Force A1181 Mobo to Boot on External Monitor
  • JuniperSprouts
    Solder Soldier
    • Aug 2010
    • 119
    I have a Macbook A1181 (820-2279-A motherboard), which is probably this model: _everymac.com/systems/apple/macbook/specs/macbook-core-2-duo-2.1-white-13-early-2008-penryn-specs.html
    It is essentially just the laptop bottom (no LCD).
    How can I force this to boot to an external monitor?
    I would appreciate people with personal experience doing this. Seems an almost unexplored pursuit.
    I wish I was a competent electrical engineer.
    I learned a bit about reed sensors/switches vs. hall-effect.
    I'm not sure if my magnets are powerful enough. They are not terribly strong.
    I don't even know if the hall-effect sensor tripping will force it to (from boot time) display only on the external monitor. Anyone confident in messing with this circuitry?
    _www.allegromicro.com/~/Media/Files/Datasheets/A3213-4-Datasheet.ashx
    On page 3, you can see the pole configuration. I have the LH package (I am pretty sure). Any thoughts? Honestly, the chip only says:
    Code:
    13E
    This style hall-effect sensor seems to have a universal configuration? The configuration was the same with the 3 manufacturers I checked.
    This kid "sort of" did what I am trying to do:
    _nemrod.se/hardware/macbook-reed-switch/
    *What he is calling a reed switch is a hall-effect sensor; more info (for amateurs like me):
    _www.meder.com/fileadmin/meder/pdf/en/Reed_Sensors_vs._Hall_Effect_Sensors.pdf
    Sorry to ask such beginner-esque questions. I am slowly learning.
    Thanks,
    Jaime
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: Force A1181 Mobo to Boot on External Monitor
    you should modify bios.
    • t.j.
      • Apr 2010
      • 383
      • canada
      is there not a hotkey combo?
      an then some suggestions from the interweb.
      http://www.livingdigitally.net/2006/...an_extern.html
      • JuniperSprouts
        Solder Soldier
        • Aug 2010
        • 119
        Pray tell, how?
        • JuniperSprouts
          Solder Soldier
          • Aug 2010
          • 119
          Is there a combo?
          That link only refers to (normal, complete) laptops. I only have a bottom (just mobo, essentially).
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            you may find information and help at bios mods forum.
            • JuniperSprouts
              Solder Soldier
              • Aug 2010
              • 119
              spidey,
              Bios-mods has nothing. Please do not post in my thread anymore. You ever seen a Macbook with a BIOS?
              • dj_ricoh
                • 2073
                • uk
                how rude!
                • JuniperSprouts
                  Solder Soldier
                  • Aug 2010
                  • 119
                  I said, "please."
                  • spidey
                    climbs
                    • Dec 2012
                    • 644
                    • Cyprus
                    Originally posted by JuniperSprouts
                    spidey,
                    you are an interesting person. yes of course mac has a bios, but you cant enter any setup or bios utils similar to pc's. i am an electronics/computer hardware tech. and doin this job 15+ years. it was just an idea for you to figure it out, and modding bios is not my intelligence so tried to direct you to a better place. But never mind, doesnt worth. find you own way.
                    • JuniperSprouts
                      Solder Soldier
                      • Aug 2010
                      • 119
                      PPC Macs used Open Firmware whereas Intel Macs use a technology called Extensible Firmware Interface or EFI. They do not have a normal BIOS. I have played with Open Firmware before (making USB drives enumerated & bootable). It required being able to see it, though. If that [BIOS diddling] were even possible, how could I even do that with NO DISPLAY?
                      The reason I created this thread was because I could not figure it out. You're an experienced tech, and these are your replies/posts?
                      Please stop spamming my thread.
                      • chinsuckseed
                        Need Help to Boot with External Display XPS 13 9343
                        by chinsuckseed
                        I need some help !! I just update Display firmware of XPS 9343 but it 's wrong firmware the system prevent me from BOOT and got 8 beeps even i press FN+F8 to connect HDMI to external Display then FN+F12 to select Boot Menu, it stucked at Dell Logo and preparing to Boot Menu, i would need your help to boot to an external display I have dump my BIOS of my XPS 9343 . pls advice me would be highly appreciated. THank u very much
                        https://drive.google.com/file/d/1pXd...usp=share_link
                        02-23-2023, 06:48 AM
                      • privato89
                        Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                        by privato89
                        I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                        Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                        Let's begin:
                        Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                        03-26-2024, 06:37 AM
                      • ugamazing
                        Odd One: 820-00923, Won't Boot to External on 2 Ports
                        by ugamazing
                        We got a really weird one in the shop last week and I've just been trying to figure out exactly what could cause the issue's we're experiencing. The symptoms are odd:
                        820-00923, no liquid, no damage, not previously-repaired, etc.
                        1. Unit powers up and boots fine; passes AHT, SSDs wipe/install OS perfectly fine, unit will run for hours under stress, and charge/discharge totally fine from ALL four ports. No issues until...
                        2. You try to boot to an external drive (OS installer or bootable drive, doesn't matter) using ONLY the "bottom" port on each...
                        04-21-2022, 10:49 AM
                      • Luke Anders
                        Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                        by Luke Anders
                        A few details about the laptop itself:
                        Name: Lenovo Legion 5
                        Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                        BIOS Version: GKCN60WW
                        EC Version: GKEC65WW
                        Serial Number: PF39AQ7Z
                        Board Model: NM-D562 Rev 3.0
                        RAM: 16GB Installed, DDR4 (brand new)
                        NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                        I bought this laptop recently from eBay as a faulty device....
                        10-12-2024, 05:13 AM
                      • madan1
                        Cisco catalyst 2960c POE
                        by madan1
                        Hello everyone.
                        Got a catalyst 2960 from the usual scrapyard - ebay.
                        It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
                        Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
                        Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
                        The switch fails to boot due to the following POST error:...
                        12-19-2024, 09:34 AM
