HP hp 15-cs3112tx with power light no boot
  • jheunne
    • Sep 2022
    • 62
    • philippines
    hi i have this hp laptop board id DAG7BLMB8D0 REV : D , G7BL (2G) it has power light but won't boot and no fan spin i found ic busted near headset jack it has hole in center. according to data sheet of ic its a power ic na audio ic i tried to replace still come with no boot. can you help me this one and also if someone has its boardview for share thanks and more power. here i upload the ic which has hole on it.
    Click image for larger version  Name:	2024_11_25_13_02_IMG_0666.png Views:	45 Size:	3.34 MB ID:	3525049
  • mon2
    • 14520
    This is not a power ic but an audio codec. Post pics of the replacement part and board for a review.
    Have you reviewed the adapter to charger ic power path?
      Laptop computer that went completely dead no boot no power light no hard drive light
      See pictures for type of laptop computer
      I checked switching power supply brick 19.2 volts multi meter only
      No booting without switching power supply connected
      Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
      What the heck is going on here...
      04-04-2025, 04:58 AM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • dicky96
      Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
      by dicky96
      Hi guys
      I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
      If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
      If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
      03-24-2023, 06:33 AM
    • ipatch
      troubleshooting microsoft surface pro 4 no power no led charge light
      by ipatch
      hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
      10-05-2023, 11:59 AM
    • russpall
      LG 39ln540v - red light flashes twice, no power to LED driver?
      by russpall
      Hi there,
      I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
      The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
      08-27-2024, 01:07 PM
