TPS51125 on C650
  • salawayon
    • Nov 2012
    • 575
    • philippines
    TPS51125 on C650
    I'm having problem with the 5vdc output of tps51125. Pin20, 21, 23 and 24 had no measurable voltage in it. At pin22 it had 5vdc. Tried already replacing tps51125.
    Any info?
    Thanks.
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    Re: TPS51125 on C650
    Measure the following pins - 1,3,6,8,13,17 and post back results.
    • salawayon
      • Nov 2012
      • 575
      • philippines
      Sorry, the unit been pulled out already. I've encountered this problem in acer and macbook. But at macbook it still powered up and the only problem is it doesn't have lcd backlight. I really wanna know how this chip works...
      Thanks.
      • Francisco.s
        • 686
        • Spain
        The best way is reading out the data-sheet.
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          on mac book 5v appears after pressing power button, for backlight you need to have 3 main signals vin, on/off and dim. if you cant trace the problem just check which signal doesnt exists and separete that pin from mobo and apply the signal which you'll find somewhere on the mobo by a resistor and a wire.
