ThinkPad T14s Gen 1 (NM-C891) no power, I could use some help with the troubleshooting
  • mrfree2ita
    • May 2024
    • 36
    • Italy
    I'm trying to revive a Thinkpad T14s Gen1 that seems to have issue with the power. Plugging in the USB-C charger the LED on the charging port doesn't lid and nothing happens if I press the power button.
    Test conditions: board is outside the laptop, battery disconnected.
    I made a number of checks already and found out that the ThinkEngine (page 94) does not set important signals such as M_ON that enable power rails such as 3v and 5v. After I verified that on such rails are not shorted, I also injected 3v into M_ON and the board comes to life (i.e. charging port LED gets orange, 3v and 5v are present). Naturally, it was just a test. ThinkEngine is responsible for a number of other signals needed for the laptop to work.
    I'm now trying to trace down the issue starting from the IC charger. Here the measures I took on the IC charger PU0201 (page 102):
    PIN Measure Label PIN Measure Label PIN Measure Label PIN Measure Label
    1 20v VBUS 9 0v IBAT 17 1.09v COMP2 25 6.03v BTST2
    2 20v ACN 10 0v PSYS 18 3.5v CELL_BATPRES 26 6.03v LODRV2
    3 20v ACP 11 0v #PROCHOT 19 9.24v SRN 27 GND
    4 3.27v CHRG_OK 12 0v SDA 20 9.24v SRP 28 6.03v REGIN
    5 0v EMZ_OTG 13 0v SCL 21 3.25v #BATDRV 29 6.03 LODRV1
    6 2.18v ILIM_HIZ 14 0v CMPIN 22 9.24v VSYS 30 6.03 BTST1
    7 6v VDDA 15 n/c 23 0v SW2 31 0v HIDRV1
    8 0v IDAPT 16 1.2v COMP1 24 0v HIDRV2 32 0v SW1
    I'm not an expert of such boards, but looking at the schematic (that I attach to this post for convenience) that missing PSYS seems rather important to me
    The IC charger talks to the EC via SMbus. I also sniffed the signals on pins 12 and 13 with my logic analyzer and I found that the EC (MEC1663) sends something when I plug the charger in. So the EC doesn't seem to be completely dead. In fact, if I understand correctly, the IC charger acts like slave on the bus and just waits for commands.
    Resistance to ground on PSYS is around 8k ohm, so in line with what I can see on the schematic.
    I could use some help on the the next steps, guys
    Is PSYS supposed to be there since the very beginning, is it something that comes up later on in the power on sequence? Do the values I measured look strange to you?
    Many thanks in advance!
    • 22293
    Schematic & boardview -> https://www.badcaps.net/forum/troubl...atic-boardview
    Reminder: rules and organization of this section --> https://www.badcaps.net/forum/troubl...f-this-section
    • mon2
      • Dec 2019
      • 14882
      Missing the voltage on SCL & SDA lines is of concern since these are open-drain lines and in their parked state, the lines will be floating so the pull-up voltage should have ~3v on each line but are at 0v.
      With no power to the board, confirm the resistance to ground of the pull-up voltage rail of VCC3M (created by PU0501). What is the resistance? Also of concern since this rail is also mated with the PCH.
      Click image for larger version  Name:	pch_3v3.png Views:	0 Size:	40.1 KB ID:	3465801
      • mrfree2ita
        • May 2024
        • 36
        • Italy
        Thanks for pointing this out. Indeed, the VCC3M rail is absent at the moment. PU0501 is one of those that wait for the enable signal M_ON from the ThinkEngine. In fact, if I inject 3v on the M_ON line the VCC3M rail comes up regularly.
        Resistance to ground on the inductor PL0501 starts around 900kohm when I start measuring and then it goes down until it stabilizes at 40kohm
        • mon2
          • Dec 2019
          • 14882
          Confirm the power rails of UTE1B (ThinkEngine-3 block). Is this component being powered?
