Vaio VPCSB2M9E/PCG-41218M dead after drop
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    This laptop is an absolute nightmare, it goes through 4 logic boards from charger/battery to power button. I can't find schematics online, this makes it impossible for me to follow anything. Maybe you guys can help me out.
    The only thing I have working for me is that I have an exact same model working laptop to compare with. I have a big urge to replace board by board to figure out which board is busted and go from there but I'm afraid by doing this I bust both laptops..
    It's completely dead from the drop, but apparently nothing seems cracked, except the body near the battery fit. I get 19V at charger input and 3.3V in a couple battery pins, but battery is not charging, also, laptop doesn't boot on a charged battery. This is pretty much it. I've rechecked all connections and hit the hard reset button just to be sure, nothing worked and now I'm lost..
    Can you guys point me in the right direction?
    Thanks in advance.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    Re: Vaio VPCSB2M9E/PCG-41218M dead after drop
    Here's some photos..
    Try Harder!
    • atsio
      • Oct 2013
      • 819
      • Greece
      Have a look at this.
      • Learn2Day
        • Jun 2013
        • 254
        • Portugal
        Thanks for those schematics but something's not right..
        Dunno if it's related to my board being rev 1.2 and schematics 1.3, but, in example, I followed 19V till PD12, in schematics PD12 is connected to ground. From PD12 i followed it to PU4 pin 10, not present in schematics..
        What am I doing wrong??
        Thanks.
        Try Harder!
        • atsio
          • Oct 2013
          • 819
          • Greece
          Which is PU4 on your board? Why are you following the over voltage protection circuit when you say your problem was a drop down and not a short? Do you have 19V on pin 5 of PQ14 or better 3.3 and 5v on PL16 and PL17?
          • Learn2Day
            • Jun 2013
            • 254
            • Portugal
            PU4 is a CL257 TI, PQ14 and PQ15 have only 3 pins, 0V in all.
            Can't find PL16 and 17, but i believe PL23 is where PL16 is suposed to be, it reads 1V.
            I wasn't following the over voltage protection circuit, I was following the charger input! That's why i think the schematics are not the same.
            Thanks.
            Try Harder!
            • Learn2Day
              • Jun 2013
              • 254
              • Portugal
              Ok. I did a little more digging and apparently the issue is in the main board.
              Dunno exactly how a drop turned into a common failure but the symptoms fit this thread.
              https://www.badcaps.net/forum/showthread.php?t=29549
              Motherboard black connectors are all shorted to ground.
              This was the best solution i found, unfortunately I don't have a regulated power supply..
              Originally posted by michaeleangelo
              Hi guys!
              I have just registered to share a bit of my experience with this mobo.
              I had no power at all on this laptop (current draw was 0.01A when connecting the power adapter to the laptop). BTW, I am using a very convenient chinese cheap power meter to see what happens to the laptops when I connect them: http://www.ebay.com/itm/261219652805 .
              I had the black connectors (in yellow rectangles) on the mobo shorted with each other and to the ground. Therefore, the power daughter board MBX-458 did not provide 19V to the shorted circuit.
              Then I soldered regulated power supply terminals to the points shown GREEN. The voltage was set to 1.5V, the current to 3A. The capacitor in a RED rectangle became hot immediately. So, it was shorted to the ground. After I have removed it, all the shorts with black (6-pin and 10-pin) connectors went away. The cap was replaced by a compatible 10uF/25V ceramic cap, and laptop turned on, was assembled and passed to the customer.
              Of course, in your case this can be ANY other cap or semiconductor, but the main method is the same: apply safe voltage (lower than the intended voltage for the shorted circuit) to the shorted circuit and slowly raise the current while controlling the temperature of the board (with your hands or using any pyrometer).
              Good luck, colleagues, and successful repairs to you all! :-)
              Is there any alternative to find which capacitor is shorted?
              Thanks.
              Try Harder!
              • atsio
                • Oct 2013
                • 819
                • Greece
                Your short is on the 19v rail (r460 is upper fet on 5v rail, drain pins 5,6,7,8 are 19v) so you could try with your power supply (19v) but be carefull, if you see PCH is getting hot, stop it immediatelly, because a fet controlling a voltage rail to PCH is shorted (you pass 19v directly to PCH).
