Asus X302LA battery power on issue
  • s_henya
    • Jan 2011
    • 483
    • Israel
    Hey all,
    very weird case,
    When laptop is connected to charger, battery is charging and holding charge.
    When connected to charger:Upon power on, laptop turns on then off then on again.
    Without charger, upon power on, laptop is turning on then off and staying off. If i try to push again on power button it’s doing the exact same thing.
    i ordered a new original battery (i doubt it’s really original but a very good copy) exactly same phenomena.
    i upgraded the bios to 206 but no change.
    Guess my MB is the problem, but what should i check?
    thermal camera while off didn’t show off anything weird.
    and when its on CPU is warming up the board beyond ability to differentiate.
  • mon2
    • 14660
    Review the sticky above on charger circuits by piernov
    Suggest reviewing the charger circuit and their mosfets. Is the battery charging to its full potential and yet still unable to power the laptop?
    What is the battery is removed and tested with only the power adapter? Does the laptop boot?
    Which charger IC is onboard? Most Asus board schematics are kept as a family secret so you will be our eyes on this board. With no power, test the resistance to ground of each and every inductor on the board. Checking if there may be a possible shorted part on that local power rail which will consume higher than normal current and force the local power rail to shut off.
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • bajdik
      Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
      by bajdik
      I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
      Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
      I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
      Unfortunately, I don’t have access to the schematic.
      It seems to me that when I bend the board, something changes.
      Could this...
      08-13-2025, 07:26 AM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • justice171
      Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
      by justice171
      I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
      Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
      1. Verified that all critical voltages are present:
        • 3.3V and 5V are always present if DC is plugged.
        • 1.8V on the BIOS chip is present.
      2. Checked the power button functionality:
        • When pressed, the voltage drops to 0V, indicating the button is functional.
      3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
        • Confirmed connectivity is intact, ruling out issues
      11-26-2024, 12:39 AM
