Macbook A2485 ( Main 820-02100-A) no power
  • robgerr
    • Apr 2012
    • 70
    • Italy
    Good morning.
    This MacBook came to me with the defect that it doesn't turn on, even the green or orange LED doesn't turn on from its power supply with magsafe connection. While disassembling the motherboard I noticed the following problems:
    UG400 with a hole, I desoldered it.
    I find very low resistance to ground on the LG801 coil. I unsolder UG800 and the short disappears. With these two components desoldered, I connect the magsafe and the light turns on orange but still doesn't start. I order a new Ug400 and UG800 but nothing changes, same problem. I check the components under the protective plastics and find the burnt protective plastic on the UH700. I remove the component but nothing changes yet. When connected to USB type C it negotiates 5V and absorbs 0.02A. If instead I connect to the right side USB port there is 5 V but 0 absorption.
    what can I check?​
  • rcanpolat
    M1 MacBook Pro 2021 A2485 - No backlight display
    by rcanpolat
    I recently got my hands on an M1 MacBook Pro (2021, A2485) that I suspect suffered some liquid damage. I have a hot air station and the basic tools to work on the board, but I’m new to SMD repair and would love some guidance before diving in.
    Here’s what I’ve observed so far:
    • When I power it on, I hear the MacBook chime and, with a flashlight, I can see the Apple logo on the screen. However, it never completes the boot and eventually powers off. My plan is to try to get the display fully working first, then tackle the boot issue.
    • I did some basic resistor
    08-24-2025, 02:16 PM
  • spwoof
    Seeking LCD Schematic for MacBook Pro M1 A2485 - Aiming to Repair, Not Replace
    by spwoof
    I'm currently working on a MacBook Pro A2485 and have encountered an issue with the LCD. Instead of opting for a full replacement, I'm interested in performing an in-depth repair on the LCD itself. I'm hoping to find the schematic for the LCD in order to understand its architecture and troubleshoot more effectively.
    If anyone has access to the schematic or can point me in the right direction, I'd really appreciate it. My goal is to repair the components and connections within the display, rather than going for a costly replacement. I've been in the notebook...
    10-05-2024, 08:02 AM
  • spwoof
    by spwoof
    10-05-2024, 07:24 AM
  • Loki_Fido
    Requesting help identifying chip in Macbook Pro A2485
    by Loki_Fido
    Hi ya folks,
    I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
    It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
    I replaced it and the SSD are fine. No more shorts.
    But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
    But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
    Chip marking...
    08-07-2025, 10:17 PM
  • PITERPENY
    Macbook Pro A2485 820-02100 SSD
    by PITERPENY
    Hello. SSD UN0000/0100/0200/0300 were shorted in the MacBook. There are 4 SSD chips on the board. I don’t have the same board and I removed two SSD UN0000/0100 chips from the MacBook on the M1 A2338. I installed only these two, but the machine does not recover and gives error 28. I have a question: is it necessary to have all 4 or should it work with two chips? Is this important for the M1 Max processor?...
    05-11-2025, 06:30 AM
