a1990 no image
  • Arshad alam4659
    • Aug 2020
    • 156
    • India
    a1990 no image
    I HAVE A1990 BOARD 820-01814 THIS BOARD WAS NAND IC SHORT I CHANGED NAND IC NOW BOARD IS POWER ON BUT NO DISPLAY SOUND IS COMING AND CAPSLOCK IS BLINK WHEN PRESS I CHECKED WITH EXTERNAL MONITOR BUT SAME DISPLAY IS NOT COMING
    IT GOES 1.3MA THEN COME 600 TO 700 MA I CHECKED NAND COIL VOLTAGE ARE OK SOMEONE HELP
  • Arshad alam4659
    • Aug 2020
    • 156
    • India
    anybody help what should i check
    • mon2
      • 14340
      Review the multiplexer IC @ U9850. This is a critical component that routes the display data to either the outside or the internal LCD display assembly.
      • reformatt
        • Feb 2020
        • 1418
        https://logi.wiki/index.php/MacBook_NAND_List
        You can't just swap out a NAND on a T2 machine. Has to be of the same configuration and location from a donor, or re-programmed by the JC P13/P15 programmer. Additionally all of the NAND's are striped as RAID 0 by the T2 and encrypted. As the SSD also contains the T2 BridgeOS, you need to perform a DFU restore to fix all of that.
        If the NAND firmware you installed doesn't match the rest of the config, or in the right location, a DFU will fail. Others have also stated that all NAND's should be replaced after a TPS failure, don't try to re-use any of them.
        • Arshad alam4659
          • Aug 2020
          • 156
          • India
          i changed nand controller ic not nand only nand ic was shorted
          • Arshad alam4659
            • Aug 2020
            • 156
            • India
            i checked j8500 only pin 1 and 3
            diode mode
            pin 1 =460
            pin 3 =462
            and i also changed u9850 with new one but same condition
            • mon2
              • 14340
              External display also fails?
              Remove all power. Meter in diode mode. Red meter lead to ground. Black meter lead to point to test.
              Test each pin on this mux. Low measurements may be due to a short. No power during diode mode testing.
              • tranquility
                Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                by tranquility
                i want to repair an Onkyo TX-NR809 receiver.
                symptoms:
                on power on, display appears and i hear one click. enue functions is given.
                - no hdmi output
                - audio output not tested, but i think it is not there
                - usb sticks are not recognized
                if i read out the chips with display+standby button + tone+
                both dts show only ????
                chip is D830K013BZKB4
                things i have done:
                - reflow of the dts chip without taking off and reballing
                - changed the aluminium caps without the big one with 25v because i dont...
                Yesterday, 01:04 AM
                HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                09-12-2024, 02:20 PM
              • sajidmirza
                A1990 cant install OS after SSD nand repalced
                by sajidmirza
                Got A1990 with ssd nand ic shorted.Repalced all the nand ic from same donor board.Restored in apple configurator successfuly and booted to recovery.Its high siera recovery.But when i try to insatll OS from internet recovery it gives error "Recovery server could not be contacted".tried at different places thinking of low internet but still getting same error.Tried date adjustment from terminal also.
                i have heard that we cant install OS from high siera recovery at the moment.Is it true.If yes how to update recovery to latest one.tried to restore several times from...
                07-06-2023, 07:53 AM
              • Jaime Morillo
                Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                by Jaime Morillo
                Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                The TV was stuck on the logo and I couldn't access the update menu.
                I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                The image result was good, but the image is inverted.
                The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                08-18-2025, 11:38 AM
                HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                09-06-2024, 10:56 AM
