MSI DELTA 15 NO POWER
  • Kevin555
    • Sep 2023
    • 13
    • France
    Hello I have a problem with an MSI DELTA 15 which does not want to turn on according to the customer he was on the internet and the PC suddenly shut down while it was on battery he then tried to charge but nothing apart from the white charging LED which lights up, after disassembling I tested different voltage and I encounter a problem with the 3v 5v chip which does not receive its activation signal of 3.3volt I do not I have no diagrams or Boardview at my disposal but in my opinion this signal should be sent by the EC chip (ENEKB9028GC) on my thermal camera I only have 2 heating points the 3v 5v chip and the EC chip do you have an idea of the problem and where should I look?
    ( https://ibb.co/album/jZZsFN )
  • mon2
    • Dec 2019
    • 14261
    Which charger IC is onboard?
    Review the charger sticky above by piernov
    Using the official and recommended power adapter?
    • Kevin555
      • Sep 2023
      • 13
      • France
      Thank you for your response
      The charging chip has the reference (BQ24780S) and yes I use the original power bank here are the photos of the chip and the power bank.
      • mon2
        • Dec 2019
        • 14261
        Perfect. See attached for the TOP side view of this charger IC.
        Remove all power. Disconnect the battery. Meter in resistance mode.
        Measure the resistance to ground of the ACP and ACN pins on this charger IC. One meter probe onto pin #1 or # 2. Other meter probe to ground. We are checking if there is a short on the main power rail that powers this logic board.
        What is the resistance to ground?
        Are your meter probes pointy to measure the pins on the charger IC? For resistance check, no issue but need to be pointy for voltage checks so the pins are not shorted.
        • Kevin555
          • Sep 2023
          • 13
          • France
          yes my probes are pointed my multimeter in diode mode and red probe to ground ACP (0.420) ACN (0.420).
          • mon2
            • Dec 2019
            • 14261
            Diode mode is different than resistance mode. But the diode mode measurements do not show this main power rail as being shorted. This is a good start.
            Now, apply the power. Meter in DC volts mode (30v or higher scale). Measure the voltage to ground on the
            ACDRV pin # 4 ; should be ~25v if all is ok and is used to enable the 2 x DCin mosfets in the power path
            ACOK pin # 5
            VCC pin # 28 ; used to power the IC
            REGN pin # 24 ; must be ~6 volts stable if all is ok
            • Kevin555
              • Sep 2023
              • 13
              • France
              all voltages are good ACOK (3.3 volt)
              • mon2
                • Dec 2019
                • 14261
                How hot are the missing 3v and 5v regulators? Often these parts are enabled using 2 resistors that are driven by the main power rail (same voltage as you will see on ACP/ACN pins). The resistors create a safe lower voltage which is fed onto the ENABLE pins of each regulator.
                What is the voltage to ground on the ACN/ACP pins? It should be the power adapter voltage since the charger IC is enabling the power path mosfets.
                If the 3v/5v are missing, then power down and measure their resistance to ground at their inductors. If a low resistance, then someone is shorted on that rail. No power during resistance checks.
                • Kevin555
                  • Sep 2023
                  • 13
                  • France
                  The temperature is around 35 degrees celsius I did not specify but I have already changed the 3v 5v chip without success, ACN and ACP I have 20v here is a diagram of the 3v 5v chip with the voltages that I should have I put a cross where I have no tension.
                  • Kevin555
                    • Sep 2023
                    • 13
                    • France
                    here is the 3v 5v chip
                    • mon2
                      • Dec 2019
                      • 14261
                      The measured temps are not considered to be hot.
                      The '2N=' marked part is
                      Richtek # RT8249CGQW
                      Full datasheet:
                      • mon2
                        • Dec 2019
                        • 14261
                        Measure the voltage to ground of:
                        EN1
                        EN2
                        LDO3
                        LDO5
                        on this IC.
                        • Kevin555
                          • Sep 2023
                          • 13
                          • France
                          EN1 : 0
                          EN2 : 0
                          LDO3 : 3,3v
                          LDO5 : 0
                          • mon2
                            • Dec 2019
                            • 14261
                            OK. LDO3 (only) on is good and follows the part markings.
                            Check the resistance to ground of LDO5 and the output rails on this regulator to be sure there are no downstream shorts.
                            You will have to trace where EN1 and EN2 are enabled. As per your first post, is it the EC or is it a resistor based enable using 2 resistors that are feeding from the main power rail?
                            Often there are 2 resistors building a voltage divider to lower the 19v to a safe enable voltage for EN1 and EN2. Hunt for these parts using diode mode and a tone beep.
                            If mating with the EC, then the EC power rails and clock must be confirmed to be ok.
                            • Kevin555
                              • Sep 2023
                              • 13
                              • France
                              Okay thank you for all the details I really appreciate your help it's late at home I'm going to rest and tomorrow I'll give you everything you need, good night sir.
                              • Kevin555
                                • Sep 2023
                                • 13
                                • France
                                Hello so I checked the 2N chip completely I didn't find any output short and I found where EN1 is connected I switched to diode mode and I have a direct connection with the pin of this IC I don't know what to it is useful I do not have its datasheet but on the second identical IC right next to it I have no direct line for EN2
                                • mon2
                                  • Dec 2019
                                  • 14261
                                  https://www.mouser.com/datasheet/2/2...HOxYWdLUoMcLNX
                                  • Kevin555
                                    • Sep 2023
                                    • 13
                                    • France
                                    I checked and this AE chip does not have its activation voltage either which passes through a 10k ohm resistor, i just have the VIN on pin 1
                                    no shorts either
                                    • mon2
                                      • Dec 2019
                                      • 14261
                                      Do not have any schematics for this board. You will have to trace the enables and hunt for faults. Test each inductor to check if the voltage is within spec. Perhaps bios is corrupted. Check spi lines for activity.
                                      • acedogblast
                                        by acedogblast
                                        11-02-2024, 05:13 PM
                                      • DynaxSC
                                        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                        by DynaxSC
                                        Hi
                                        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                        08-04-2025, 12:20 PM
                                        by sam_sam_sam
                                        03-31-2024, 02:12 PM
                                      • dragon3x
                                        >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
                                        by dragon3x
                                        Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
                                        that is still quite new, as it worked OK for some months until it failed.
                                        At the time I was not into power supply electronics; it was put
                                        aside and a new power supply installed inside the computer. Also at the time
                                        power supplies were half the price of today's.
                                        On the PCB there are a D339 and 7500B chips.
                                        I have found that schematics with these 2 chips (see included file).
                                        Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
                                        Some measurements,...
                                        06-05-2024, 03:34 PM
