Dell Vostro LA-L245P Charging not working
  • radoslav baca
    • May 2024
    • 24
    • Slovakia
    Description : Dell
    Model : Vostro
    Serial Number :
    Product Number :
    CN :
    MFD:
    Hard disk : NVMe 256GB
    CPU: AMD Ryzen YM3250C4T20FG
    RAM : DDR4 8GB
    MB : GDM54 LA-L245P Rev : 1.0(A00) 2021-07-26
    I don't have any other data because there is no data label on the laptop.
    I have a problem with my laptop that when I connect the charger, the charging indicator lights up and goes out after 4 seconds. Windows reports charging but does not charge the battery. Can anyone help me with this? I also looked for older threads with this board but couldn't find anything.
  • mon2
    • Dec 2019
    • 13830
    Carefully measure the voltage to ground of each pin on the adapter connector. The fault may be due to the PSID pin (PL3) which is used by Dell to gauge the power of the external adapter. If this signal is absent, then the charging will halt.
    Click image for larger version  Name:	PSID.png Views:	0 Size:	96.2 KB ID:	3333127
    • radoslav baca
      • May 2024
      • 24
      • Slovakia
      I checked the 3 pin and did not measure any voltage on it
      • naze60
        • Jun 2023
        • 3
        • iran
        in bios menu show adaptor wattage. example 65w 90w
        If it says (unknown), the battery will not be charged
        • radoslav baca
          • May 2024
          • 24
          • Slovakia
          In Bios, it says 65W if I have an adapter connected. If I disconnect it, the 65 W disappears. Even if the charging light goes out, the adapter shows 65 W in the BIOS
          • naze60
            • Jun 2023
            • 3
            • iran
            So it has nothing to do with the charger
            Only the battery remains
            Battery replacement​
            • radoslav baca
              • May 2024
              • 24
              • Slovakia
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Dont agree completely with post#6. Battery wont charge if charging circuit has issues even if psid is correct. So battery replacement may/may not solve the problem.
                If you have a spare battery,try it.Else needs some measurements on charging IC to be sure its not charging circuit.
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  Always a good idea to try a replacement battery before messing with the mainboard though. A battery is a consumable and it is much more likely to be the problem than the mainboard.
                  When you are experienced enough you know what to look for and can make an educated guess if it's gonna be a battery or a board problem. When you are not experienced you are more likely to cause more damage by randomly probing and messing around.
                  That said if the battery is not empty yet and the machine works off of the battery without the AC adapter, but does not charge it when the AC adapter is connected, there's a much higher chance for it to be a mainboard problem.
                  • radoslav baca
                    • May 2024
                    • 24
                    • Slovakia
                    Unfortunately, the battery is dead, but I can measure circuits if I have documents on what and where to measure
                    • mon2
                      • Dec 2019
                      • 13830
                      What are the markings on the power adapter? Is it a 60W unit?
                      Remove all power. Meter in DIODE mode. Red meter probe to ground - yes red probe. Black probe on the PL3 / pin 3 of the power connector (as above). Do not attach the power adapter. Do not attach the battery. We are only checking if this PSID line is shorted due to an ESD or another event. The diode mode measurement will confirm the condition of this signal.
                      Post the diode mode measurement.
                      • radoslav baca
                        • May 2024
                        • 24
                        • Slovakia
                        I measured according to your instructions, red pin to ground and black to PL3, and after connecting the charging connector, the state on the measurement in diode mode did not change and showed infinity
                        • mon2
                          • Dec 2019
                          • 13830
                          Remove all power. Review the DCin mosfets (see attached).
                          Meter in resistance mode.
                          Measure the resistance across each of these mosfets:
                          source (1-2-3) & drain (5-6-7-8)
                          source (1-2-3) & gate (4)
                          gate (4) & drain (5-6-7-8)
                          Post each measurement. Review the above sticky by piernov on charger circuits.
                          • radoslav baca
                            • May 2024
                            • 24
                            • Slovakia
                            Click image for larger version  Name:	dcin_mosfets.png Views:	0 Size:	217.0 KB ID:	3469117
                            I measured things as you wrote them and here are the results:
                            PQB 11 source (1-2-3) & drain (5-6-7-8) 503k Ohm
                            source (1-2-3) & drain (4) 538k Ohm
                            gate (4) & drain (5-6-7-8) 0L
                            PQB 12 source (1-2-3) & drain (5-6-7-8) 484k Ohm
                            It's just that my laptop works on the battery, but the charging diode lights up and after a few seconds it goes off, and Windows also says that it's charging the battery, but it shows the battery as almost empty.​
                            • mon2
                              • Dec 2019
                              • 13830
                              Attach the power adapter and carefully measure the voltage to ground on each pin of the same Dc-in mosfets.
                              Measure the voltage to ground of:
                              source (1-2-3)
                              gate (4)
                              drain (5-6-7-8)
                              of each mosfet. Post each measurement. A full list of the voltages of each pin on the charger IC will also be helpful but start with the mosfets. Be sure your meter probe is sharp enough to probe each pin on the charger IC without shorting as the charger IC is live.
                              • rogfanther
                                • Jul 2006
                                • 458
                                • Brazil
                                In BIOS, can you see the serial number or Service Tag of your notebook ? With that it is possible to look on Dell´s site what is the correct model, and also what would be the correct PSU. Do you have some memory of the machine ever present some message on boot about the power supply / charger ?
                                • radoslav baca
                                  • May 2024
                                  • 24
                                  • Slovakia
                                  source (1-2-3)
                                  gate (4)
                                  drain (5-6-7-8)
                                  I just measured each leg separately and here are the measurements:
                                  PQB11:
                                  S1 - 19,79 S2 - 19,79 S3 - 19,79
                                  G - 24,97
                                  D5 - 19,79 D6 - 19,79 D7 - 19,79 D8 - 19,79
                                  PQB12:
                                  G - 24,97
                                  • radoslav baca
                                    • May 2024
                                    • 24
                                    • Slovakia
                                    The charger is an original DELL 65W, which is also shown in the BIOS when I checked it. Windows also shows charging, but the indicator does not go up and also the LED diode, which indicates charging from the side, lights up after connecting the charging and goes out after a short time.
                                    • Thomasraud
                                      Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                      by Thomasraud
                                      i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                      QUOTED
                                      -It works on charger (without battery connected-only charger)
                                      -It works on battery (without charger connected-only battery)
                                      -& it also works when plugged in battery & charger, but it's not charging the battery
                                      //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                      and..
                                      QUOTE
                                      The IC cannot maintain the input current level
                                      06-28-2022, 06:47 PM
                                    • Bowline
                                      by Bowline
                                      06-11-2025, 10:13 AM
                                      DELL Vostro 3671 Vostro 3600 i5-9400 Specification for Upgrade or Repair
                                      This specification for the DELL Vostro 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3671 boardview and Vostro 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                      09-12-2024, 03:44 PM
                                      DELL Vostro 3470 Vostro 3400 i3-8100 Specification for Upgrade or Repair
                                      This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                      DELL Vostro 3470 Vostro 3400 i5-9400 Specification for Upgrade or Repair
