Lenovo IdeaPad Slim 5 16IAH8 no power
  • yobbgsm
    • May 2017
    • 63
    I have a repair, a Lenovo IdeaPad Slim 5 16IAH8 laptop. It's seems a 1 year old only. No display, no post, only blinking power led. I opened and investigate and found this burnt IC, but I cannot see the details properly and or the label of the IC.
    Can you help me recognize this so I buy?
    Thank you. See attached.Click image for larger version
  • yobbgsm
    • May 2017
    • 63
    Anyone?
    • mon2
      • Dec 2019
      • 14120
      Post more pics of this logic board. The part is 100% from Richtek but the critical first 2 characters are not legible in the shared pic. The same part may be common to other Lenovo models.
      On the logic board will be white silk screened markings. Post those as well.
      • yobbgsm
        • May 2017
        • 63
        Sure, mon2. Please see attached.
        • mon2
          • Dec 2019
          • 14120
          Your board number is 'LA-M652P'. Search out pics of this board to locate this mystery component.
          From your original post, we know 100% the part is from Richtek and can make out that the first character is a 'P'.
          Once you know the 2nd character, you can solve this mystery. The Richtek part is 'Px=' but we do not know yet what value of x.
          Pour IPA (alcohol) onto this part and apply your phone torch light to best guess the 2nd character and post a fresh pic or guess.
          • yobbgsm
            • May 2017
            • 63
            Thanks mon2, I can't still find the label of this IC. Maybe because this is new model?
            • yobbgsm
              • May 2017
              • 63
              I finally found it. It is PF = 9G 45C. Thanks
              • Ololoev1996
                • Nov 2022
                • Ukraine
                It's not "pf=", it's "ml="
                • acata
                  Lenovo Ideapad slim 3 not power on
                  by acata
                  Lenovo Ideapad slim 3 not power on after consumer problems is can not on after sleep mode.
                  And the consumer asked for reinstalling OS.
                  I reinstalled windows 10 and working fine. After i leave it for updating windows and goes to sleep mode. Now it cant draw any input from power supply.
                  Motherboard number is GS450&GS550&GS750 MM-C821 REV: 1.0
                  Check the main power rail for 20v input ok
                  No amper input from Power supply 0.013a
                  Mosfet PQ201 20v and 26v ok.
                  3.3v exist
                  1,8v exist
                  5v exist
                  12v from baterai exist....
                  09-30-2024, 09:42 PM
                • SoulFreeze
                  Lenovo Slim Pro 7 14ARP8 83AX No Power
                  by SoulFreeze
                  Hello All, I have a Lenovo Slim Pro 7 14ARP8 83AX, Board No NB6369A_MB_V5
                  Behavior - Pressing power button results in three second led blinks on the button,
                  Connecting charger lights up orange as normally would while charging.
                  Connecting charger without battery blinks orange.
                  No fanspin.
                  Tried flashing bios, no change.
                  I inspected the board and found a burnt component on the USB / Power button daughter board. I assume the comonent was an esd protection diode as it was on the USB A port power rails. removed the component but still exhibits...
                  05-01-2025, 09:04 PM
                • Dr.d
                  Help please..Lenovo ideapad 5 14itl05 power and charging problem
                  by Dr.d
                  I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                  Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                  04-05-2024, 11:48 AM
                • rabsonnjala
                  LENOVO IDEAPAD 100 works only on bench power supply
                  by rabsonnjala
                  Hie I have a Lenovo laptop
                  Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                  it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                  below are my readings
                  with the original charger only
                  JBATT1
                  PIN1 0.22V
                  PIN2 0.22V
                  PIN3 0.45V
                  PIN4 0.45V
                  PIN5 O.43V
                  PIN6 0V
                  PIN7 GND
                  PIN8...
                  11-20-2021, 08:32 AM
