Tutorial about diagnostic methodes for Motherboards
  • yoritomo
    • Sep 2012
    • 147
    • Belgium
    Hello
    I would like to know if anyone of you knows about an online lesson or tutorial to learn about motherdoards problems detection.
    for example :
    How to identify these problems by symptoms and reaction of the machine :
    -chipset needs to be reballed
    -Processor needs to be reballed(laptops)
    -Voltage regulation troubles
    -capacitors fails and coils, various symptoms(Desktop)
    -GPU (i know already)
    -and other problems are welcome.
    thank you by advance
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3575
    • slovakia
    Re: Tutorial about diagnostic methodes for Motherboards
    LOT of them on youtube. just search "laptop repair training"
    most from india with funny accents :-)
    • ivanxxx
      • Nov 2012
      • 10
      • Croatia
      Try sivainstitute videos, their lectures seems good if you can understand them.
      • yoritomo
        • Sep 2012
        • 147
        • Belgium
        Good evening all
        ivanxxx: thank you very much for this link it is exactly what i need, it is really well made videos, that is an appreciable learning assistance for laptop and motherboard fix.
        India is not only the world capital of Bollywood movies, they are as well the capital of electronic fix and hacks, i saw them to fix rusted dvd players with sand inside In Bakkali for exemple peoples are still living in earth houses with for only windows some wood bars, and more amazing inside it has TV and DVD player
        ktmmotocross: Don't worry for that, i have been in India and i saw worse, they have a very atypic way to speak english but after 30 minutes listening them you feel habit already. All of them speaking same language.
          Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
          Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
          various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
          Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
          trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
          what is wrong with your PC in just seconds. It saves you time and money.
          Our new and improved design...
          11-01-2024, 06:29 AM
        • qwerty99
          Xbox 1.6 Motherboards and Polymer Capacitors
          by qwerty99
          Hello!
          I need to change the capacitors on my three original Xboxes.
          Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
          The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
          The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
          I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
          06-26-2022, 12:53 AM
        • Foetuss
          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
          by Foetuss
          Hi all
          Hope this is in the correct place.
          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
          Could use some double checking to see if I'm not doing something stupid .
          Pictures of the boards are attached.
          What I will be replacing with what : (planned)
          Soltek Golden ::
          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
          01-18-2025, 11:44 AM
        • Kyleadonis
          Launch Automotive Diagnostic Tool Missing Diode and Cap
          by Kyleadonis
          Hi there, I need some help identifying replacements for a Launch Diagnostic Plug In Tool. I can't seem to find any information on the LF 7HZPU Diode so I have no idea what to replace it with if anyone can help? Also there is a missing component on the side that I highlighted in green and I assuming it's a cap?
          I have added some photos for reference....
          09-03-2024, 11:54 PM
        • madscientist750
          Looking for capacitor lists for Motherboards, Video Cards, Home Appliances
          by madscientist750
          I would like to ask if there is some kind of capacitor lists for motherboards, power supplies, video cards, audio cards, microcontroller powered home appliances, and so, that i could try to find and download. I use to repair those things and i would find it helpful if i could know in advance what parts may i need for common repairs.
          07-09-2024, 09:24 AM
