Lenovo V14 G2 heating component
  • Nagyesz
    • May 2024
    • 124
    • Hungary
    I haven't downloaded the schematic yet, as I still want to master the bv for now, but I'm increasingly seeing that knowledge of both will unfortunately be necessary very soon
    So, should I start by injecting 1V into PJ6003 first, regardless of which rail? (+3VLP, +3VL)
    To be honest, I've looked at the schematic, but my eyes aren't quite adjusted to it yet. What will my next will be?
    • mon2
      • Dec 2019
      • 14659
      Boardview for the NM-D521 appears to be a match to your board. Therefore we have access to the schematics as well.
      • mon2
        • Dec 2019
        • 14659
        Yes, if you have a variable power supply, inject 1 volt onto this rail and whomever is shorted will heat up. You can use the thermal camera or IPA to hunt down the part.
        • Nagyesz
          • May 2024
          • 124
          • Hungary
          I had to take a closer look a few times.
          Unfortunately, I don't have a thermal camera yet, so I used basic methods,
          I did find something that was heating up, but it was far from hot. It was drawing 0.2A at 1V, and it was UE1 that I felt was getting warm. Is there a way to be sure that this is where the problem?
          • mon2
            • Dec 2019
            • 14659
            Hunt for RE5. This should be a solder blob or a 0 ohm resistor. If you remove this 'short' then you will be removing UE1 from this common power supply as a load. Afterwards, test the resistance again to see if it is higher or not.
            Recommend to source IPA (pharmacy grade is recommended) alcohol as it is more pure. Then pour over the parts you suspect. The heat will make the IPA evaporate faster than the cooler parts.
            • Nagyesz
              • May 2024
              • 124
              • Hungary
              #26
              I'm sorry for asking again, I found the RE5 +3VL_EC is OL, while the +3VL is 4.6 ohms. These two are blob, how can I 'remove short', or what to do with the blob?
              • mon2
                • Dec 2019
                • 14659
                Post a clear picture of RE5. From the schematic, this should be a short on the trace or a 0 ohm resistor. Either way, if this part is present, you should have 4R6 ohms on each test point.
                With no power to the board, meter in resistance mode. Place one meter probe on +3VL and other meter probe @ +3VL_EC. What is the resistance? It should be ~0 ohms (Not OL = over limit).
                • Nagyesz
                  • May 2024
                  • 124
                  • Hungary
                  #28
                  Not entirely, if is it RE5 (pic) is likely the pin 1 with 0.05 ohms to the PJ6003. However, pin 1 and pin 2 show OL to eachother when measured in 20k ohms.
                  • mon2
                    • Dec 2019
                    • 14659
                    My bad. RE5 has '@' symbol = 'do not stuff' on these schematics so this part will not be populated.
                    Can you confirm that the WLAN card is removed from the long black socket in the above pic? If not, remove it and check if the short remains. The WLAN card is one of the loads on this same power rail.
                    • Nagyesz
                      • May 2024
                      • 124
                      • Hungary
                      #30
                      I'm sure there is no wlan card.
                      4.6 ohms is still on the line.
                      So what we know for sure is that something on this line is shorted, and when 1V was injected, only the UA1 heated up.
                      What should be done now?
                      • mon2
                        • Dec 2019
                        • 14659
                        What are the topside markings on UA1? Share a pic. Is it the sound card IC = ALC3287?
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          #32
                          PJ6003 solder blob must be removed to proceed further. You need a soldering iron,de soldering wick,good quality flux to remove the excess solder to separate the jumper and then inject 1V to the shorted side. If nothing significantly heats up increase the voltage to max 1.2V/5A. Most likely its SIO which will heat up a bit.
                          • Nagyesz
                            • May 2024
                            • 124
                            • Hungary
                            #33
                            Pic about the ic which was warming: (IT8227VG-128)
                            Also a pic about PJ6003, do I need to further remove everything?
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              #34
                              To me,it seems like the jumper is not separated.A beeter quality picture of the jumper area will clarify.
                              • Nagyesz
                                • May 2024
                                • 124
                                • Hungary
                                #35
                                I did it. PU​6001 13 pin OL, but the other line still shows 4.6 Ohms, so I'll start experimenting with the PSU on 1-1,2V
                                • mon2
                                  • Dec 2019
                                  • 14659
                                  PJ6003 looks to be still shorted. Can you confirm?
                                  • Nagyesz
                                    • May 2024
                                    • 124
                                    • Hungary
                                    #37
                                    Yes, that is, the +3VL line remained at 4.7-4.6 ohms, and with the PSU at 1.2V, the line drew 0.25A. Nothing really heated up again, maybe the UE1 where a temperature change could be felt.
                                    I believe it can now be the +3VL line is the main suspect. However, there was only very slight heating at UE1.
                                    • Nagyesz
                                      • May 2024
                                      • 124
                                      • Hungary
                                      #38
                                      So, is the motherboard faulty because of the SIO? Is there anything else I could check on the motherboard?
                                      • tandoori
                                        • Nov 2024
                                        • 4
                                        Did you find out something new? I got a V15 G2-ALC and the same problem.
                                        Cheers, tandoori
                                        • Nagyesz
                                          • May 2024
                                          • 124
                                          • Hungary
                                          #40
                                          Bad SIO
                                          I’m almost certain about this, but what’s even worse is that there’s no pre-programmed SIO available for sale anywhere, and I’d also need a bga machine...
                                          • coasterghost
                                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                            by coasterghost
                                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                            System Hardware:
                                            Processor: AMD Ryzen 7 PRO 5850U
                                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                            09-08-2025, 10:46 PM
                                          • A1yn88
                                            Lenovo Legion Y740 LA-G132P power on, but CPU and GPU are not heating
                                            by A1yn88
                                            Hi everyone. I have in the workshop Lenovo Legion Lenovo legion Y740, LA-G132P which had a burnt component, PUZ7 from the schematic. I replaced that part from a donor motherboard, same result. I noticed that VCCSA is missing. I have attached a diagram and measurements. I saw that many people have a problem with the PQZ1 mosfet next to it. Maybe it's the same cause, only that I didn't find anyone on the forum to say whether the repair was successful or not. Can someone help me? Thank you....
                                            12-06-2024, 01:24 AM
                                            Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                            09-06-2024, 06:40 AM
                                            This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                            09-06-2024, 06:06 AM
                                          • derradji89
                                            Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                            by derradji89
                                            Hi everyone 🤗
                                            I have a Lenovo MIX 320-10lCR computer.**
                                            1. **Operating System**: Windows 10 ** Education** 64-bit.
                                            2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                            3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                            4. **BIOS Chip Reflashing**: Currently,...
                                            04-19-2025, 03:04 PM
