Toshiba Satellite Pro No Power
  • anotherdude
    • Feb 2013
    • 488
    My son was at his friends house with his laptop and his left click got stuck and wouldn't click so his friends dad had the brilliant idea to stick a screwdriver in and try pop it out.
    So as he done that the laptop turns off instantly and now no longer charges or turns on with no leds anywhere.
    So stripped it down and can see where he has scraped the board and remove a resistor and blew out a stepdown converter.
    Thinking this is completely done for?
    As my understanding of the stepdown converter would downscale the needed amps or voltage and now without it with a charger being plugged in numerous times and trying to turn it on could of well blew out other components?
    heres the picture of it anyway
  • anotherdude
    • Feb 2013
    • 488
    Re: Toshiba Satellite Pro No Power
    anyone?
    • atsio
      • Oct 2013
      • 819
      • Greece
      Give exact model and board number.
      • khaahk
        • Dec 2013
        • 779
        • Estonia
        You need to order replacement ic and add the removed component. After that you will know. Also need to have hot air station to change the ic. To know which component was removed, give the exact model of the laptop and mainboard name and model if possible.
        • atsio
          • Oct 2013
          • 819
          • Greece
          It is better to remove the TPS51124, solder the missing capacitor (from what I understand from the photo and its datasheet), check for shorts on the two output lines, the VIN line and the 5VA line, check if upper and lower fets of both lines are O.K. and then solder the TPS51124 and power up laptop.
          • spleenharvester
            • Mar 2010
            • 903
            How on earth does someone even manage that through the TP plastics?
            But yeah as the others aid, replace TPS51124 and the missing capacitor. If it doesn't work after that consider scrapping it. It's hard to give a better answer without knowing the model number.
            Be warned it probably still won't work after doing the above. In my experiences with DC stepdown-related damage, there's always some other component somewhere that's near impossible to track down causing problems. On a HP 6735s I worked on that component actually turned out to be on the opposite side of the board.
            Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
            • anotherdude
              • Feb 2013
              • 488
              sorry i don't have the motherboard model as i'd decided the IC was out of my depth to remove with no rework station
              and the likes of RS Components wanting £4 for the IC then near £7 handling and packing for a IC smaller than a cheerio, joke of a company.
              laptop model is L450D-12X
              thanks for the responses, even if I could replace the IC i'm guessing other components could be dead and it'll be never ending fault finding etc, luckily I guess this has visual damage
              @spleenharvester
              The guy after the fact is now denying all knowledge of doing this and claiming the laptop was already off when he'd tried to move the left click back, which is utter rubbish, the scrape mark can clearly be seen on the picture and from my experience marks like that and components becoming missing doesn't happen on it's own
              • spleenharvester
                • Mar 2010
                • 903
                It's possible it was indeed switched off but that the battery or AC was still plugged in, hence causing the short.
                Best thing to do is look for a spare on any other scrap boards you have lying around. I've replaced QFN chips like those several times with a hot air gun, and almost no experience.
                • anotherdude
                  • Feb 2013
                  • 488
                  tbh i'm not going to attempt it no doubt i'll still get £50-60 after fees on ebay for it as the battery still held just over a hours charge and the screen is still fine.
                  my son told me what happened he stuck the knife/screwdriver in and the laptop just turned off so anything after doesn't really matter I suppose
                  thanks for your input
                  • spleenharvester
                    • Mar 2010
                    • 903
                    Can't blame you really, not worth the effort for an old, low-end AMD based laptop in my opinion. Usually if it's older than rPGA988 socket and the problem isn't an easy fix I just chuck it in the scrap.
                    • anotherdude
                      • Feb 2013
                      • 488
                      i'd upgraded the si-42 to a rm-72
                      was fast enough but picked up amilo pro v3525 yesterday for £30 so alls good for now
                      • dj_ricoh
                        • 2073
                        that TPS51124 is SYSTEM POWER +V1.8S
                        so i`m 40% he is not the only one broken
                        • anotherdude
                          • Feb 2013
                          • 488
                          would anyone know if the CPU would of likely of survived this
                          • atsio
                            • Oct 2013
                            • 819
                            • Greece
                            Probably, yes.
                            • anotherdude
                              • Feb 2013
                              • 488
                              just for anyone interested CPU was/is dead
                                Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                09-06-2024, 06:10 AM
                                Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                09-06-2024, 05:40 AM
                                09-06-2024, 05:27 AM
                                Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook Specification for Upgrade or Repair
                                This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-11J boardview and Satellite Pro R50-EC-11J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                09-06-2024, 08:10 PM
