Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
  • zwect
    • Oct 2022
    • 46
    • Brazil
    I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
    Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
    Here is the original BIOS dump from the 25R256JVEN chip.
  • zwect
    • Oct 2022
    • 46
    • Brazil
    Update: Tested proper ME cleaned BIOS with the laptop's ST on it and no change in symptom.
    PU102 heats up as soon as DC is connected to the laptop too. but i do not know if that should be normal on this model.
    • mon2
      • Dec 2019
      • 14672
      Remove all power. Meter in resistance mode. Measure the resistance to ground of the inductor @ PL101 (either side). Checking if there is a low resistance to ground on this power output rail = shorted part is present. Post the measurement in ohms. Suspects are the USB Vbus rails that consume the +5V.
      • zwect
        • Oct 2022
        • 46
        • Brazil
        Measuring PL101 to GND gives 20.3Ohm
        • mon2
          • Dec 2019
          • 14672
          So there is a partial short on this rail. Everyone attached is a suspect. Would you have a thermal camera?
          Review UI1 - pin 12. What is the resistance to ground here? If it is low, consider to flux and remove UI1 off the board and test again.
          Check UI3 - USB load switch in sot23-5 package. Test the resistance to ground of pin # 1. USB load switches often short out with illegal USB loads. If the resistance is low here, flux and remove this part off the board and test again.
          • zwect
            • Oct 2022
            • 46
            • Brazil
            UI1's pin 12 gives some mega ohms that my multimeter cannot read and stays 0.L with a M at the top
            UI3's pin 1 reads the same as UI1's pin 12
            also no, i do not have a thermal camera, had checked PU102 with isopropyl alcohol method
            • zwect
              • Oct 2022
              • 46
              • Brazil
              Removing PJP103 seems to kill the short on PL101's side. PL101's resistance to ground goes up to 204 K Ohms.
              • zwect
                • Oct 2022
                • 46
                • Brazil
                +5V_ALW's resistance to GND now is 60Ohm after disabling PJP4 (and +5V_ALW_A_TBT reads 30Ohm), where to go from here?
                • zwect
                  • Oct 2022
                  • 46
                  • Brazil
                  Hello?
                  • zwect
                    • Oct 2022
                    • 46
                    • Brazil
                    UPDATE: +20V_TBTA_VBUS_1 29Ohm
                    +20V_TBTB_VBUS_1 is 240K Ohm (not affected?)
                    EDIT: PD_VSYS at RT248's pin 2 (although not present) and UT3's pin 3 is 0Ohm is that how it should be?
                    • yesuha
                      • Apr 2016
                      • 8
                      • mexico
                      did you managed to fix it? have same exact problem
                      • zwect
                        • Oct 2022
                        • 46
                        • Brazil
                        Sadly not, and i didn't get any other clues
                        • mon2
                          • Dec 2019
                          • 14672
                          Your post #10 is a good clue. Review all parts on this low resistance to ground rail.
                          Start with fluxing and removing capacitor CT3. If the resistance to ground does not return to a much higher value, place this capacitor back onto the board.
                          Each part mated to ground on the 'EMI Part' red box are also suspects. It may also be true that the PD controller @ UT3 is 50% broken but doubt it for now.
                          I would flux and remove mosfet PQ1 off the board to essentially isolate parts of the board to hunt for the shorted part. Continue to review and post your updates here.
                          Most likely some USB Type C connector cross short during hot removal while the power adapter was @ 20V killed either the PD controller (partially shorting) or some other part on this network.
                          • yesuha
                            • Apr 2016
                            • 8
                            • mexico
                            Really Bad, i'll try removing UZ7 ,n ot getting hot but checked with 4 points method , it seems something around that área is shorted, Will try later and post results
                            • yesuha
                              • Apr 2016
                              • 8
                              • mexico
                              some advances i made
                              at first got same symptoms led decresing etc...
