16IAH7H minor liquid damage around GPU buck. boardiew and schematic included.
  • GGEZ
    • Nov 2020
    • 7
    • Scandinavia
    Hi. I have a lenovo 16IAH7H (NM-E231) with a small amount of water spilled on the RT8816CGQWGPU buck converter. When powering on, keyboard lights up, fans will spin slowly. CPU and GPU are getting hot. No image. Not via HDMI either.
    Part number is PU4001. The liquid spillage looked minor so I cleaned it up with some alcohol and cleaned ups some crusty joints with solder and flux.
    BoardView and schematic is provided. The buck converter diagram is on PAGE 107.
    I'm inquiring about any troubleshooting tips like probe points to measure and such. I can access a hot air station and micro soldering tools if necessary. Any tips and suggestions would be greatly appreciated. thanks.
    [MOD EDIT] Link to schematic/boardview
    https://www.badcaps.net/forum/troubl...15#post1719615
    Click image for larger version  Name:	water damaged area.png Views:	0 Size:	3.26 MB ID:	3332665
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Are you getting output on coil from PU4001?
    • GGEZ
      • Nov 2020
      • 7
      • Scandinavia
      Hi.Thank you for the reply.
      Yes im getting .75v from coils. and 1.25V on VRAM
      Im only getting voltage on one side of the coils. is that normal?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        You must be measuring the coil with multimeter and its normal not to see anything on the other side. With DSO you should get a voltage on one side and pwm pulses on another side.
        Just make sure both ends of the coil is beeping when measured in diode mode with multimeter.
        • GGEZ
          • Nov 2020
          • 7
          • Scandinavia
          Multimeter is beeping on both sides. Interesting that voltage can only be measured on one side. Learning something every day!
          Resistance to GND on all coils are just 0.3-/.4 OHMS.
          • GGEZ
            • Nov 2020
            • 7
            • Scandinavia
            I have seen some videos from "Laptop Repair School" on YouTube that the CPU intel Intergrated graphics will boot before the big GPU takes over. So technically i should have a boot screen and since I'm not even getting an image at post, I'm starting to think that this could possibly some other issue than GPU. Maybe BIOS? Is it possible to probe for a "ALL_SYS_PWRGOOD" type of signal I could do for Lenovo laptops?
            • bogosort
              Asus FX505GT, voltage reading after minor liquid damage
              by bogosort
              TLDR:
              Are these voltage readings normal? What should I do next?
              Long story:
              I have an Asus FX505GT laptop that received a small amount of liquid.
              Since then, installing the Intel GPU drivers causes a black screen, then an infinite Windows loading until I uninstall the driver using safe mode.
              The laptop still works when using the default Microsoft display driver, but the video memory shows as unknown in hwinfo.
              Installing the GTX 1650 max-q drivers works, but there does not seem to be any acceleration....
              12-07-2022, 02:54 PM
            • mon2
              A1466 Macbook Air (Liquid damage repair)
              by mon2
              Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
              Macbook AIR Model A1466 Diagnostic 09-01-2021
              Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
              Problems & Resolutions
              1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
              09-01-2021, 09:31 AM
            • rilley
              MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
              by rilley
              I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
              I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
              My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
              And the resistor L4004 is literally burned.
              From what I see from the schematics, it does not affect any other rails, only the connection to the display...
              07-10-2024, 01:57 AM
            • Jenzo
              MacBook A1989 overheating after liquid damage
              by Jenzo
              Hey everyone,
              Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
              I can't figure out how...
              05-13-2023, 07:58 AM
            • mitchw
              MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
              by mitchw
              Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
              It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
              I quickly took it apart and washed the liquid residue off the mainboard.
              The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
              The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
              Now the laptop...
              07-16-2025, 07:55 AM
