A2179 - No Audio
  • iMuhtaseb
    • Jan 2017
    • 125
    • Palesine
    A2179 - No Audio
    this is a board of mine that's I've been trying to repair from time to time..
    liquid damaged on right I/O.. after taking the I/O out and measure diodes and shorts on board I found everything OK except for SPKRAMP_INT_L readings were too high.. and sadly its associated with the T2 chip..
    Days pass by and I'm now good with T2 chip.. so I've taken it out and put another one.. SPKRAMP_INT_L is reading OK now but no audio.. :| with known-good right I/O and known-good right I/O cable..
    I've taken diode measurements.. and I've measured resistors for bad or blown resistors maybe somewhere.. And I could not find out the problem..
    It might be an I2S line issue but sadly I do not own an oscilloscope :|
    Other suggestions?
  • mon2
    • 14660
    Check voltage and diode mode to ground at SPKRAMP_RESET_L.
    • iMuhtaseb
      • Jan 2017
      • 125
      • Palesine
      SPKRAMP_RESET_L
      voltage 1.76v
      resistance 3.99 kOhms
      diode 0.428
      • mon2
        • 14660
        So the I2S amplifier is not stuck in reset mode since the line is 1v8 and is powered by 1v8 so is parked out of reset.
        Perhaps the audio IC is defective or has cat urine on the balls? If comfortable, consider to flux and reflow U6400.
        It is relatively inexpensive but is a wlcsp package so not joy to replace.
        https://www.mouser.ca/ProductDetail/...C24uRB3pOZ46UI
        • iMuhtaseb
          • Jan 2017
          • 125
          • Palesine
          omg you're a genius!
          it worked.. I replaced it from another donor and it worked out..
          why didn't I think of replacing it?! I went to replace a T2 but lazied out for replacing an amp IC.
          Much appreciated it bro
          • Darren Hibbert
            MacBook A2179 Audio board+Power button boardview & schematic needed
            by Darren Hibbert
            Hi.
            Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
            There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
            Many thanks. ...
            08-21-2025, 02:38 PM
          • samson7point1@yahoo.com
            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
            by samson7point1@yahoo.com
            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
            The player processes the audio signal using two different reference frequencies. The "R"...
            04-30-2024, 11:22 AM
          • tccyo22
            MacBook Air 13" 2020 A2179 Audio Board
            by tccyo22
            Hey all! I have a MacBook Air 13" 2020 A2179 that won't switch on with the audio board connected so before just replacing it outright I took a quick look and found a cracked cap and short. Removed the cap and the short has gone so want to replace the cap to see if we can use this audio board still.
            TL;DR Anyone know the value of the cap circled in red in the attached picture?...
            07-23-2024, 03:36 AM
          • i_am_patch
            Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
            by i_am_patch
            Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
            04-30-2024, 08:20 PM
          • silver60618
            Macbook M3 A2991 Speaker Audio Amplifier IC
            by silver60618
            Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
            I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
            09-26-2025, 12:25 PM
