Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
  • lawrenceptrini
    • Mar 2023
    • 65
    • trinidad
    Hi Guys,
    I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
    The laptop is working fine with the adapter plugged in and also with a charged battery.
    Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
    ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
    loses its charge, it stays on 0%.
    Measurements taken
    Charging IC (ISL95522HRZ) 32 pins
    Voltage to ground with ac adapter only plugged in:
    1) 0.056
    2) 0.056
    3) 0.003
    4) 17.31
    5) 19.87
    6) 12.09
    7) 25.04
    8) 5.266
    9) 0.001
    10) 0.056
    11) 0.018
    12) 4.944
    13) 1.003
    14) 19.92
    15) 19.93
    16) 2.429
    17) 19.68
    18) 5.264
    19) 0.001
    20) 1.420
    21) 3.357
    22) 3.357
    23) 5.254
    24) 0.009
    25) 3.325
    26) 1.734
    27) 0.001
    28) 0.001
    29) 0.110
    30) 0.091
    31) 0.054
    32) 0.001
    DCIN CONNECTOR 6 pins
    1) 0.000
    2) 0.000
    3) 3.294
    4) 0.011
    5) 19.95
    6) 19.95
    BATTERY CONNECTOR 10 pins
    Voltage to ground with Battery only plugged in
    1) 0.000
    2) 0.000
    3) 0.000
    4) 0.000
    5) 0.000
    6) 0.000
    7) 0.000
    8) 10.71
    9) 10.71
    10) 10.71
    Voltage to ground with Battery AND Ac Adapter plugged in
    1) 0.000
    2) 0.000
    3) 0.000
    4) 0.000
    5) 0.000
    6) 3.324
    7) 3.324
    8) 10.71
    9) 11.17
    10) 11.17
    I have attached the schematic for the motherboard
    Any assistance will be appreciated.
    regards
    Link to schematic --> https://www.badcaps.net/forum/troubl...ed#post1859382
  • mon2
    • Dec 2019
    • 14259
    This means the PSID signal from the power adapter is not communicating with the EC chip using pin # 3 of the DC power connector.
    Make sure that the power adapter is a Dell original so that it will contain the 1-wire ID chip to identify the power adapter.
    Make sure the Dell power adapter is of the recommended power rating and is for use with this logic board.
    Confirm that the center pin inside the power connector of the power adapter is not bent or missing / broken. This is the needle like pin that must mate with your logic board and spit out the power adapter rating. In its absence, the BIOS will report what you see now.
    • lawrenceptrini
      • Mar 2023
      • 65
      • trinidad
      Thanks for your reply.
      The adapter's center pin in the tip is in good condition. Clean on the inside and straight. It's a 65w adapter
      and the rating is 19.5V - 3.34A. There's also the Dell logo on the back.
      • mon2
        • Dec 2019
        • 14259
        In general, the mosfet @ PQ1 and/or the series resistor @ PR1 become defective.
        Remove all power. Measure the resistance across PR1. Confirm this part is ~33R.
        Flux and remove PQ1. Bypass this over voltage crowbar mosfet by shorting pins 1-3. Download a datasheet for this mosfet to review the locations for pins 1 & 3 on this SOT-23 package.
        Test again. If still not working, then the EC firmware may be at fault. It is the EC that is the bus master here who pulses this PS_ID line to send out commands to the adapter's ID 1-wire IC. Then the adapter's 1-wire IC will respond back to identify itself to the host and the details are posted inside of your BIOS.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          In case of fault with PSID it will show as adapter "Unknown". However,the OP is saying adapter "Not Installed". So PSID is unlikely to be at fault here.
          What is the gate voltage of the 2 dc-in fets?
          Pin24 ACOK is not correct and this is the reason for adapter not installed.
          • lawrenceptrini
            • Mar 2023
            • 65
            • trinidad
            mon2 thanks for the feedback
            I measured PR1 resistor in (ohms mode) the reading is varying getting 35 to 37 ohms each time I measure.....
            • lawrenceptrini
              • Mar 2023
              • 65
              • trinidad
              mcplslg123 thank you for responding
              My apologies, I made a typo with the reading of ACOK. The reading is 3.077v with adapter only, voltage to ground.
              I re-took all the measurements of the IC.
              The Gate voltage of DCIN Mosfets are: PQB11 - 25.04V and PQB12 - 25.03V
              • mon2
                • Dec 2019
                • 14259
                This is ok. As per suggestion by mcplslg123, ACOK is logic low and it should be a logic '1' = High if the power adapter is considered to be OK.
