Legion 5 15ACH6 lights up and stays lit
  • trepachka
    • Oct 2022
    • 414
    I have a Legion 5 15ACH6 with RTX 3050 ti graphics card (NM-D601 board). Computer charges when plugged into a charger. When power button is pushed, it lights up and stays lit forever. No other action is happening. All voltages needed to start are present: 3.3V, 5V, 1.8V, 0.75V
    The EC chip gets 3.3V on many pins, it is not shorted. However, IC chips responsible for generating 2.5V, 1.2V and VCORE are not producing the power due to no signal on the enable pin.
    I can, of course, reflash the BIOS chip but I think the EC chip is corrupted. I read somewhere where it was said if the computer is charging and the EC chip gets the right voltage, then it is not corrupted.
    Could someone, please weigh in and let me know whether I should try reflashing the bios chip or rather replace the EC chip? I think it's the latter.
  • peste
    • Dec 2016
    • 12274
    • ROMANIA
    I would rewrite the main bios because it's easier to do, and then we'll see..
    • trepachka
      • Oct 2022
      • 414
      I rewrote the bios, same result. When the power button is pressed, only the power button lights up. No power to the CPU. All start-up voltages are present. I went ahead and ordered pre-programmed EC chip from China. This will take 2 weeks.
      • trepachka
        • Oct 2022
        • 414
        I replaced the EC chip without any change. When power button is pressed, only the power button lights up. Battery gets charged, no problems. I get 5V, 3.3V, 1.8V and 0.75V. No obvious hot spots on the board
        • rogfanther
          • Jul 2006
          • 458
          • Brazil
          Is the charger you are using the original one from the machine ?
          • trepachka
            • Oct 2022
            • 414
            I am using a genuine 230w lenovo charger. Computer behaves the same way on battery power alone.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              I'm not in favour of replacing components in a random fashion without proper diagnosing it.
              Vcore will rise at the fag end of booting process.Before this 1.2V is a must. If ram doesnt get voltage,vcore wont rise.
              So you should focus on RAM IC first.
              Most important to check-Is EC releasing SUSP_N from pin 124?
              • PacoGT
                • Sep 2022
                • 72
                • Guatemala
                hello can you upload the ec file?
                and
                you resolved the problem?
                i have 2 motherboard and one whit the same issue, turn on and only lighs on the keyboard but no video display and the other pr1072 is hot and one side 5v and the other 3.3v and no power on
                • trepachka
                  • Oct 2022
                  • 414
                  Unfortunately, no. It was a no fix.
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
                  • joesmoe91
                    Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
                    by joesmoe91
                    My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
                    02-22-2024, 07:38 PM
                    by SMDFlea
                    Bad...
                    09-02-2021, 04:40 PM
                  • Mirenia
                    Lenovo Legion 5 15IAH7 - location of BIOS chip
                    by Mirenia
                    I've got a Lenovo Legion 5 15IAH7 with no post/no boot issue.
                    The mainboard is a NM-E241 Rev 1.0
                    Now I am searching for the BIOS chip so I can reflash it.
                    But I have some difficulties to identify the correct chip. The schemantics somehow are not really helpful for me (I am a beginner with Laptop schemantics)
                    I found 3 Winson chips and one GigaDevice chip as you can see on the screenshots.
                    My guess its the W25Q128JVSIN (UB3) because it is the biggest from all.
                    I attached the pages of the schemantics from the...
                    05-31-2024, 01:31 PM
                  • geotox
                    Lenovo Legion Y540-17IRH 81Q4 dead IT8226E-192 chip
                    by geotox
                    Hi, after a short circuit during power cord plug-in the IT8226E-192 chip on my Lenovo Legion Y540-17IRH 81Q4 died. I'm trying to order a replacement for it. There are some similar chips available online, but they are not 1-to-1 identical to my chip. For example, I see there's a 1921BXA chip available for sale, while mine is 1932BXA. Do you guys know if there's any compatibility table available which I can use to see what chips are compatible? Should I just order a similar chip and try it? Will I need to program the chip before installing, or will the laptop do it for me?
                    Thanks...
                    08-02-2023, 09:57 AM
