LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
  • NConstantinou
    • May 2017
    • 335
    • Cyprus
    Dear all,
    i have the above laptop which had a problem with battery. i replaced it with a compatible one..
    the laptop DOES NOT POWER ON..
    with it old battery it does power on.
    i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
    when i shutdown the laptop does not power on.
    does anyone have any solution!
    when is not power on the usb c voltage tester shows 5v 1.3A
    when i disconnect battery and power on and then connect battery the tester usb shows 19v as input
    thanks
  • mon2
    • Dec 2019
    • 14271
    Remove all power. Meter in resistance mode.
    Measure the resistance across the mosfet pins to test if they are leaking.
    Review the mosfet @ PQ304:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Post each measurement.
    • NConstantinou
      • May 2017
      • 335
      • Cyprus
      SOURCE TO DRAIN 21M AND DICREASING
      SOURCE TO GATE 208K
      GATE TO DRAIN 20M
      MULTIMETER IS NOT STABLE IN ALL READINGS IT FLATUATES
      • mon2
        • Dec 2019
        • 14271
        These are low measurements for source/drain and source/gate.
        Flux and remove this part. Allow it to cool. Then measure this part again to see if the readings are still this low. Suggest to replace this part and test again.
        • NConstantinou
          • May 2017
          • 335
          • Cyprus
          ok i will do that but what should be the readings
          • mon2
            • Dec 2019
            • 14271
            Each measurement should be hundreds of k ohms or higher on a good part.
              • 21058
              Tried another replacement battery ?
              • NConstantinou
                • May 2017
                • 335
                • Cyprus
                CAN I SUBSTITUTE AON7380 WITH AON7516!
                TO ORDER AON 7380 WILL TAKE AT LEAST 2 WEEKS TO ARRIVE.
                THANKS
                • mon2
                  • Dec 2019
                  • 14271
                  Yes.
                  • NConstantinou
                    • May 2017
                    • 335
                    • Cyprus
                    still the same problem
                    voltage is flutuating.
                    could that be the charger ic!
                    • mon2
                      • Dec 2019
                      • 14271
                      Remove all power. Test each mosfet that is driven by this charger IC. You are hunting for other defective parts in this region.
                      See the sticky above by piernov on charger circuits.
                      • NConstantinou
                        • May 2017
                        • 335
                        • Cyprus
                        is it possible the charger ic maybe defective!
                        After studying BQ25710 i connected only battery on motherboard and i notice that the problem is on EC_SMB_CK1 and EC_EMB_DA1.
                        those 2 pins are connected to RPE3 pins 1 & 1 3v is fluctuating BUT pins 3&4 i get stable 3.3v.
                        Those EC_SMB_CK1 & EC_SMB_DA1 are the outputs of BQ25710 charger ic​
                        • mon2
                          • Dec 2019
                          • 14271
                          The BQ charger IC is the slave node on the I2C / SMBUS network. The I2C / SMBUS master is the EC and the EC is the one that drives the clock line. One side of the required pull-up resistors must be at 3v3 or similar (varies with the logic levels needed by the slave nodes) but the other side or the active side will be toggling high and low so your meter is observing as fluctuations.
                          If of concern, test if these lines are being shorted. Remove all power. Meter in resistance mode. Measure the resistance to ground of the CK1 and DA1 lines. If the resistance is low then yes, someone is defective and it could be the ESD TVS diodes. We have this event on a few cases and took longer than it should have to locate the tiny buggers that demand nice tweezers to pluck off the board. Made the macbook look dead to the world and multiple local shops gave up on it. The same defective TVS diode was shunting this line and causing the main buck / boost regulator from creating the required PPBUS_G3H rail. Your case may be similar.
                          • NConstantinou
                            • May 2017
                            • 335
                            • Cyprus
                            Thanks MON2
                            it seems that my multimeter was defective and i notice it too late after spending a lot of time to realize it.
                            getting a new multimeter the resistance is as follow
                            PQ 305 D to S 2.4M, S to G 1.5M, D to G 8M
                            PQ 303 D to S 1.7M, S to G 0.2M, D to G 1.9M
                            PQ 304 D to S 9M, S to G 2M, D to G 7M
                            when i was testing PQ305 D to S the multimeter reading was increasing more rapidly than the other readings if that is telling you something.
                            PQ305 is 5W3502 and is before PR302.
                            the EC_SMS da&cl are not short. their resistance is about 30k
                            • mon2
                              • Dec 2019
                              • 14271
                              This mosfet is a suspect. The S/G measurement is a bit on the low side. Consider to flux and remove this part and confirm if the measurements remain the same. This part may be defective.
                              • NConstantinou
                                • May 2017
                                • 335
                                • Cyprus
                                I REPLACED AON7408L WITH 7408 BUT STILL GET 0.2M RESISTANCE.
                                GROUND TO GATE IS THE SAME RESISTANCE
                                • NConstantinou
                                  • May 2017
                                  • 335
                                  • Cyprus
                                  According to the diagram there is a capacitor PC331 100p_50v that is connected to the gate of PQ303.
                                  On board there is no such a capacitor. i found one and i solder it but resistance still low onPQ303 S to G at 0.2M with the capacitor install
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Have you tried another battery?
                                    Too me nothing seems wrong here and perhaps the unit may be damaged by un-necessary steps at this stage.
                                    The compatible battery is simply not compatible with this unit.
                                    Post the original battery+new battery PICS
                                    • NConstantinou
                                      • May 2017
                                      • 335
                                      • Cyprus
                                      No i do not have that type but this battery works on another Lenovo.
                                      i am sending you pictures of original and compatible
                                        • 21058
                                        To save anyone else having to download,extract,rotate pictures and zoom in to see the part numbers i`ll post the pictures and part numbers
                                        Both battery models: L19M4PDC
                                        • ferah831208
                                          Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                          by ferah831208
                                          Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                          03-18-2025, 01:18 AM
                                        • Grafnus
                                          Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
                                          by Grafnus
                                          Hey there,
                                          first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
                                          So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
                                          Specs:
                                          • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
                                          • CPU, GPU, RAM work fine (not involved in the Problem)
                                          So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
                                          Now I noticed...
                                          08-06-2025, 11:54 AM
                                        • emeskay
                                          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                          by emeskay
                                          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                          08-06-2024, 07:13 AM
                                          Lenovo ThinkPad X1 Yoga Gen 7 Notebook Yoga Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Yoga Gen 7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga Gen 7 boardview and X1 Yoga Gen 7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 05:20 AM
                                          Lenovo ThinkPad L13 Yoga Gen 2 (Intel) Notebook Yoga Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad L13 Yoga Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L13 Yoga Gen 2 (Intel) boardview and L13 Yoga Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