          • anhbanxoi
            • Sep 2021
            • 180
            • VN
            Try to plug usbc cable to the thunderbolt port nearby. The laptop may turn on
            • mrfree2ita
              • May 2024
              • 36
              • Italy
              Here the measurements on the UTE1B (starting top-left corner in the schematic and moving anticlockwise). In the table, I use mV when I measured just millivolts:
              44 6.6v BAT_VOLT 55 3.3v #SHUTDOWNIN 1 0v M_PGS 36 0v RD1_DRV
              43 18.7v #3SW_OFF 54 mV TH_DTCT 33 0v 5B_DRV 35 0v RD0_DRV
              29 mV RD0_ON 2 GND 34 0v 3B_DRV 30 mV raising CP10OUT
              27 0v RD1_ON 37 GND 42 0v RD6_DRV 32 mV VDD10
              26 mV RD2_ON 46 GND 41 0v RD5_DRV 47 3.3v VCC3SW
              25 0v RD3_ON 57 GND 40 0v RD4_DRV 28 0v 5B
              24 0v RD4_ON 53 3.3v #PWRSHUTDOWN 39 0v RD3_DRV 31 0v VCC5M
              23 0v RD5_ON 56 0v B_PGS 38 0v RD2_DRV 45 19.8v VREGIN20
              I just tried. Unfortunately, no luck. Same result
              • mrfree2ita
                • May 2024
                • 36
                • Italy
                I didn't manage to find much about the ThinkEngine chip (marked BD4179MWV (on my board) or TC62D518FTG).
                Do the values I shared look good/healthy to you?
                • reformatt
                  • Feb 2020
                  • 1551
                  There is no power sequence in the schematic unfortunately. There is however a sequence diagram in the Thinkpad X270 NM-B601 schematic, and looks to use the same ThinkEngine chip, so you should be able to use that as reference. Basic design looks identical to me.
                  The power management is shared between the ThinkEngine and MEC chips. Given that EC_RESET comes from the ThinkEngine chip, seems to me that he is the first guy active in the power up sequence. You are supposed to have M_ON directly after RTCRST. Are RTCRST and SRTCRST both 3V? Share the values for UTE1A might help.
                  Have you checked your PCH power rail for a short BTW? A lot of the signals relating to this initial power on do require involvement from the PCH. Power management IC may have damaged the PCH, it's always a possibility to rule out.
                  • mrfree2ita
                    • May 2024
                    • 36
                    • Italy
                    Thanks for your input reformatt, very interesting points.
                    Here the measurements on the UTE1A (starting top-left corner in the schematic and moving anticlockwise). In the table, I use mV when I measured just a few millivolts:​
                    22 0v EXTPWR# 21 3.3v PWRSW# 4 0v SPISS#
                    19 mV SLP_S3# 20 0v PME# 5 0v SPIMOSI
                    18 mV SLP_S4# 9 0v PGPIO0 6 0v SPICLK
                    17 mV SLP_S5# 10 3.3v PGPIO1 8 0v ECRST#
                    16 mV SLP_LAN# 11 mV PGPIO2 48 0v CPUON
                    15 mV SLP_M# 12 mV PGPIO3 49 0v BON
                    14 mV SUSPWRACK 13 mV PGPIO4 50 0v AON
                    7 mV PLTRST# 3 300mV SPIMISO 51 0v LANON
                    52 0v MON
                    I can measure 3.14v on both RTCRST and SRTCRST.
                    As you suggested, I also measured the resistance to ground on all the power rails indicated on page 16 (PCH POWER):
                    Label Measure Label Measure
                    VCC3M_PCH 40Kohm VCCDSW_1P05 5.7Kohm
                    VCC3_SUS_PRIM 26Kohm RTCVCC 747Kohm
                    VCC1R8_SUS_PRIM 53Kohm VCCRTCEXT 414Kohm
                    VCC1R05_SUS_PRIM 51Kohm VCC1R05_SUS_XTAL 52Kohm
                    VCCPRIM_CORE 51Kohm VCC1R05_SUS_AMP 51Kohm
                    VCCDPHY_1P24 39Kohm
                    • reformatt
                      • Feb 2020
                      • 1551
                      To me, pin 44 (BAT_VOLT) seems low and could potentially be why M_ON is not being asserted. If VREGIN20 is indeed 20V, then I'd expect roughly 12.8V at pin 44, not 6.6V. This is based on the voltage divider R9504 (1M), R9506 (1.8M). R9509 is 0 ohms according to the schematic. That is of course unless the version of the schematic and the board don't line up.
                      Everything else to me looks fine. So check out this voltage divider network, R9505 and C9505.
                      • mrfree2ita
                        • May 2024
                        • 36
                        • Italy
                        Well, that's interesting.
                        R9505 and R9509 are both 0ohm resistors and I get consistent values while checking them.
                        R9504 and R9506 are... funky
                        Every time I measure them after a try (i.e. I plug in the charger and measure voltage on pin 44) I get different values:
                        For R9504 (nominal 1Mohm 1%) I've observed values like 780k, 804k, 921k and around 970k in different tries.
                        For R9506 (nominal 1.82Mohm 1%) I often get something around 1M, but I've also seen 1.6Mohm and even 1.7Mohm once.
                        C9505 is there and since it's in parallel with R9506 I get the same values.
