunt transient events to prevent damage. Suggest to flux and remove the ESD transient protection device (usually will be a 3 pin part in a SOT-23 package or SC-70 package). Then test the resistance and voltage to ground again after this part is removed off the board.
                                      • magneh
                                        • Apr 2014
                                        • 616
                                        • Portugal
                                        Hi mon2
                                        Thanks for the inputs. Yes, voltage to ground diode mode, and resitance in Ohms.
                                        I removed a 6 leg ESD IC, the one you can see on the picture above, that I asked help to identify here at this post.
                                        Values remain the same.
                                        Ive tried also 2 charge IC's and 2 ITE controllers, same values.... dont see where the problem is , and whitout a schematic or boardview , cant think on anything else...
                                        These values are 100% bad and too low for SMBUS lines ? cant be any thing firmware related?
                                          ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-07-2024, 02:50 AM
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          ASUS VivoBook VivoBook 14 Notebook 14 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook VivoBook 14 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VivoBook 14 boardview and VivoBook 14 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 04:10 AM
                                          ASUS VivoBook S431FA-EB039T Notebook S14 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook S431FA-EB039T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S431FA-EB039T boardview and S431FA-EB039T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 10:56 AM
                                          ASUS VivoBook S531FL-EJ154T Notebook S15 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook S531FL-EJ154T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S531FL-EJ154T boardview and S531FL-EJ154T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
