HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
  • Archimedes
    • Jul 2024
    • 10
    • Turkey
    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
    Fans are spinning. Blindly could install windows11 and got the device manager by print screen+mspaint and also got some error log files by pnputil all blindly (I will post them here). In device manager there is no line about the dedicated GPU AMD HD7850M, six device drivers showing couldn't be installed. My dedicated GPU is a PCIe device but “PCI Simple Communications Controller not installed” cannot detect the GPU. There is no other GPU in this motherboard to test more. One more trouble, after each booting file corruption happening in the boot drive SSD. Needed to repair the SSD in another computer and move it back again.
    I replaced a new bios with the same .bin data. (I tested with old bios again, no change in the result). I took the motherboard to a professional they replaced HM76 chipset chip, AMD HD7850M GPU chip and 4 Graphic Ram chips with the brand new one. Also they transferred few other components from my first old motherboard which I can point out which ones are they.
    Still no graphics output. Only difference motherboard heat increased and this time heat coming from every part.
    I have no battery, I am using the power adapter only.
    I measured the voltages on the pads of the motherboard:
    Back side: all the pads show 19.3V (PAD# 6210,6753,6310,6600,6601,6700,6015,6110 which all voltages matching with schematics.)
    Front side (component side): PAD#:
    6121…3.35V
    6135…3.34V
    6100…3.37V
    6150…5.10V
    6970…1.84V
    6200…1.52V
    6201…1.52V
    6220…1.52V
    2013…5.09V
    6940…1.06V
    6950…0.96V
    6510…5.10V
    All these look like in normal range but;
    PAD6300 and PAD6301 show 1.06V (must be in the 1.5V range?)
    PAD 6750 and PAD6751 show 0.90V (I couldn't find how much V is the normal?)
    What to check more, what to diagnose,
    (I don't have an IR camera for heat detect)
    Thank you.
  • Archimedes
    • Jul 2024
    • 10
    • Turkey
    Additional information about the blank screen issue.
    The HP power adapter smart pin voltage is 18.5V when not connected. When connected, it measures 1.08V regardless of power on or off.
    Another info about the blank screen issue.
    The problem devices list created by Windows11 :
    Microsoft PnP Utility
    Instance ID: ACPI\SYN1E67\4&30193793&0
    Device Description: PS/2 Compatible Mouse
    Class Name: Mouse
    Class GUID: {4d36e96f-e325-11ce-bfc1-08002be10318}
    Manufacturer Name: Microsoft
    Status: Problem
    Problem Code: 24 (0x18) [CM_PROB_DEVICE_NOT_THERE]
    Driver Name: msmouse.inf
    Hardware IDs: ACPI\VEN_SYN&DEV_1E67
    ACPI\SYN1E67
    *SYN1E67
    Compatible IDs: *SYN1E00
    *SYN0002
    *PNP0F13
    Instance ID: ACPI\HPQ0004\3&11583659&0
    Device Description: Unknown
    Class Name: Unknown
    Class GUID: Unknown
    Manufacturer Name: Unknown
    Status: Problem
    Problem Code: 28 (0x1C) [CM_PROB_FAILED_INSTALL]
    Problem Status: 0xC0000490
    Hardware IDs: ACPI\VEN_HPQ&DEV_0004
    ACPI\HPQ0004
    *HPQ0004
    Instance ID: USB\VID_8087&PID_07DA\6&3a62018b&0&1
    Class Name: Unknown
    Class GUID: Unknown
    Status: Problem
    Hardware IDs: USB\VID_8087&PID_07DA&REV_7869
    Compatible IDs: USB\COMPAT_VID_8087&Class_E0&SubClass_01&Prot_01
    USB\Class_E0&SubClass_01&Prot_01
    USB\Class_E0
    Instance ID: ACPI\HPQ6001\2&daba3ff&0
    Class Name: Unknown
    Class GUID: Unknown
    Status: Problem
    Hardware IDs: ACPI\VEN_HPQ&DEV_6001
    ACPI\HPQ6001
    *HPQ6001
    Instance ID: PCI\VEN_8086&DEV_1E3A&SUBSYS_1852103C&REV_04\3&11583659&0&B0
    Device Description: PCI Simple Communications Controller
    Class Name: Unknown
    Class GUID: Unknown
    Status: Problem
    Hardware IDs: PCI\VEN_8086&DEV_1E3A&SUBSYS_1852103C&REV_04
    PCI\VEN_8086&DEV_1E3A&CC_078000
    Compatible IDs: PCI\VEN_8086&DEV_1E3A&REV_04
    PCI\VEN_8086&CC_078000
    PCI\VEN_8086
    PCI\CC_078000
    PCI\CC_0780
    Instance ID: ACPI\INT33A0\0
    Class Name: Unknown
    Class GUID: Unknown
    Status: Problem
    Hardware IDs: ACPI\VEN_INT&DEV_33A0
    ACPI\INT33A0
    *INT33A0
    Instance ID: PCI\VEN_10EC&DEV_5229&SUBSYS_1852103C&REV_01\4&10b3103b&0&00E2
    Device Description: PCI Device
    Class Name: Unknown
    Class GUID: Unknown
    Status: Problem
    Hardware IDs: PCI\VEN_10EC&DEV_5229&SUBSYS_1852103C&REV_01
    PCI\VEN_10EC&DEV_5229&CC_FF0000
    Compatible IDs: PCI\VEN_10EC&DEV_5229&REV_01
    PCI\VEN_10EC&CC_FF0000
    PCI\VEN_10EC
    PCI\CC_FF0000
    PCI\CC_FF00
    • Archimedes
      • Jul 2024
      • 10
      • Turkey
      And the device manager details...
