HP G62-b10sg does not charge, works with battery
  • mtherana
    • 117
    • South Africa
    Re: HP G62-b10sg does not charge, works with battery
    Hello Guys
    I have almost Similar issue here ...
    this G62 laptop had a blinking power button when you switch on. after sometime of reading posts on this forum i have decided to do some check-up.now the laptop works on battery but only after i removed PQ808 (ac_off) but it does not charge the battery or power on with Charger. it only with-draws about 0.56-1.11A from the power supply. if I replace PQ808 it still blinks and does not switch on. please help...
    • dycc
      Vision
      • Nov 2011
      • 625
      • Côte d'Ivoire
      pq808 is just there to switch off the lappy.
      1 check pq800 Gate voltage ( 19x240)/(240+240)=9,5V
      2 check pu800 pin 22 (dcinpmos=19V)
      3 check m31aacin pin 2 pu800 ( 19x33)/(200+33)=2,69V
      4 check m31aacok pin 13 pu800 or gate pin of pq807 (must be 3,3V)
      5 check pq801 gate pin DCINPMOS_Q=( 19x10)/(100+10)=1,7V
      • mtherana
        • 117
        • South Africa
        Hello dycc
        I would like to thank you for the reply"
        I have done the measurements and here are the outcomes:
        PU800 PIN 2 =2.2V
        PU800 PIN 22= 19.9
        PU800 PIN 13 = 0.0v (M31AACOK)
        please help me with the clue on what the next step is.
        • Choppies007
          • Aug 2014
          • 3
          • South-Africa
          maybe it can be that the chip that lets your battery charge has got a problem so i know the battery charges but may be look into where it should switch between normal ac and battery power on the mb if that makes sense lol
          • mtherana
            • 117
            • South Africa
            Thanks choppies
            I have already replaced the Battery charging chip PU800(Maxim 8731AE).
            • mtherana
              • 117
              • South Africa
              #26
              can someone please help ...what steps do i take further to fix the ACOK issue on this G62. AC seem not to be detected but 19v is there and found on the board as well as 3.3v and 5v but it doesnt switch on with Charger only with battery, and ACOK Pin on PU800 or gate of PQ807 is 0.0v
              please Help me out...
              • dycc
                Vision
                • Nov 2011
                • 625
                • Côte d'Ivoire
                #27
                check ACOK line to ground if there is no short
                • mtherana
                  • 117
                  • South Africa
                  #28
                  thank you dycc
                  will check it today...
                  • dycc
                    Vision
                    • Nov 2011
                    • 625
                    • Côte d'Ivoire
                    #29
                    1 remove pq807 and check if you got acok voltage .
                    2 if yes replace pq800 and pq801 (one of them might have low impedance)
                    3 put back pq807 and check again
                    • mesersmith
                      • 35
                      • România
                      #30
                      I have 3 laptops G62, and all of them have the same problem.
                      All of them works great only with one charger. They works great only with HP 19v, 4.7A charger.
                      I tried with HP 19v, 3.2A, Dell and Compaq chargers with 19v, 4.7A, but the power led just starts blinking. This all chargers is the same and for exemple, one Dell laptops works great with all this chargers.
                      Is this G62 so strict about what charger is ok for it?
                      Is anyone who knows what is happening?
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4953
                        • New Zealand
                        #31
                        Probably those others chargers don't send the right charger ID data or voltage.
                        -David VanHorn
                        • Am0rPHiA
                          • Nov 2011
                          • 31
                          • Greece
                          #32
                          Hello all,
                          i also have a HP G62-b10sv which powers on only with battery and if i plug in the charger
                          and remove the battery then it keeps running, but it will not power on only with AC.
                          The motherboard part number is 597673-001 and i am referring that because the MAXIM
                          chip on this board is PU5 and not PU800 unless i am reading something wrong.
                          I have already replaced maxim 8731 but that did not solve the problem, any
                          suggestions where to look and measure ? 19v,5v and 3.3v appear to be present on the
                          board.
                          thanks in advance for your help
                          • Malvkane
                            • Feb 2021
                            • Porto
                            #33
                            Hello i have the same problem!! Is ther a bypass from the maxim ic charger? Or can i conect the 19v to the batery line to power up the laptop with the charger? Hellp please
                            • razenxd
                              How can I charge that battery pack?
                              by razenxd
                              it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                              At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                              Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                              Now, I have noticed a few things.
                              The "dead" battery, while connected to charger and NOT Charging will...
                              12-05-2024, 06:11 AM
                            • Klevjetack
                              Charge a L19D3PDA battery externally from the laptop
                              by Klevjetack
                              Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                              03-05-2024, 07:26 AM
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • gadgettree
                              Acer Nitro AN517-52 FH51M LA-J871P Works on battery only. Won't charge.
                              by gadgettree
                              Hi there,
                              I am having trouble diagnosing this gaming laptop.
                              The laptop does not power on with AC Power only. The battery also does not charge. The laptop turns on when the battery is plugged in, regardless of whether or not the charger is plugged in until the battery dies of course.
                              So something is stopping adapter power from getting to the laptop. I checked Adapdet to make sure that the motherboard knows when the adapter is plugged in. That works fine.
                              I suspect the first Mosfet isn't turning on but I am unsure how to properly diagnose that...
                              02-28-2024, 05:27 PM
                            • bin_
                              XPS 15 9570 will not charge but battery works
                              by bin_
                              XPS 15 9570 will run from battery but will not charge/run from USB-C or the DC jack. The charging light does not come on, even though it normally does when power is connected (regardless of whether or not a battery is in the machine). So it seems like something is wrong power wise. Battery is dead so it currently won't boot. Machine specs:
                              Dell XPS 15 9570
                              Intel Core i9-8950HK
                              Tried 32GB DDR4 2666 and 8GB DDR4 2400 RAM
                              Motherboard is a Compal LA-G341P
                              I've tried removing the battery, CMOS battery, RAM, trackpad, keyboard,...
                              12-24-2021, 03:49 PM