                Remove cpu for test.
                • lefos
                  • Nov 2013
                  • 321
                  • Greece
                  Check for the capacitor on the mainboard.That it's been said on that topic.
                  Also check on the small psu board there are some tiny fuses underneath those stickers.
                  • Learn2Day
                    • Jun 2013
                    • 254
                    • Portugal
                    CPU is soldered onboard. Tried with power adapter, no dice.
                    lefos, no fuses underneath the stickers, can't check capacitors on mainboard without injecting voltage. They're all parallel.
                    Thanks.
                    Try Harder!
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      When you try with power supply, can you check voltage and amps?
                      • Learn2Day
                        • Jun 2013
                        • 254
                        • Portugal
                        I can check voltage, not amps. 19V at DC input. To check current I would need to interrupt the circuit somewhere (obviously), and I don't want to go there because I've ordered a new 0-30V/0-10A regulated power supply which will be arriving this Tuesday or Wednesday, and this way I can measure amps directly before injecting signal.
                        Thanks.
                        Try Harder!
                        • atsio
                          • Oct 2013
                          • 819
                          • Greece
                          When you solder the power adapter cable on the cap you can check with a multimeter if you have 19v. Furthermore you can interupt the plus cable you solder on the cap with a multimeter to measure amps.
                          • Learn2Day
                            • Jun 2013
                            • 254
                            • Portugal
                            Doing that won't I risk busting the AC adapter? Also, in my experience, plugging the adapter to a shorted board, the adapter shuts down.. I can give it a try, but a power adapter is not stable as a power supply..
                            What if I use a desktop power supply and inject 5 or 12V instead? Won't that work best and more stable?
                            Thanks.
                            Try Harder!
                            • atsio
                              • Oct 2013
                              • 819
                              • Greece
                              If rail draws too much current (due to short) it will auto switch off. You can use a resistor to reduce amps drawn.
                              ATX power supplies provide a lot of current.
                              • Learn2Day
                                • Jun 2013
                                • 254
                                • Portugal
                                Yeah I thought about that, ATX says 45A on 3.3V.. Ouch! Is there any i can reduce my ATX 3.3V output to a steady 5A?
                                I'm a bit rusty on my U=RxI theories, but if I'm not mistaken a half ohm resistor in serial with the circuit should ensure to provide a 6.6A maximum current. What I'm unsure is if the full 3.3V will go through.
                                I'm very reluctant to inject 19V directly into the board from power adapter. I think more things could go wrong injecting such high voltage in the components..
                                Thanks.
                                Try Harder!
                                • Learn2Day
                                  • Jun 2013
                                  • 254
                                  • Portugal
                                  Hey guys,
                                  Today I got a new regulated power supply and I solved that shorted capacitor from the other thread. Now the main board is no longer shorted, but I still have no power...
                                  I think this short must have busted something else in the power board. Now I'm back to following this:
                                  atsio can you help me out?
                                  Thanks.
                                  Try Harder!
                                  • atsio
                                    • Oct 2013
                                    • 819
                                    • Greece
                                    Your charger is BQ24725?
                                    • Learn2Day
                                      • Jun 2013
                                      • 254
                                      • Portugal
                                      I'm not sure i understand your question.. I'm using one of two universal AC adapters I have in my bench. Is this what you meant to ask?
                                      Try Harder!
                                      • atsio
                                        • Oct 2013
                                        • 819
                                        • Greece
                                        No the charger IC on the daughter board is BQ24725?
                                        • BTubbs200
                                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                          by BTubbs200
                                          Dell Latitude 5420 P137G
                                          Board: LA-K491P REV A01
                                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                          Board seems to have no shorts, all power rails are fine and show high resistance.
                                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                          01-24-2025, 08:15 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                          Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                                          This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                                        • flat-earther
                                          how to prevent a connected charger from draining battery when not charging?
                                          by flat-earther
                                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                          So the battery is backfeeding the charger and being drained.
                                          How can I prevent...
                                          Yesterday, 01:04 PM
