Asus S500 --something I've never seen before.
  • k370
    • Oct 2014
    • 30
    • portugal
    I have something I've never seen before.
    I've received an Asus laptop that had a short in the DC input. I found that the second MOSFET in the DC input line was heating up, so I replaced it, and now the laptop works. Great, isn't it?
    Now, for the odd part: the mosfet replaced wasn't measuring as short or having low impedance on the board either before or after I replaced it. It was an "A5 GND" mosfet, which I swapped for something I had in stock—some N-type 30V MOSFET.
    Now the laptop works fine, but when it restarts, it takes 5 to 7 minutes before it's able to power on.
    For example:
    The laptop runs fine in Windows, but if I restart it, when it shuts down and tries to boot back up, it won't do it right away. I have to wait 5 to 7 minutes for it to actually start again.
    This behavior is the same whether using only the battery, only the charger, or both.
    When it doesn't start, it behaves almost like it has a short in some secondary line. I press the power button, the lights come on, the hard drive spins up, and then it shuts down immediately—this takes around 1 to 2 seconds.
    Does anyone have a clue as to what could be causing this behavior? The time the laptop is on doesn't affect the wait time before it can start again. I've searched for schematics to help troubleshoot, but I haven't found anything.
    The motherboard code is 60NB0060 rev 2.1, and the laptop model is an Asus S500CA.
    Thanks in advance!
  • mon2
    • Dec 2019
    • 14309
    Which charger IC is onboard?
    Check the ACDET pin on the charger ic to confirm it is within normal range with the power adapter. You may have another leaky mosfet onboard. Remove all power and check the resistance across the mosfet pins. Each measurement should be hundreds of k ohms or higher.
    • k370
      • Oct 2014
      • 30
      • portugal
      After looking with more attention, I found the schematics, and the actual model of my board is S400CA rev 3.1.
      The MOSFET I changed seemed like it was shorted, but it wasn't. The issue was with PQ8802, and the original MOSFET reference is (P0903BEA).
      The charging IC on my board is BQ24725ARGRR, and the ACDET pin shows 2.60V, whether the laptop is in a cold state (when it turns on) or a hot state (when it doesn't turn on).
      I've measured all the MOSFETs present on the board, as well as a good amount of capacitors, and everything seems fine.
      Do you have any other ideas?
      I've also included the MOSFET I replaced and the boardview for reference. LINK to boardview https://www.badcaps.net/forum/docume...ptop-boardview
      • reformatt
        • Feb 2020
        • 1416
        I would check power good signals for each power rail back to the EC with the board on the bench. Have seen intermittent issues with BAT54CW/BAT54AW diodes (e.g. D2201/D2202) causing these to be low etc. Power sequence halts as a result.
        • k370
          • Oct 2014
          • 30
          • portugal
          I've solved this... hurray!
          It was the BIOS; I used the dump from this link, and now everything works marvelously!
          https://www.badcaps.net/forum/troubl...s400ca-rev-3-1
          • AppleLover123
            Asus X712EA 3 volts after the first mosfet
            by AppleLover123
            Hey guys,
            i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
            I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
            Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
            I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
            Now i thought something...
            12-15-2024, 07:49 AM
          • Scotchmist
            Asus GA502D keeps blowing mosfet
            by Scotchmist
            I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
            I have removed the mosfet and can run the laptop no problem
            The MOSFET is FDPC5018SG
            Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
            08-24-2024, 02:23 PM
          • MicroSMD Lab
            ASUS ROG Zephyrus GPU Mosfet repeat failure
            by MicroSMD Lab
            The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
            I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
            01-10-2024, 06:36 AM
          • Timp74
            Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
            by Timp74
            Hi All,
            Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
            I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
            08-13-2021, 01:11 PM
            ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
            This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
            09-07-2024, 02:50 AM
