Lenovo V14 G2 heating component
  • Nagyesz
    • May 2024
    • 124
    • Hungary
    Hi all!
    I have a laptop that the previous owner tried to repair. It didn't have backlight, but during the repair, accidentally short-circuited two components.
    Details:
    Inductors:
    PL5400 OL CHG_PHASE_S CHG_CHG ▶ 0.22V
    PL6001 OL 3V line
    PL5701 OL 5V line
    PL1004 9.5Ohm P_VDDCR_SOC_PH1_30
    PL1001 5.2Ohm +VDDCR_CPU
    PL1002 5.2Ohm +VDDCR_CPU
    PL1003 5.2Ohm +VDDCR_CPU
    PL7201 52.5Ohm +0.75VALW_P ▶ 3.9V
    PL7203 85.2Ohm +1.2V_P
    PL7202 OL (10KOHM) +1.8VALW_P ▶ 1.16V
    I measured the voltage of each inductor when the charger was plugged in (▶) rest of them has no volts, doesn't power on.
    Two component which was short ciruited is FV1 CV5 B+ +LEDVDD B+ GND
    Heating component is:PU6001 ! ( SY8386BRHC_QFN16_2P5X2P5 )
    1 pin 1.27
    2 pin 20.7V should be about 3v
    3 pin 20.7v should be about 3v
    4 pin 0v
    13,9,5 pin 0v
    Issue is most likely on the 3V line, but I simply can't find the source anywhere. How should I start?
    Also
    PJ6001 1V and GND
    PC6015 1V and GND
    Thank you in advance for the suggestions!
    Also I attach boardview
    • 21842
    Please post a link to the boardview https://www.badcaps.net/forum/troubl...f-this-section
    • Nagyesz
      • May 2024
      • 124
      • Hungary
      Link to boardview https://www.badcaps.net/forum/troubl...-2-0-boardview
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        PU6001, pin 2-3-4 are ties together and should be 19V as its VIN. Read diagram /datasheet carefully before proceeding.. What's the resistance to GND on FV1,pin1/pin2?
        • Nagyesz
          • May 2024
          • 124
          • Hungary
          Both pins are approximately 5 MΩ to GND, 20.3V travelling through
          (I fixed the short circuit a while ago, replaced the capacitor, and cleaned everything with alcohol.)
          • mon2
            • Dec 2019
            • 14659
            ?? Normal rail voltage is ~3v but you have 20V? ​
            • Nagyesz
              • May 2024
              • 124
              • Hungary
              Yes, when I measured it, that's the value I got, and this ic gets very hot. The boardview shows 3V for the ic, but due to the previously mentioned VIN, I thought it was normal, right?
              Click image for larger version  Name:	2000v.png Views:	0 Size:	60.2 KB ID:	3343792
              • mon2
                • Dec 2019
                • 14659
                No, no. This is Vin. This is a high voltage Vin regulator that is capable of accepting such a high voltage and lower it down to whatever. A buck regulator.
                If the part is heating up, remove all power -> measure the resistance to ground of the output rails. If there is a low resistance to ground, then something is shorted on the rail and causing an excessive load and heating up this part.
                See attached.
                Measure the resistance to ground of pins 15 / 16 (they are tied together so either is ok). What is the measurement?
                • Nagyesz
                  • May 2024
                  • 124
                  • Hungary
                  Pin 15-16 is the lowest measured in 200kohm, both of them 6.7kohm,
                  14, 6 pin 0.03ohm rest of them OL and pin 10 is about 100kohm
                  • mon2
                    • Dec 2019
                    • 14659
                    Not shorted. If this part is heating up, replace it.
                    • Nagyesz
                      • May 2024
                      • 124
                      • Hungary
                      Alright, I'll order it. By the way, I'm almost certain the short circuit was on the +B line, so it probably took out this IC. Thank you!
                      • mon2
                        • Dec 2019
                        • 14659
                        Forgot to ask about pin 13 = 3v LDO rail. The pins 15/16 are switching rails. What is the resistance to ground of pin # 13?
