Acer Aspire one AOD257 netbook black screen
  • Herbssat
    • Sep 2011
    • 194
    Just got one of these in that powers up with a black screen. I am quite sure it is a flaky bios but am not sure of the proper procedure to flash it. I have already tried a few files but no luck with a usb stick. I am afraid that the bios chip may have to be programmed externally. Your help is greatly appreciated.
  • alihomee
    • Dec 2012
    • 1594
    • malaysia
    Re: Acer Aspire one AOD257 netbook black screen
    yas you have to take it out from mobo to program it
    • Herbssat
      • Sep 2011
      • 194
      Any recommendations for a cheap usb spi programmer for this winbond soic-8 chip. Have been currently looking at the ent2580 on ebay. Didnt know if i could use this to flash a .fd or a .rom file. Thanks for your help.
      • Herbssat
        • Sep 2011
        • 194
        Still looking for recommendations for a usb spi programmer that will reflash soic8 chips.Anybody?
        • lezsimply
          The Wanderer
          • 657
          • Philippines
          I recommend this one
          http://www.ebay.in/itm/320967107440?...ht_13630wt_937
          fast, easy to use and updateable
          • Herbssat
            • Sep 2011
            • 194
            Thanks for the quick response. This has become a way of life for these acer netbooks. I am quite sure that some other manufacturers have problems also but not like these acer netbooks. What causes this corruption anyway? Has anybody gotten to the core of the problem or are they just that crappy?
            • Herbssat
              • Sep 2011
              • 194
              Received bios chip today from a vendor and now no power up. 3.3 volts not at power switch. Thought about soldering the old chip back on to backtrack. Any ideas on this. 3.3 volts at the bios chip on 4 pins. I hope this vendor programmed this chip for the right netbook.
              • Herbssat
                • Sep 2011
                • 194
                Soldered the old chip back in and no dice. 0.685 at power switch and fluctuating. Bios chip has voltage at pins 1,3,7,8.
                • thodoris10
                  • Mar 2014
                  • 17
                  • Greece
                  Usually the problem is the CPU, did you try reflow?
                  • Herbssat
                    • Sep 2011
                    • 194
                    Thanks for the response. Trying to see what went south after the new bios chip was installed. It was at least turning on before this. Now nothing and very low voltage at the power switch. Have not tried to reflow anything but im sure that it will still need to be reballed if it works.
                    • Herbssat
                      • Sep 2011
                      • 194
                      Dont have the schematic for this netbook but looks like pin 94 of the nuvoton Kbc is connected to the power switch directly. Help in this matter is greatly appreciated.
                      • lezsimply
                        The Wanderer
                        • 657
                        • Philippines
                        Is the seller of the chip a legit one? Or perhaps may have good feedbacks? if not then you probably got a defective one.
                        • atsio
                          • Oct 2013
                          • 819
                          • Greece
                          It is actually pin 95. Here is the schematic.
                          Check pins 64, 93 and 102 on Nuvoton. Also check if you got signals on SPI rails when you plug in adapter and also on LAD rails.
                          • Herbssat
                            • Sep 2011
                            • 194
                            Thanks for the responses guys. Traced the problem all the way back to the RT8223M(PU3) . Voltage in is not even in the ballpark at 2.6 volts. Will have to see if i have a scrap board to find another regulator. I actually stumbled onto a schematic late last night. Do you think that this bios chip was the cause of this problem or was the regulator failing all along. Without a programmer i could not tell whether the chip was programmed right or not. The seller does have good feedback on ebay.
                              Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
                              This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              09-06-2024, 05:27 AM
                              Acer Aspire Aspire One D255 Netbook One Specification for Upgrade or Repair
                              This specification for the Acer Aspire Aspire One D255 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One D255 boardview and Aspire One D255 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-12-2024, 03:28 PM
                              ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-12-2024, 02:30 PM
                              ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
