MacBook A1989
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    MacBook A1989
    in operation macbook A1989 with two dead chips ssd sandisk. I think to replace them with toshiba only these two chips! Is it possible to collaborate ssd of two different manufacturers of chips ssd toshiba and sandisk on one board?
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    I replaced all 4 SSD chips from a similar donor, but I still get an error when restoring the DFU. Can you tell me what could be wrong?
    • PITERPENY
      • Jul 2023
      • 461
      • Ukraine
      • reformatt
        • Feb 2020
        • 1488
        Some strict rules you have to follow with NAND swaps. You cannot mix them as each chip has data striped across them by Apple. If that data is absent or incorrect, then a DFU restore will fail. So configuration, brand and order matter. More info here:
        https://www.youtube.com/watch?v=yR7m4aUxHcM
        • PITERPENY
          • Jul 2023
          • 461
          • Ukraine
          friends I really need help with images for ssd A1989. I really need it
          • MyronViegas
            MacBook Pro 2018 A1989 820-00850-A Stuck at 5.00V and 0.150A
            by MyronViegas
            Hey guys,
            I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
            Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....
            10-06-2025, 08:45 AM
          • ErinV
            MacBook Pro A1989 820-00850-A not powering on
            by ErinV
            Hey everyone!
            I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
            I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
            The diode voltages around all 4 CD3215's seem fine.
            For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
            09-30-2024, 10:21 PM
          • Madoy104
            Macbook Pro A1989 - No image, working fine with external monitor
            by Madoy104
            I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
            08-15-2024, 10:01 AM
          • ugamazing
            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
            by ugamazing
            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
            08-31-2022, 07:34 AM
          • PITERPENY
            Macbook A1989, 820-00850, won't boot. 20V, 0A.
            by PITERPENY
            Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
            Here are some measurements, maybe someone can tell what the problem is.
            The initial problem was a burnt out induction coil L8504 (replaced).
            When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
            here are some measurementsmotherboard...
            01-16-2024, 02:19 PM
