Dell inspiron mini 10 battery not charging
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 343
    • India
    Any one please i need bios for dell inspiron mini 10 . problem is set boots ok problem only battery not charging. if testing with new or charged battery set is on battery power only .
    -If left for charging led changes color white orange white orange......goes on every 3sec. changing color
    -i need bios because it is writen in many web to down grade bios .
    -i need old version bios A03.presentlyrunning on A06
    -while switching on message shows unidentified battery press F1 to continue.
    -if using charged battery this above message dosent come directly boots to windows.
    Thankyou
  • sorinac
    • Jul 2013
    • 123
    • Romania
    Re: Dell inspiron mini 10 battery not charging
    have you searched on www.dell.com ??
    here you go
    http://www.dell.com/support/drivers/...eId=2731109007
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 343
      • India
      yes i have seen there but for flashing they need laptop charged condition ,i have tryed while flashing charger not found mesage is coming so unable to flash
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • lawrenceptrini
        Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
        by lawrenceptrini
        Hi Guys,
        I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
        The laptop is working fine with the adapter plugged in and also with a charged battery.
        Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
        ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
        loses its charge, it stays on 0%.
        Measurements taken
        Charging IC (ISL95522HRZ) 32 pins
        Voltage to ground with ac adapter only plugged in:
        1)...
        08-26-2024, 06:45 PM
      • shatteredhalo
        Dell Inspiron 15 5559 AAL15 LA-D071P battery not charging
        by shatteredhalo
        I'm troubleshooting an issue with a laptop where it doesn't seem to want to charge the battery. The laptop will run off the battery alone and use/drain the battery normally in this situation, it will run off the AC adapter alone, and it will run with both charger and battery connected, but it doesn't seem to charge the battery under any circumstance.
        At startup of the laptop, the following error message is displayed by Dell SupportAssist: "Alert! The AC power adapter wattage and type cannot be determined. The battery may not charge. The system will adjust...
        08-20-2020, 09:45 PM
      • danielsak
        Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
        by danielsak
        Hello, I have issue with Dell Inspiron 3542.
        Motherboard marking:
        Code:
        PWB FX3MC REV: A00
        The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
        1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
        1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
        10-11-2024, 04:36 PM
      • ipatch
        dell inspiron 5567 laptop battery lipo WDX0R
        by ipatch
        recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
        1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
        2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
        got the computer...
        04-02-2023, 04:45 PM
