HP 17-cn1007cy BIOS replacement, now storage devices not detected.
  • JJA
    • Jun 2015
    • 6
    I have a HP 17-cn1007cy laptop that had an unknown bios password. I ordered a replacement bios from eBay and used a rework station to remove the old bios and install the new.
    The new BIOS fixed the password problem and the system does boot, but now the laptop will not recognize the SSD at all, in bios or otherwise. I tried installing a cable for the HDD option on the mobo and the bios recognized it, but Windows installation media for both 10 and 11 fail to recognize it to perform an OS install. The system is able to boot to USB media with no issue.
    Any ideas on what I did wrong, and how I might fix it or find someone to fix it for me if that's beyond my ability? Any advice will be much appreciated!
    Specs:
    1. Laptop model: 17-CN1007CY
    2. Motherboard: 17N-8L-TGL with i5 processor
    3. https://support.hp.com/us-en/product...43?sku=552Y0UA
    ​-Jay
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    The bios you got from ebay may not be the exact match for your motherboard. In HP there are 3-4 bios with different "BID" numbers for a particular model-so there may be mismatch.
    Try updating the bios from HP website.
    Check legacy/uefi settings in bios.
    • JJA
      • Jun 2015
      • 6
      I already checked and updated the bios to the latest version, using the unit's serial number on HP's site. Switching between secure boot enabled or disabled (no option directly called 'legacy') doesn't affect it.
        • 21679
        Do you still have the old bios chip
        • JJA
          • Jun 2015
          • 6
          I just looked and can't locate it, it might have been lost.
          • JJA
            • Jun 2015
            • 6
            Might there be a schematic or high-rez pictures available for the motherboard (17N-8L-TGL), perhaps?
              • 21679
              Search the forum it might have been posted,and if not you can make a new thread with your request --> https://www.badcaps.net/forum/troubl...-requests-only
              If you want to try another bios post your backup in the "Bios requests ONLY!" sub forum - https://www.badcaps.net/forum/troubl...-requests-only .You will need an SPI programmer to make the backup
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
                by Vesko356
                08-11-2023, 03:27 AM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • lucaszmn
                by lucaszmn
                Problem:
                Initial Findings:
                • I concluded that the
                08-12-2025, 03:01 PM
              • titomno2
                Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
                by titomno2
                Hi guys,
                On motherboard ACER AN515-52 type LAF951P.
                I fixed issue with not starting computer (it was the PQ201 component not working properly).
                But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
                Basically some HDD spin but are not detected by the bios.
                Already tried following:
                checked the 4 data lines
                #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
                #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
                07-28-2024, 08:30 AM
