Hello friends, this model came with the complaint of no image. The screen, lvds cable, bios and nec tokin chip were replaced and tested. still no image Where else should I look?
DA0SWMB6E0 REV: E NO DİSPLAY PROBLEM HELP
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by r ez ahello my friend
i have a motherboard here with lvds problem
with some panels there is no output just black screen
with some panels its noisy and split horizontally
Dp output is ok
i tried different bios,led,led cable
no change
any idea?... -
by Zeonalbastai have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double... -
hello friends
i had a lenovo b590 with no display
i programmed the bios and now it has display on vga and hdmi but not on lvds
lvds cable and led has changed but no difference
backlight comes up but no data
there is one beep at startup
pch is my suspect but i cant confirm it
any idea?
thank you very much09-01-2022, 03:27 AM -
by Gibon378PC Specs:
- CPU: Ryzen 5 1600
- GPU: GTX 1080 Palit JetStream
- MOBO: ASRock ab350 PRO4
- RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
- PSU: XFX 650W (don't remember what model)
- OS SSD: ADATA SP920
- OS: Windows 10 21H2
Problem description:
Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders... - Loading...
