Lenovo T580 - LCD Panel problem - error 0288
  • perzyk23
    • Mar 2017
    • 31
    • Poland
    Good morning,
    I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise. Regards​
  • reformatt
    • Feb 2020
    • 1404
    Check voltages at LCD connector, and any fuses etc.
    You should put as much info as possible in your post if you want help, like motherboard part number, link to schematic/boardview etc, background of the issue.
    • perzyk23
      • Mar 2017
      • 31
      • Poland
      Motherboard: LTS-2 MB 17812-1
      CPU: I7-8650U
      Graphics card: Intel UHD 620
      • s_specialist
        Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
        by s_specialist
        Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
        07-07-2025, 11:47 AM
      • konradx
        Lenovo Thinkpad T15 Touchscreen problem bios
        by konradx
        i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
        That is my DUMP.
        My device:
        SN: PF29Y4N6
        1s20S7S2WF00PF29Y4N6
        MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
        09-06-2024, 01:33 AM
      • madrali
        lenovo e15 gen2 bios ? problem
        by madrali
        Model: Lenovo ThinkPad E15 Gen 2 (Intel)
        20TD-50S0KU00
        Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
        I used Lenovo's SmartBeep decoder and it returned error 0284:
        "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
        I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
        06-16-2025, 12:06 PM
      • Ziome3eknh
        Lenovo x1 carbon problem
        by Ziome3eknh
        Hello, I have a problem with this computer.
        After connecting the power supply, the keyboard lights up and the touch bar works, you can click on it and it even illuminates the keyboard. When the fan is turned on, it turns on and off. the processor heats up. I have tried different bios but with no success, the same signs. It doesn't charge the battery either. when starting, it takes 20v and about 0.650a, after some time it drops to 0.350a and 5.2w. Has anyone solved the problem with this model?
        Will it be a RAM or CPU problem?
        below is the computer details
        Lenovo x1 carbon...
        01-29-2025, 02:35 AM
      • jomerfx28
        Lenovo T580 Bios Request
        by jomerfx28
        I've got a system here Lenovo T580- SSD NVme damaged. we replaced the ssd, however it doesnt boot nor detect the new ssd, so could be bios is corrupt.
        Lenovo t580
        P/N SL10T84532
        S/N R90VTEDC
        Type 20LA-S1V100...
        10-25-2024, 11:10 AM
