cheap solution for bga rework?
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    Hi guys,
    I'm really tired of relying on my friends re-ball workstation, having to travel 2h and pay 40€ to do these jobs..
    As I was reading unique thread on his re-ball jobs, I read about is cheaper solution using a hot air station with bga nozzle on top and a irda table to provide heat underneath, and I was wondering, could it be a even cheaper, yet, stable solution for a temporary BGA station until I get the money for the real deal?
    I googled a bit and found some simultaneous amazing and scary solutions for home made BGA stations. From using a electric stove plate, to using 250W IR light bulbs, etc.. Scary because I believe it's too much heat and probably damaging for other components.
    The one it looked safest to me was one with a modified halogen stove.
    https://www.youtube.com/watch?v=VTAU647jzzk
    Well, I have a hot air station, and my question is, do you guys have any ideas/recommendations for me for a cheap solution to apply heat underneath and do re-ball jobs until I get money for the real deal?
    Thanks.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    Re: cheap solution for bga rework?
    I found bgamods.com forum, but they have such complete jobs and so much diversity it makes it even more difficult to find a simple solution..
    Try Harder!
    • Agent24
      I see dead caps
      • Oct 2007
      • 4950
      • New Zealand
      If you want a cheap bottom heater you will have to use something like what you just mentioned, otherwise buy a proper one.
      But you won't overheat anything IF you have a good thermocouple and control system for whatever you are using as a heater.
      -David VanHorn
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        A lot of people say the Puhui T-8280 preheater is a decent tool for the price.
        A working TV? How boring!
        • Learn2Day
          • Jun 2013
          • 254
          • Portugal
          +200€ is a bit out of my range.. What do you guys think about this one?
          http://saomamededeinfesta.olx.pt/bas...-iid-453380095
          Website is Portuguese, here's a quick translation of it's description:
          characteristics:
          - Real-time display of temperature;
          - Digital temperature setting in increments of 1 ° C;
          - With easily adjustable brackets that hold the plate above the heating surface;
          - Infrared heater;
          - The heater surface: 13cm x 13cm;
          - Temperature: 0 ° C - 400 ° C;
          - Dimensions: 220 x 250mm
          Thanks.
          Try Harder!
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            13x13cm is not going to be enough for all boards, but should do for most laptops. For that price you cannot complain.
            • Learn2Day
              • Jun 2013
              • 254
              • Portugal
              Thanks, I think I'll risk it.
              BTW, I'm also thinking in investing in a EZP2010 BIOS programmer, I can get them in 24h for about 40€.. My question is, will this be compatible with most laptop BIOS from 2008 till now?
              Thanks.
              Try Harder!
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3577
                • slovakia
                or u can do it yourself buying irheater for 30e,2 controllers for 30e and heatplate
                • Learn2Day
                  • Jun 2013
                  • 254
                  • Portugal
                  Can you please post links of what I need to buy?
                  Thanks.
                  Try Harder!
                  • sparker1
                    • Sep 2011
                    • 343
                    There are used ones here http://www.alibaba.com/showroom/used...k-station.html but no prices. I've asked for a price on the Puhui preheater, just to get an idea, and I'll let you know what they say.
                      Multifix 425-01 and 450-01 Rework Flux Datasheet
                      REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                      - No Clean Formulations
                      - Low residue
                      - Range of activity to deal with different component solderability
                      - Halide free
                      - Suitable for dispensing
                      - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                      Both products are supplied in syringes or cartridges for application by dispensing....
                      10-07-2024, 06:02 AM
                    • tommy97
                      MacBook A1932 & A2337 MDM - Permanent solution?
                      by tommy97
                      we're getting quite a lot wiped A1932 & A2337 from scrap with MDM (Remote management), we'd like to find permanent solution to remove it without CPU swap as it gets not economical, I found iremove.tools website which offer permanent solution, however if they got shut-down i believe laptops would also get locked? Does anyone have any knowledge about this service & about any other possible method?
                      06-18-2025, 02:43 AM
                    • bohaboha
                      DO THERE IS A SOLUTION PREVENT MELTING DIFFUSER
                      by bohaboha
                      I want to find a solution, perhaps an ultimate, solution to this dilemma with your expertise. As it stands, the diffuser is too close, if not directly on the joint, there must be a way to separate without affecting image quality, I'm thinking with small glass strips or maybe pieces that make it a little distance, melan, them, or what do you suggest?
                      03-06-2024, 12:59 PM
                    • learnmore
                      Recommended BGA Rework Stations
                      by learnmore
                      Hello Community,
                      Based on your experiences and knowledge, which BGA Rework stations would you recommend for general use for an enthusiast at the low-mid-to-high price range? Based on what I've seen, £6000 may be considered high. I particularly like those with adjustable focus, built-in suction and ball alignment features, but I appreciate that they may be on the high end.
                      Also any thoughts on the PUHUI T-862++ IR Rework Station, LY GXX models, WDS-XXX models?
                      01-22-2024, 04:53 AM
                    • petemanuk
                      Help with IR6500 rework station
                      by petemanuk
                      I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
                      1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
                      2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
                      10-14-2022, 12:31 AM
