lenovo y50 charging socket shorted out
  • Rolandas
    • Apr 2024
    • Norvegija
    Hei
    The lenovo y50 charging socket shorted out. The computer does not turn on. The inductive coil 1R5 is hot. Do you know which part can short out?
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
  • thesame
    Lenovo TB-X605F fake charging after charging connector replacement.
    by thesame
    Hy guys, i have this lenovo TB-X605F with charging problem, the tablet is fake charging, i have replaced the charging connector twice, it only draws 0.40 Amps when pluging the cable for the first time then it stops drawing any Amps but the tablet keeps showing the charging image at 0% as long as i keep it connected. I have no voltage at the battery connector with the cable pluged, but i have 5 volts after usb connector on some testing points on the board.
    04-03-2024, 03:14 AM
  • nikolayu
    Lenovo ThinkPad X1 Nano Gen 1 not charging on 1 USBC
    by nikolayu
    I have Lenovo ThinkPad X1 Nano Gen 1 which is not charging on 1 usbc port (the one that has mark for charging).
    When i connect usb it switchs to 20v but no current draw (only 0.02a) and orang light is on. In windows it shows that is charging but percentage is dropping.
    Other usbc is charging fine,
    I installed lates bios and firmwares for thunderbolt and battery.
    Could be faulty JHL8040R controller?
    08-31-2024, 11:08 AM
  • B2L_Repairs
    Lenovo g50-80 charging led flashing but laptop not switching on
    by B2L_Repairs
    I got a lenovo g50-80 that shows charging led (orange LED flashing) and when I press the power button the white LED comes on but the laptop doesn't switch on. The fan spins for 2 seconds when I press the power button then it stops. This problem started when my charging dock broke the connecting wires and i soldered these wires back but I might have mixed them. I ended up buying a new charging dock but laptop never switched on it just shows flashing orange LED when charger is connected. Could the super io be bad? I don't know how to go about diagnosing and I can't check any board view since this...
    01-19-2025, 12:28 PM
  • mkdj
    Lenovo Thinkpad L480 : 3VALW rail shorted to ground, but I can't find the shorted component
    by mkdj
    Dear all,
    Laptop is Lenovo Thinkpad L480 (boardview can be found in this badcaps topic). When pressing the power button the LED power light turns on, but nothing else happens.
    I removed the motherboard, checked for shorts on the main inductors. I found that there is a short to ground on the +3VALW_P rail (@PL201). I soldered a wire on the PL201 inductor, and I injected up to 1.3V with my power supply. Current drawn is approximately 3.2A.
    I used a small thermal camera to locate the shorted component. But nothing on the board heats significantly, except the...
    08-11-2025, 04:55 AM
