macbook a1707 820-00928
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    the board is not filled! 3 ports consume 5v/0.265a and overload! one port 20v/0.120a and reboot and so constantly overload! no short circuits! replacing the U7000 did not help! replacing the BIOS also did not change anything! tell me what else can be checked! so far my suspicions are on the U1100
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    PPBUS_G3H=1.7V
    PP1V1_UPC =0 all cd3215
    • mon2
      • 14660
      Remove all power. Flux and remove the fuse on PPBUS_G3H. Meter in resistance mode. Measure the resistance to ground of the 2 pcb pads where the removed fuse was soldered. Post the measurements.
      • piernov
        • Jan 2016
        • 4439
        • France
        Of course the USB-C controller for the port that acts differently is gonna be bad.
        • PITERPENY
          • Jul 2023
          • 461
          • Ukraine
          I thought so too and replaced all four CDs but the behavior remained the same! The problem is not in the CD!
          • PITERPENY
            • Jul 2023
            • 461
            • Ukraine
            with f7000 PPBUS_G3H=6.9 kOhm (diode 0.400)!
            with f7000 removed: PPBUS_G3H=6.9 kOhm (diode 0.390)
            PPVBAT_G3H_CHGR_REG=13.2 kOhm (diode 0.520)
            when f7000 is removed, usb ports also reboot cyclically
            • mon2
              • 14660
              Measure the resistance to ground of each of the USB port's VBUS line. Perhaps a local USB load switch is defective.
              • PITERPENY
                • Jul 2023
                • 461
                • Ukraine
                I have PPBUS_G3H=1.7 V and it should be 13 V! Who forms this voltage? VBUS = 5 V (d0.122) 0.700 kOhm
                • mon2
                  • 14660
                  U7000 = ISL9239 is the buck / boost regulator that creates PPBUS_G3H.
                  If the input voltage is 5v on VBUS, then this regulator will enter BOOST mode to booth the output to a required voltage. Whenever the voltage is boosted, the current support is for low loads.
                  After the PD controllers negotiate 20v from the power adapter then the VBUS = 20v and this U7000 regulator will enter buck mode to lower the 20v down to the required voltage.
                  If the PPBUS_G3H voltage is low, inspect this area and without power to the board, confirm the resistance of the dual mosfets @ Q7030 and also Q7040.
                  Measure the full resistance path of the VBUS input resistors by probing across C7023. Does this resistance match the schematic values? Should be ~2 ohms.
                  • PITERPENY
                    • Jul 2023
                    • 461
                    • Ukraine
                    I put the board in another case with a charged battery and all 4 USB ports show 20V/0.250A (stable). But it doesn't charge and the fans work at high speed despite the touchpad being connected! The system doesn't boot! C7023=2.7ohm
                    • mon2
                      • 14660
                      Try a DFU. Double-check your interconnect cables from the trackpad assembly.
                      Is the trackpad & trackpad cable a known good pair?
                      • PITERPENY
                        • Jul 2023
                        • 461
                        • Ukraine
                        dfu A1707 is not supported! The case with a fully working MacBook and another board works fully in this case! The problem is on the board! It does not see the battery apparently and therefore does not charge! The problem is in the power supply network, but I do not understand where! Maybe the problem is in the Thunderbolt firmware?
                        • CG_Dionysos
                          MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
                          by CG_Dionysos
                          I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
                          • Model: A1707
                          • 15-inch, Mid 2017
                          • 3.1 GHz Core i7
                          • 16 GB RAM
                          • Radeon Pro 560
                          • 1 TB SSD
                          • Board number: 820-00928-A
                          I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
                          Thanks in advance!
                          Greetings from Germany...
                          09-16-2025, 06:43 AM
                        • leonemax81
                          Macbook a1707 820-00281 Battery no Power
                          by leonemax81
                          Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                          08-23-2024, 09:24 AM
                        • sofles
                          Macbook a1707 2017 model 820-00928 GPU issue
                          by sofles
                          Hello there
                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                          11-21-2024, 05:25 AM
                        • jesi
                          MacBook Pro 820-00281-A A1707 macbook
                          by jesi
                          hi all techs
                          require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
                          adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
                          update:
                          when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
                          08-23-2025, 02:35 PM
                        • tommy97
                          Apple MacBook A1707 No Audio/Sound
                          by tommy97
                          I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                          I've also replaced U6300, but the problem persists.
                          Here are the current voltage readings:
                          • PPV18_S0: 1.8V
                          • R6402: 1V
                          • R6405: 1V
                          • R6403: 1V
                          • AUD_SPKRAMP_RESET_L: 1.3V
                          • PPBUS: 12.6V
                          03-10-2025, 11:22 AM
