Dell Precision 5510 " Not a Dell Battery"
  • tomodachi
    • Apr 2012
    • 611
    • Turkey
    Hi
    Dell Precision 5510
    Mobo code : LA-C361P
    This one came in for battery replacement but without original battery, so original battery and charging history is unknown.
    The customer said he bought the computer several years ago second-hand and was told that there was no battery inside but that he could purchase one if he wanted.
    So we ordered a geniune battery for customer, plugged it in
    RTC battery was also dead and it was also replaced. First boot up brought up warning message;
    Click image for larger version  Name:	resim.png Views:	0 Size:	210.9 KB ID:	3502168
    Funny thing is Service Tag is already set.
    And in battery information tab ;
    Click image for larger version  Name:	resim.png Views:	0 Size:	288.0 KB ID:	3502167
    Thought it could be a faulty battery and ordered another, but no change.
    Battery is not being charged even powered off
    Note : There is a " This product contains used parts" sticker on bottom cover.
    Any ideas to get it to charge battery please ?
  • mon2
    • Dec 2019
    • 14671
    Check the voltage on the SMBUS lines of the battery connector with the battery attached. You should have ~3v3 on the SCL / SDA lines.
    • tomodachi
      • Apr 2012
      • 611
      • Turkey
      Hello and thank you for answering
      Both lines have 3.3V
      • mon2
        • Dec 2019
        • 14671
        Try to update the bios or test with another known good bios.
        https://www.dell.com/community/en/co...ccf8a8de62bc4a
        • tomodachi
          • Apr 2012
          • 611
          • Turkey
          Both done, no result.
            • 21914
            Does the service tag in the bios screen match with the one on the sticker on the base cover
            • tomodachi
              • Apr 2012
              • 611
              • Turkey
              Umm service tags are different
              By the way, when I tested it with the battery I got from another same laptop, it charges perfectly and gives no startup errors... pretty confusing
              • mon2
                • Dec 2019
                • 14671
                To me, it appears the batteries you are sourcing have bogus and incompatible BMS modules. The last one you have tested is a good fit and has pacified the checks made by the logic board.
                • tomodachi
                  • Apr 2012
                  • 611
                  • Turkey
                  Absolutely.
                  You wouldn't believe the ability of some companies to produce fake batteries and sell them as original.
                  Returning batteries to supplier, I will share the news
                  • tomodachi
                    • Apr 2012
                    • 611
                    • Turkey
                    Update :
                    Problem fixed with a geniune battery from another supplier. Everything work fine now.
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • HTR-Informatique
                      by HTR-Informatique
                      02-09-2025, 06:51 AM
                    • andrhouseolly
                      Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                      by andrhouseolly
                      Hi.
                      I kindly ask you to help me solve the problem.
                      Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                      The board turns on, there is no image.
                      Read more. When the power supply is connected, the front panel indicators light up briefly.
                      When you press the power button, the button indicator lights up. The board works
                      there is no image, there is no matrix initialization, there is no image on HDMI.
                      When turned on, the fans do not spin, but when they warm up they start spinning.
                      When you turn off the button, the fans spin up to full speed for a short...
                      05-11-2024, 03:14 PM
                      DELL Precision T3420 Precision E3-1220V5 Specification for Upgrade or Repair
                      This specification for the DELL Precision T3420 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3420 boardview and Precision T3420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                      09-12-2024, 03:44 PM
                      DELL Precision 5820 Precision 5000 W-2125 Specification for Upgrade or Repair
                      This specification for the DELL Precision 5820 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 5820 boardview and Precision 5820 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
