dell inspiron mini 1012 not charging batt
  • crazypepe
    • Oct 2012
    • 34
    • Philippines
    hi guys
    got a dell inspiron mini 1012 that is not charging
    have replaced the burnt charging ic with new one
    (ISL6251AHAZ)
    now it says plugged in,charging but battery is stuck at 0%
    have replaced the battery also but still the same
    any ideas?
    thanks in advance
  • Agent24
    I see dead caps
    • Oct 2007
    • 4957
    • New Zealand
    Re: dell inspiron mini 1012 not charging batt
    Probably some other component around charger IC circuitry also failed.
    -David VanHorn
    • jtamad44
      • Apr 2013
      • 145
      • israel
      Originally posted by crazypepe
      hi guys
      (ISL6251AHAZ)
      any ideas?
      thanks in advance
      Try to update bios.
        • 31029
        if the chip shorted,
        it probably blew an smd fuse.
        • crazypepe
          • Oct 2012
          • 34
          • Philippines
          thanks for the reply guys
          @jtamad44
          tried updating bios but it wont update if battery is less than 10%
          @agent24
          actually i keep checking on other components around it still cant find ones that failed
            • 31029
            if you have a datasheet for the charge i.c. you can check the inputs and outputs.
            • masud
              • Jul 2011
              • 317
              • Bangladesh
              try on changing the two mosfets nearby the (ISL6251AHAZ).
              • sanehdeep2012
                • Oct 2013
                • 139
                • india
                check voltage at pin no 3 of isl6251 it should be high, and check bat charging voltage present at pin no 18 of ISL6251
                most probably BELOW COMPONENTS ARE FAULTY CHECK THESE AT YOUR SIDE
                U16 = ISL6251
                PQ35,PQ39=SIS412DN / SI7716ADN
                ALSO CHECK FOR PR178FUSEABLE RESISTANCE AT +BAT CONNECTION
                ALSO SHARE THE VOLTAGE AT U16 ISL6251
                • crazypepe
                  • Oct 2012
                  • 34
                  • Philippines
                  @sanehdeep2012
                  checked pq35, pq39 out of circuit, both are good
                  resistance for pr178 is 1.4 ohms in my dmm
                  here are the voltages of u16
                  pin 1-5.0v
                  2-4.7v
                  3-0v
                  4-0v
                  5-0v
                  6-0v
                  7-0v
                  8-2.3v
                  9-0v
                  10-0.8v
                  11-0v
                  12-0v
                  13-0v
                  14-0v
                  15-5.0v
                  16-5.0v
                  17-0.6v
                  18-0.7v
                  19-20v
                  20-20v
                  21-0.8v
                  22-0.6v
                  23-0v
                  24-20v
                  thats my second replacement for isl6251
                  • crazypepe
                    • Oct 2012
                    • 34
                    • Philippines
                    dont know if its related but pq40 shows short on pin 3 and pin 2, both sides
                    is that ok?
                    thanks again in advance
                    • sanehdeep2012
                      • Oct 2013
                      • 139
                      • india
                      as per you provide the volage of u16
                      problem releated to
                      pin no 3 (charging enable pin)should be high when charger and battery is connected,in your case pin no 3 of u16 is 0v
                      please clear the following
                      1.battery and charger should be attached to laptop.
                      2.check voltage at pin no 3,6, 7 of battery connector JBATT1 THESE SHOULD BE 3 TO 3.3 V DC.IF Missing check for related ckt and battery faulty.
                      3.Check battery try to replace with another
                      4. PQ40 IS OK as it is use to provide the adapter voltage dcin pin no 24 of u16 and that voltage is available to u16
                      • proman28
                        • May 2014
                        • 9
                        hi i worked on the dell mini 9 and 10s the problem you have isnt a fault just flash bios back to a02 you most likely find it cured the problem let me know
                          • 31029
                          that may be a challenge,
                          dell flashers often want a full battery AND external charger or they wont run.
                          • proman28
                            • May 2014
                            • 9
                            no, you can flash in dos mode by using external commands, after your bios file ***.exe /forceit /nopause will flash down
                            • crazypepe
                              • Oct 2012
                              • 34
                              • Philippines
                              thanks for all the replies guys
                              @sanehdeep
                              voltages of jbatt with battery on:
                              pin 1 - 9.2v
                              2 - 9.2v
                              3 - 3.2v
                              4 - 0 v
                              5 - 2v
                              6 - 5v
                              7 - 5v
                              voltages of jbatt without battery
                              pin 1 - 0.6v
                              2 - 0.6v
                              3 - 7 same as with battery
                              should i replace the charging ic (ISL6251) again?
                              @proman28
                              hi proman unfortunately i couldnt find the bios version a02 so i tried upgrading the bios to a12 in dos mode but still battery still stuck at 0%
                              do you have a copy of a02?
                              have another battery for this model but stuck at 5%
                              other battery is 0%
                              thanks again
                              • sanehdeep2012
                                • Oct 2013
                                • 139
                                • india
                                pl check PL10 coil for open at battery connector , go through attatchment
                                hope your problem will be solved this time, i hope so.
                                • sanehdeep2012
                                  • Oct 2013
                                  • 139
                                  • india
                                  i am sure the PL10 is open
                                  • loser18
                                    • Nov 2013
                                    • 274
                                    @sanehdeep
                                    pin 1 - 9.2v
                                    2 - 9.2v
                                    3 - 3.2v
                                    4 - 0 v
                                    5 - 2v
                                    6 - 5v
                                    7 - 5v
                                    pin 1 - 0.6v
                                    2 - 0.6v
                                    @proman28
                                    other battery is 0%
                                    thanks again
                                    Again...If the laptop posts, DON'T WORRY ABOUT BIOS!!!
                                    It has got nothing to do with BIOS...
                                    As sanehdeep2012 said you don't have voltage on PIN3 & therefore the PU16 disables charging...
                                    • sanehdeep2012
                                      • Oct 2013
                                      • 139
                                      • india
                                      pin no 3 of u16 is low as it not detecting the battery because the path of battery connector pin no1/3 is disconnected from u16 pin no 18, only three components are there in that line
                                      PL10, PL 15 AND PR178
                                      pl check all these because one end you have 9.2v and other hand you have 0.7v which mean something is open in between, so i suggest three component only pl check i sure you will resolve the isue and give a good news to us
                                      • proman28
                                        • May 2014
                                        • 9
                                        sanehdeep downgrade your bios to a00 i done hundreds of these mini 10 and 9 before u start soldering un soldering
                                          DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:30 PM
                                          09-12-2024, 03:28 PM
                                          DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                                          DELL Inspiron 3650 Inspiron 3000 i3-6100T Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 02:15 PM
