A1707 sleeps @ stress
  • iMuhtaseb
    • Jan 2017
    • 122
    • Palesine
    When I run Heaven for a couple of minutes the computer does not shut off I believe it sleeps..
    Because when I plug the power back on; the loading bar on the bottom loads. I remember this bar used to come when the battery drains and writes stuff on SSD rather than memory.
    Anyway, I tried another battery; same stuff.
    When its plugged in; it does not happen..
    Tried with screen off, Touch Bar off; issue repeats itself..
    Found little corrosion on C4237 (PP1V8_SLEEP3_BUCK3)..
    Replaced cap; same issue..
    I replaced the whole SoC PMU (U4200); same thing..
    I took diode mode readings on all bucks around PMU..
    Kinda stuck.. I don't like replacing the T1 just based on a hunch..​
  • Inforgalaxie
    Overheating in Stress Test
    by Inforgalaxie
    Hello i have a problem, i have a laptopt Dell E5570 that in stress test without the battery it works good and not turn off.
    But when i conect the battery and made a stress test the cpu temperature go to 95º and turn off. I also was testing with a new battery and the problem is the same in stress test turn off with big cpu temperature (95-100º). What can be this?
    12-13-2023, 03:24 AM
  • obelix24
    A1707 - No internal display
    by obelix24
    I got two Macbook's Pro 15" A1707 both fully working except no image on internal LCD.
    I've checked and it looks like it's problem with U9850 (on both pin 1 on screen connector is 0.007 or 0.050 in diode mode)
    My question is if this IC can be ordered from Aliexpress (will it work) ?? or it needs to be taken directly from donor (a1707, a1990, a2141) ?
    Is this IC interchangeable (on my board i have 6142E and i found that there can be also HD3SS212) are this chips same ? ? Is it possible to find this IC on some other Macbook 13" (air, pro) ?? i have...
    04-25-2025, 07:55 AM
  • jma46
    A1707 820 281 jumps from 5v -16v on amp meter then restarts
    by jma46
    Hi sorry to Hijack this thread, I have an A1707 820 281 which jumps from 5v -16v on amp meter then restarts, I have checked big coils for shorts, ppbus and all seems ok. Im thinking there is a short which is causing it to reboot but I'm out of ideas? Also another A1707 where the internal SSD is not showing in terminal or disk utility? No excessive heat from SSD chips?
    Thanks in advance for any suggestions...
    08-13-2024, 03:18 AM
  • tommy97
    Apple MacBook A1707 No Audio/Sound
    by tommy97
    I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
    I've also replaced U6300, but the problem persists.
    Here are the current voltage readings:
    • PPV18_S0: 1.8V
    • R6402: 1V
    • R6405: 1V
    • R6403: 1V
    • AUD_SPKRAMP_RESET_L: 1.3V
    • PPBUS: 12.6V
    03-10-2025, 11:22 AM
  • czacha414
    please help me identify macbook a1707 chip
    by czacha414
    Macbook A1707 - Guys, please help newbie confirm if chip on picture is a bios one?
    01-20-2025, 03:39 PM
