Lenovo LOQ 15IRH8 DC Socket
  • Rickkap
    • Aug 2015
    • 139
    I have a LOQ 15IRH8 laptop which has suffered a damaged DC socket. I'm trying to find a replacement but after searching on eBay, AliExpress and google, i can't seems to find one and I'm hoping that someone out there has replaced this socket and is willing to share which port they used. This is very much different to the normal Lenovo ports and they don't fit. It has the marking of LOTES on it but after looking at replacement board they don't have the same marking so I'm thinking that there must be a generic one available.
    If someone could help with this i would really appreciate it.
    I've attached the original port below. Please ignore the lengths of the pins as these needed to be cut to be able to get it off the motherboard. the main 2 lugs which hold it in place are original.
ID:	3503592 Click image for larger version
ID:	3503590 Click image for larger version
ID:	3503585 Click image for larger version
ID:	3503586 Click image for larger version
ID:	3503587 Click image for larger version
ID:	3503588 Click image for larger version
ID:	3503589 Click image for larger version
  • mon2
    • 14634
    Why can't this one work?
    https://www.aliexpress.us/item/10050...Cquery_from%3A
    Know Lotes and they are a quality OEM supplier to many customers including Intel and I recall them at many assorted electronic fairs in HK. They stamp these out to custom specs for their clients but no issue if you can find a similar drop in replacement. The above looks like a good fit but best to ask the vendor for more details on the dimensions to compare against yours.
    • Rickkap
      • Aug 2015
      • 139
      I have them in stock and they don't fit. The LOQ seem to be smaller and also the lugs which hold the socket to the motherboard are not long enough, they seem to be at the bottom of the plug.
      I really need to find someone that has already replaced the port on this model to see what they used.
      • Rickkap
        • Aug 2015
        • 139
        Anybody??
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • viniciussls
          Notebook won’t turn on after screen replacement - Lenovo Legion Silm 5 16IRH8_LOQ 15IRH8 Compal ILG10 LA-M542P Rev 1.0
          by viniciussls
          Good morning everyone, this is my first post and I apologize in advance if there are any mistakes in the post.
          I have a Lenovo Legion Slim 5 16IRH8_LOQ with the typical issue of stripes on the screen, but I made the mistake of replacing the screen without physically removing the battery, thinking that just pressing the SW2 button would be enough – it wasn't. The board showed consumption, with LED6301 lit up and PU301 getting very hot. I replaced PU301. Now, the board is not working correctly, but it has no consumption, LED6301 stays on, and I haven't found any other signs of a short...
          04-02-2025, 01:40 AM
          Lenovo 3000 Series Schematic
          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
          3000 C100 laptop with Braille keyboard
          Lenovo 3000 C
          C100, C200 - 15-inch XGA screen
          Lenovo 3000 N
          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
          N500 - 15.4 inch screen.
          Lenovo 3000 V
          V100, V200 - 12.1-inch WXGA models
          Lenovo 3000 G
          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
          10-04-2024, 06:05 AM
        • Rolandas
          lenovo y50 charging socket shorted out
          by Rolandas
          Hei
          The lenovo y50 charging socket shorted out. The computer does not turn on. The inductive coil 1R5 is hot. Do you know which part can short out?
          04-08-2024, 01:38 PM
        • derradji89
          Need help Lenovo MIX 320-10lCR domaine name SERCOL
          by derradji89
          Hi everyone 🤗
          I have a Lenovo MIX 320-10lCR computer.**
          1. **Operating System**: Windows 10 ** Education** 64-bit.
          2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
          3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
          4. **BIOS Chip Reflashing**: Currently,...
          04-19-2025, 03:04 PM
