Macbook Air a1932 only right speaker working
  • obelix24
    • Jun 2023
    • 291
    • Slovakia
    I just got one macbook air a1932 that is fullu working (no signs of liquid damage but there is strange issue that only right speaker is working (that one that is connected directly to audio board)
    the other one is not working at all.
    i've tried to replace left speaker 3x and still no sound, i've also replaced audio board but still the same.
    Do you know what can cause this issue ?
  • mon2
    • Dec 2019
    • 14634
    Left speaker(s) work in the right speaker audio out?
    • obelix24
      • Jun 2023
      • 291
      • Slovakia
      In the setting when i turn the switch to the left and then i try some left right test on youtube then there is still no sound from left speaker but the right speaker is acting as the left (hard to explain i hope you understand
      • mon2
        • Dec 2019
        • 14634
        Yes, I understand. It appears the logic board is not detecting the left speaker logic. Just asking if the actual left speaker makes sounds if you attach to the right speaker connector. Assuming that the actual speaker is not defective.
        Review U6400 which is the audio codec that is responsible to convert the digital audio signals to analog ones for the left speaker (only). Share a good pic of this part. This part may be defective.
        Study the parts linked to the LEFT speaker to be sure each is present. Suspecting that the audio codec is the root cause if BOTH the right & left speaker audio are being merged into only the RIGHT audio channel. That is, if this U6400 was ok, but issue was with the output side parts for the left side, then the left audio would not be merged into the single channel. The PCH who spits out the audio would continue to stream out the audio to U6400.
        Review this area of interest.
        • obelix24
          • Jun 2023
          • 291
          • Slovakia
          Ok i've replaced U6400 and both speakers are working now thank you
          • bouch
            unlock macbook air A1932 2019
            by bouch
            hi
            i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
            i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
            i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
            have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
            I need help or information?
            Does anyone have the minat2 activator 1.4 software?
            Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
            Thank yo...
            03-12-2025, 10:14 AM
          • nikolayu
            MacBook Air A1932 internet recovery loop
            by nikolayu
            I have A1932 that is going to internet recovery every time.
            i tried nvram and smc reset but it looks that MacBook is not reacting to that.
            i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
            keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
            also won’t open option to boot from usb device.
            and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
            07-22-2025, 02:55 AM
          • TOMÁŠ
            MacBook Air A1932
            by TOMÁŠ
            Hi, I've never worked with a MacBook before, so I need some advice.
            I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
            05-20-2025, 11:19 AM
          • Arshad alam4659
            macbook air a1932 sign out of find my
            by Arshad alam4659
            Today I receive a MacBook Air A1932, its apple ID has been deleted but when I am resetting it is showing a message(sign out of find my ) customer's have no apple id he bought this MacBook from someone else can someone help me remove this message...
            04-09-2025, 12:37 AM
          • Sik_6ty_Sixx
            HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
            by Sik_6ty_Sixx
            So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
            02-18-2025, 05:06 AM
