MECER GURU YA13Q40-LTE_PRO_S
  • Intelliware
    • Dec 2022
    • South Africa
    Hello everyone can anyone assist with advice MECER GURU YA13Q40-LTE_PRO_S with no sound after installing fresh windows 10 have tried installing drivers not sure whats wrong /can anyone assist with working drivers also
    • 22264
    Originally posted by Intelliware
    HELLO EVERYONE CAN ANYONE ASSIST WITH ADVICE MECER GURU YA13Q40-LTE_PRO_S WITH NO SOUND AFTER INSTALLING FRESH WINDOWS 10 HAVE TRIED INSTALLING DRIVERS NOT SURE WHATS WRONG /CAN ANYONE ASSIST WITH WORKING DRIVERS ALSO
    Can you post in lower case and not UPPER CASE, ITS ANNOYING.
    Drivers - http://downloadcenter.mustek.co.za/N...k/YA13Q40-LTE/
    • Intelliware
      • Dec 2022
      • South Africa
      Apologies. I've installed the drivers, sound still not working, its saying No Audio Output Device is installed
        • 22264
        Have you installed all of the drivers and not just the audio driver.
        • pavithra
          LC6685 based LED drivers
          by pavithra
          I have 50 Chinese constant current isolated LED drivers based on LC6685 IC. 35 drivers are working fine, but there is a slight flickering in the rest of the drivers.
          I have checked the output with oscilloscope and found that there is a slight random voltage fluctuation.
          Is it possible to get the datasheet of LC6685 IC?
          Also highly appreciate if you could let me know what could go wrong....
          04-16-2024, 02:46 AM
        • m3g4tr0n
          Dell Inspiron 5567 Black Screen after installing Drivers
          by m3g4tr0n
          Dell Inspiron 15 5000 (5567)
          when installing the intel hd 620 graphics drivers the laptop screen goes black. if i restart or shutdown it's the same thing, it will show the win10 spinning dots and then it goes black again. if i connect a monitor to the hdmi port i can see the screen.
          if i load in safe mode or disable the intel hd 620 graphics adapter, i can see the screen on the laptop but theres no 3d acceleration.
          tried os reinstall, latest bios, latest hd 620 drivers (from dell and intel), reset bios, taking off the cmos battery.
          anything...
          07-07-2019, 12:04 PM
        • kuba2102
          Alienware m15 R4 CPU or CPU drivers issue
          by kuba2102
          Hi. I had a problem with this laptop that under a load it would crash the system, meaning the screen would go black and unresponsive. I have noticed that CPU drivers surrounding area of PCB has changed colour due to high temperature. I have tried to reball the Drivers, but after it laptop wouldn't turn on at all and it would trigger over current protection in the PSU. I ordered and replaced 3 of of 5 Drivers (3 CPU, 2 IGPU?), and it started producing 1.2V again but just for a second. I get led flashing out the CPU failure code. Now I'm not sure whether there is still a problem with the drivers...
          01-04-2023, 09:05 AM
        • kotel studios
          Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
          by kotel studios
          Finally got time to fix this board up.
          At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
          Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
          04-22-2025, 05:08 AM
        • japlytic
          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
          by japlytic
          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
          Tried (only with keyboard/mouse connected):
          • BIOS + database update
          • Using latest Windows 11 image built with official image creation tool
          • Previous setup version for Windows 11 installer
          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
          06-19-2025, 04:59 PM