                        • Nagyesz
                          • May 2024
                          • 124
                          • Hungary
                          I missed it... 13 pins is 4.6 Ohms.
                          • mon2
                            • Dec 2019
                            • 14659
                            Ouch. Remove the cap that should be on this line and then measure the resistance to ground again. Everytime, without power of course to the board. Perhaps this local cap is shorted.
                            • Nagyesz
                              • May 2024
                              • 124
                              • Hungary
                              Which would be better to remove first?
                              Click image for larger version  Name:	errr3r3.png Views:	0 Size:	43.5 KB ID:	3344596
                              • mon2
                                • Dec 2019
                                • 14659
                                PC6006. The other appears to be PCB trace / solder blob short / jumper. Concern if this rail is powering the EC controller which will be the device that controls your keyboard and other low level functions. Confirm if the PJ6003 is a solder blob. If yes, after removing PC6006, then can review the balance of the loads on this power rail. This LDO is a low current rail so only a few components can be powered by this internal regulator. Someone is shorted here and most likely causing the heat up of the regulator.
                                Excellent - first remove the capacitor. Then test again if the resistance is higher. Only if required, remove the solder blob @ PJ6003. Then we will know which area of this rail is shorting.
                                • Nagyesz
                                  • May 2024
                                  • 124
                                  • Hungary
                                  Removed PC6006, solder blob is 4.6 ohms to gnd again :/
                                  How should I remove the blop now?
                                  • mon2
                                    • Dec 2019
                                    • 14659
                                    Yes. Then check the resistance again on each side of the empty solder pads. Suspecting the short is further on the downstream / consumer side of this rail.
                                    Use the BV file to assist. When you select this solder blob pad, who lights up on the BV file. Each is a suspect. Will do the same in a few.
                                    • Nagyesz
                                      • May 2024
                                      • 124
                                      • Hungary
                                      Found these
ID:	3344626Click image for larger version
                                      • mon2
                                        • Dec 2019
                                        • 14659
                                        Ok - may have found a gold mine. Maybe. Downloaded the above linked BV file and unable to load it with my viewers. Checked my (paid) database service and they do not offer the same BV file but found the BV & schematics for the NM-D521 board. This board appear to be very similar.
                                        Do you have access to the NM-D521 schematics? This rail does travel all over the board but there are jumper solder blobs again to disconnect the EC power rail which is from this LDO. An alternate approach is to inject 1 volt onto this rail and check who heats up.
                                        ** DISCONNECT any IO cables; WIFI Card; Ethernet card and test again the resistance to ground. Each is powered from this low current rail.
                                        Click image for larger version  Name:	solder_short.png Views:	0 Size:	18.2 KB ID:	3344636
                                        Click image for larger version  Name:	PU6001.png Views:	0 Size:	172.3 KB ID:	3344634
                                        Click image for larger version  Name:	ec_rail.png Views:	0 Size:	42.7 KB ID:	3344632
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • A1yn88
                                          Lenovo Legion Y740 LA-G132P power on, but CPU and GPU are not heating
                                          by A1yn88
                                          Hi everyone. I have in the workshop Lenovo Legion Lenovo legion Y740, LA-G132P which had a burnt component, PUZ7 from the schematic. I replaced that part from a donor motherboard, same result. I noticed that VCCSA is missing. I have attached a diagram and measurements. I saw that many people have a problem with the PQZ1 mosfet next to it. Maybe it's the same cause, only that I didn't find anyone on the forum to say whether the repair was successful or not. Can someone help me? Thank you....
                                          12-06-2024, 01:24 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
                                          This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                          09-06-2024, 06:06 AM
                                        • derradji89
                                          Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                          by derradji89
                                          Hi everyone 🤗
                                          I have a Lenovo MIX 320-10lCR computer.**
                                          1. **Operating System**: Windows 10 ** Education** 64-bit.
                                          2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                          3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                          4. **BIOS Chip Reflashing**: Currently,...
                                          04-19-2025, 03:04 PM