                              found a short at +20V_TBTA_VBUS_1 removed ut3 got back to normal resistance to ground
                              found shorted +5V_ALW_A_TBT fixed by removing ut3 too
                              pjp4 is a joint only from +5V_ALW_A_TBT to +5V_ALW, as 5valw was shorted too (got some 14 ohms) removed PR607 it is like a bridge for PU601 - VIN_CPU_CORE , ohms at +5V_ALW side growth to 180, so i think PU601 maybe shorted too since at that side have 13 ohms only
                              have a question 180 ohms to ground at +5V_ALW is good? or should be higher in this motherbard?
                              edit: removed pu601 since it has some wires trough some resistors to 5valws short completely dissapeared, so at the end problem (i think) was pu601 and ut3, maybe generic charger fried the circuits, as i live at Mexico and don´t have access to UT3 will return to owner, forgot to tell removed UI3 usb power switch before too, was completely shorted
                              as i can see this mobo is fault prone, if you find anything as a partial short will need to find it trought different techniques, like overheating chips, good boardview analysis and kelvin probe method, gets easier as have a lot of "jumper" resistor and pads
                              • zwect
                                • Oct 2022
                                • 46
                                • Brazil
                                just as i thought then, thank you very much nonetheless, i was afraid of desoldering UT3 and it not being the culprit since i do not have the tools yet to solder that kind of component back.
                                • zwect
                                  • Oct 2022
                                  • 46
                                  • Brazil
                                  I removed PU601 and UT3 but i still have a short on +VCCIN at 20ohm and VSSIN_SENSE is 4.4ohm while PU601 is absent.
                                  Should it be that low or are there more components affected?
                                  Also my +5V_ALW can't be measured (stays M at my multimeter) so i guess that one is ok.
                                  • Andreasbest
                                    Dell Latitude 7410 dead and amber light as long power button is pressed.
                                    by Andreasbest
                                    Hello.
                                    I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
                                    Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
                                    Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
                                    Fact #3 i tried hard reset with cmos/main battery disconnected and power...
                                    12-21-2024, 02:02 PM
                                  • djpaesgana
                                    Hi i need help with a Dell latitude 14 5420 GDF40 LA-K491P Rev 2.0 (A01) 2020-11-16
                                    by djpaesgana
                                    Hi i need help with a Dell latitude 14 5420 GDF40 LA-K491P Rev 2.0 (A01) 2020-11-16 , it charges on usb type C i checked the charger with a pd decoy and a electronic charge its ok when, i tested the usb c jack with a tail tester it reads ok (photo incluided), then with a usb charge tester it looks like its trying to negotiate the PD but ressets i openned the laptop and with a thermal camera i noticed 3 ICS getting hot the TPS65994 (UT3) the ISL95860HRTZ (PU601) and the IC SLGC55544CVTR (UI1) this one checking it on the micoscope looks damaged visually (picture incuided) and looking on the Boardview...
                                    05-14-2025, 08:12 PM
                                  • BTubbs200
                                    Dell Latitude 5420: No charge, no boot; amber LED for as long as the power button is held.
                                    by BTubbs200
                                    Dell Latitude 5420 P137G
                                    Board model LA-K491P REV A01
                                    Laptop is stone dead and only reacts to the power button being held while the charger is plugged in, in which case a dim amber LED fades in and immediately fades out when I let go. Battery being plugged/unplugged does not change anything.
                                    CMOS battery was removed and reinstalled; no change.
                                    No shorts to ground have been identified on the board whilst probing the power rails in resistance mode. No visibly damaged components.
                                    No indication that the CPU is receiving power; CPU fan does not activate.
                                    Of...
                                    01-23-2025, 10:45 PM
                                    DELL Inspiron 5420 Notebook 5000 Specification for Upgrade or Repair
                                    This specification for the DELL Inspiron 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5420...
                                    09-07-2024, 06:38 AM
                                    DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                    This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                    09-07-2024, 06:31 AM