                        Moreover, currently I seem to consistently get 12v on pin 44. However, I'm pretty sure of the 6.6v I previously reported for it and I found some older notes I took a few days ago that say 7.7v on pin 44.
                        I'm confused
                        What would make more sense to try at this point? I was thinking of removing C9505 from the board and see if it affects the resistors values, or even try injecting 12,8v directly on pin 44 (do I risk to damage something in this case?) to see if M_ON comes to life.
                        PS: the schematic matches with both the board view I'm using and what I observed on the PCB, so I'd consider it accurate.
                        PPS: I took measurements directly on the components. The resistance increases during the measurement. The value I report here were taken when the values stabilized.
                        • reformatt
                          • Feb 2020
                          • 1551
                          Either ground the top of the divider network to remove any residual charge (no power connected of course) or remove the resistors for an out of circuit measurement. Given they are pretty small, I move the component with hot air and keep one end soldered to one pad. Makes them stop flying off (measuring these components on the bench with probes is akin to changing Tom Thumbs nappies when he was a baby).
                          If both resistors check out and the volts are inconsistent, the next step would be replacing that ThinkEngine IC. Other than a donor board, the only sources I can see for them are off Aliexpress. SUHMS is normally a pretty reputable supplier and don't send you fake IC's.
                          • mrfree2ita
                            • May 2024
                            • 36
                            • Italy
                            Both resistors' values are spot on when not in circuit.
                            Out of curiosity, I also tried injecting 12.8v (300 mA max) on pin 44 of the ThinkEngine, but I didn't notice any change (i.e. M_ON didn't go high). Moreover, my PSU didn't report any current draw.
                            Many thanks again for your interest and support. I'll see if I can find the chip from a reputable source since I don't have a donor board at the moment.
                            Do you know if a new ThinkEngine (BD4179MWV) would need to be programmed?
                            • reformatt
                              • Feb 2020
                              • 1551
                              No I don’t. There is a SPI interface between the MEC and TE chip though. It’s possible that any programming is uploaded from the MEC at power on, but that would mean if the MEC has an issue then the TE won’t work. We don’t have any data sheets so it’s just a guess.
                              • mrfree2ita
                                • May 2024
                                • 36
                                • Italy
                                "It's alive!"
                                I know that it has been a while, but I finally replaced the ThinkEngine chip and the board shows some signs of life!
                                The power led comes on (orange), and the white led under the power button blinks 3 times (then it stays off). My USB-C power meter shows that the board takes 30mA for a few seconds, then goes back to 0mA and keeps cycling between the two values.
                                Any idea what the 3 blinks might indicate? What would be the next logic step in the troubleshooting?
                                • mrfree2ita
                                  • May 2024
                                  • 36
                                  • Italy
                                  Some additional pieces of information... The power button led blinks only on the moment I plug-in the AC charger.
                                  On AC plugged-in (both with or without battery), the following power rails are showing stable and correct voltage:
                                  VCC5M_PD
                                  VCC3M
                                  VCC5M
                                  VCC1R05_SUS
                                  VCC3_SUS
                                  while:
                                  VCC1R2AP stays at 0v
                                  RSMRST is also low
                                  so it seems to me that accordingly to the power up sequence you suggested before it's kind of stuck on (or just before) the A_ON signal.
                                  Moreover, on battery only (i.e. AC unplugged), when I press the power button the power rails go high for a split second and then discharge towards 0v
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Think Engine chip is programmable?
                                    • mrfree2ita
                                      • May 2024
                                      • 36
                                      • Italy
                                      I couldn't find any information about this for the ThinkEngine-3. According to the schematics, it can be one of the following:
                                      Vendor P/N LCFC P/N
                                      ROHM BD4179MWV SA000090J00
                                      TOSHIBA TC62D518FTG SA00008E500
                                      Based on my understanding, on this board the EC role is implemented by the MEC1663 (which is programmable) and the ThinkEngine-3. The two chips communicate via SPI.
                                      The EC doesn't seem to be stone dead to me, considering that it should be the one responsible for the blinking pattern on the power led for instance.
                                      Considering that when I got the board the BIOS chip was missing, I bought a new one and flashed a version I found here on the forum. But with or without the BIOS chip on, the blinking pattern doesn't change.
                                      Any idea what I could inspect? I was thinking for instance to sniff the SPI communication with my logic analyzer to see if there's any useful pattern there...
                                      • mon2
                                        • Dec 2019
                                        • 14882
                                        To where are the LEDs that blink bonded? Is it the EC or the TE? If the TE, then for sure there is firmware already present inside to offer the blink pattern.
                                          Lenovo ThinkPad T14s Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T14s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T14s boardview and T14s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-07-2024, 07:20 AM
                                          09-07-2024, 07:19 AM
