HP DV5 1000us checksum error and keyboard locked
  • barbas
    • May 2010
    • 20
    Hi fam. Got a HP DV 5 1000us with a weird symptom.
    Gives checksum error at boot but locks the keyboard. Says to press F1 to load defaults but won't take input. Tested keyboard pins with scope and ESC, F1, F10, etc work fine.
    Displays the 1st screen (HP logo just fine). Then the bad checksum message appears, with lines on screen, tho). Tried to recover BIOS with win+F. No good. New battery didn't help. Tried 2 spare key boards.
    Anybody experienced the same thing?
    I was thinking the lines may be related to something else?
  • barbas
    • May 2010
    • 20
    Here's the message. Keyboard still locked.
    • Syseng
      Lenovo P14s Gen 5 SVP unlock
      by Syseng
      This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
      The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
      06-22-2025, 07:44 AM
    • ugamazing
      820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
      by ugamazing
      So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
      1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
      2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
      04-10-2024, 08:06 AM
    • unick
      Laptop HP 850 G2 Keyboard error after Windows 11 update
      by unick
      Hello
      i have following problems on HP 850 G2 laptop and 840 G2 laptop. After win11 update 24H2 the keyboard and touchpad stop working. I delete the keyboard from device manager and restart : work. If i shut down the laptop and restart after 5 min the problem apear again: no keyboard and no touchpad active. I have used also hp driver from oficial sit but no luck. I have modified with regedit " i8042prt Start REG_DWORD with 1, but no suscces. Any ideea?
      09-15-2025, 07:47 AM
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • sushilachuthan
      APC UPS error P13
      by sushilachuthan
      one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
      the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
      The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
      We replaced the SCR with new device,, but the device is not power on as expected.
      Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
      09-26-2025, 09:00 AM