                Review PU301, confirm if you have +3VALWP at inductor PL301. What is the voltage to ground here?
                If the voltage is absent, check if the enable signals are present on pins 11 and 12 on PU301.
                If the enable signals are present but you still do not have the +3VALWP, then remove all power. Meter in resistance mode. Measure the resistance to ground on PL301. We are checking if there is a shorted part on this rail and causing this regulator to wimp out and shut down.
                -- just saw your last post. Then ACOK is OK
                What does the bios report again with this adapter?
                • lawrenceptrini
                  • Mar 2023
                  • 65
                  • trinidad
                  Thanks, The voltage to ground for coil PL301 3.3v on both sides. Yes ACOK is 3v.
                  The Bios reports that the AC Adapter is not installed.
                  • lawrenceptrini
                    • Mar 2023
                    • 65
                    • trinidad
                    mon2 The battery is showing up as Primary - 0% - Idle..in the Bios
                    • mon2
                      • Dec 2019
                      • 14259
                      Measure the voltage to ground of the H_PROCHOT# signal. You can measure this signal @ PQ12B - measure the voltage to ground on each pin:
                      gate
                      source
                      drain
                      Also, can you confirm the SMBUS pins on the battery connector?
                      6) 0.000
                      7) 0.000​
                      There should be a voltage on these 2 pins as long as the battery has a charge. Same voltage should be present if operating with only the power adapter. Confirm it.
                      • lawrenceptrini
                        • Mar 2023
                        • 65
                        • trinidad
                        Hi Thanks,
                        PQ12B seems a 6 pin dual Mosfet on the motherboard.....shows up as two distinct Mosfet on schematic.
                        I measured voltage to ground as requested: pin 3= 1.009v, pin 4= 0.000v, pin 5=0.000v
                        Battery Connector SMBUS voltages: pin 6= 3.3, pin 7= 3.3 with adapter only. These pins gives 0v each with battery only connected.
                        • mon2
                          • Dec 2019
                          • 14259
                          Does your battery have any charge left? Measure the battery voltage to ground at pins 8-9-10 on the battery connector. The first post shows the battery has some voltage (~10 volts).
                          Provided that you have a charge on the battery and the power adapter is disconnected, then the battery mosfet @ PQB13 will enable to power the logic board.
                          Confirm the voltage to ground on each pin of the battery mosfet @ PQB13.
                          Source
                          Gate
                          Drain
                          • lawrenceptrini
                            • Mar 2023
                            • 65
                            • trinidad
                            Voltage on each of pins 8, 9 and 10 of battery connector measures 10.71v without ac adapter plugged in.
                            Voltages on mosfet PQB13 is as follows: Source= 10.71v, Gate= 10.12v and Drain= 10.23v with battery only plugged in.
                            • mon2
                              • Dec 2019
                              • 14259
                              Not at my desk but this mosfet may be defective. Remove all power and check the resistance across the mosfet pins.
                              source & drain
                              source & gate
                              gate & drain
                              Check type of mosfet here. If n-channel type then gate should be higher voltage than source and drain to enable. The internal diode may be passing through the voltage but check the other factors.
                              The battery voltage should create the voltage for the smbus pull-ups.
                              PQ12B may be in trouble..will check when back to the desk.
                              • lawrenceptrini
                                • Mar 2023
                                • 65
                                • trinidad
                                mon2 Ok thanks,
                                will perform the tasks as requested.....
                                • mon2
                                  • Dec 2019
                                  • 14259
                                  H_PROCHOT# is ok due to the pull-up resistor is @ 1v05.
                                  This implies that the driving mosfet is OFF so this mosfet is open and the pull-up resistor is pulling the line to ~1v05 as in your case.
                                  • lawrenceptrini
                                    • Mar 2023
                                    • 65
                                    • trinidad
                                    Resistance across on mosfet PQB13 is as follows: Source & Drain =1.2m ohm, Source & Gate= 3.1m ohm, Gate to Drain=5.9m ohm.
                                    PQB13 is an N-Channel Mosfet
                                    • mon2
                                      • Dec 2019
                                      • 14259
                                      Check if you have +3VALW_EC voltage using only the battery.
                                      • lawrenceptrini
                                        • Mar 2023
                                        • 65
                                        • trinidad
                                        Where is best to take +3VALW_EC​ reading? I took the measurement on pins 8 and 9 of EC chip (MEC1416).
                                        It reads 0.000 for pins 8 & 9 with battery only plugged in.
                                          DELL Inspiron 3593 Notebook 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3593 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3593 boardview and 3593 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3593...
                                          09-06-2024, 08:40 PM