      Can anybody point out which components or the board part seem faulty?
      Status Class FriendlyName
      Unknown USB USB Composite Device
      Unknown Mouse HID-compliant mouse
      OK System System board
      OK Volume Volume
      OK System Motherboard resources
      Error Mouse PS/2 Compatible Mouse
      OK Volume Volume
      OK MEDIA Microsoft Streaming Service Proxy
      OK System Microsoft ACPI-Compliant Embedded Controller
      OK Battery Microsoft ACPI-Compliant Control Method Battery
      OK System ACPI Fan
      OK PrintQueue Root Print Queue
      OK System Volume Manager
      OK System Direct memory access controller
      OK USB USB Root Hub
      Unknown Keyboard HID Keyboard Device
      Error
      OK System PCI-to-PCI Bridge
      OK MEDIA High Definition Audio Device
      Error
      OK Net WAN Miniport (PPPOE)
      OK HIDClass HID-compliant vendor-defined device
      OK System Microsoft Basic Display Driver
      Error
      OK Display Microsoft Basic Display Adapter
      OK USB Intel(R) 7 Series/C216 Chipset Family USB En...
      Unknown HIDClass USB Input Device
      OK System ACPI Thermal Zone
      OK Camera HP TrueVision HD
      OK Monitor Generic Monitor
      OK Net Qualcomm Atheros AR8151 PCI-E Gigabit Ethern...
      OK SoftwareDevice Microsoft RRAS Root Enumerator
      OK System Microsoft Windows Management Interface for ACPI
      OK AudioEndpoint Speakers (High Definition Audio Device)
      OK Net WAN Miniport (PPTP)
      OK System Microsoft Hyper-V Virtualization Infrastruct...
      OK AudioEndpoint Speakers (HP Wireless Audio Adapter)
      OK System High precision event timer
      OK Net WAN Miniport (IKEv2)
      OK System Composite Bus Enumerator
      OK System Microsoft Virtual Drive Enumerator
      OK Battery Microsoft AC Adapter
      OK SCSIAdapter Microsoft Storage Spaces Controller
      OK System Numeric data processor
      OK System LPC Controller
      OK USB USB Root Hub
      OK Net Microsoft Kernel Debug Network Adapter
      OK AudioEndpoint Headset Microphone (HP Wireless Audio Adapter)
      OK System ACPI Lid
      OK USB Generic USB Hub
      OK DiskDrive TOSHIBA MQ01ABD100
      OK System High Definition Audio Controller
      OK USB USB Composite Device
      Unknown HIDClass HID-compliant consumer control device
      OK System Legacy device
      OK USB Intel(R) USB 3.0 eXtensible Host Controller ...
      OK System UMBus Root Bus Enumerator
      OK System Charge Arbitration Driver
      OK HDC Standard SATA AHCI Controller
      OK SoftwareDevice Microsoft Radio Device Enumeration Bus
      OK SoftwareDevice Microsoft Device Association Root Enumerator
      OK Computer ACPI x64-based PC
      OK WPD HP_TOOLS
      OK Net WAN Miniport (Network Monitor)
      OK Net WAN Miniport (IP)
      OK System PCI Express Root Complex
      OK Computer Hewlett-Packard HP ENVY 17-3290NR Notebook PC
      Error PCI Simple Communications Controller
      OK System System timer
      OK System ACPI Power Button
      OK System Microsoft ACPI-Compliant System
      OK
      OK System Microsoft Basic Render Driver
      OK Net WAN Miniport (SSTP)
      OK HIDClass USB Input Device
      OK System ACPI Fixed Feature Button
      OK Volume Volume
      OK System SM Bus Controller
      OK Net Intel(R) Centrino(R) Advanced-N 6235
      Error
      OK Processor Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
      Unknown HIDClass HID-compliant device
      OK System Memory Controller
      OK SoftwareDevice Microsoft GS Wavetable Synth
      OK DiskDrive JetFlash TS4GJFV20 USB Device
      OK System NDIS Virtual Network Adapter Enumerator
      OK AudioEndpoint Microphone (High Definition Audio Device)
      OK System Microsoft System Management BIOS Driver
      Error PCI Device
      OK System Plug and Play Software Device Enumerator
      OK HIDClass HID-compliant consumer control device
      OK PrintQueue Microsoft Print to PDF
      OK USB USB Root Hub (USB 3.0)
      OK System System CMOS/real time clock
      OK Net Microsoft Wi-Fi Direct Virtual Adapter
      OK Net Microsoft Wi-Fi Direct Virtual Adapter #2
      OK System Remote Desktop Device Redirector Bus
      OK Net WAN Miniport (IPv6)
      OK USB USB Mass Storage Device
      OK SoftwareDevice Wi-Fi
      OK MEDIA HP Wireless Audio Adapter
      OK System Programmable interrupt controller
      OK Keyboard Standard PS/2 Keyboard
      OK Net WAN Miniport (L2TP)
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Something is wrong in USB section. check the ports for damage. measure resistance to GND on D+ and D- on usb
        • Archimedes
          • Jul 2024
          • 10
          • Turkey
          Hi mcplslg123, thank you for the answer. Total 4 usb 3.0 in this laptop. None of them has physical damage in their pins. (Display ports and hdmi port don't have any damage either.) 2 usb in the at right side mounted on the motherboard. D+ and D- in both shows 146 kOhms to the ground. 2 usb are on the extra board which is connected to MB by cable. One shows 157 kOhms to the ground by the pins D+ D-. The last one shows 2 MOhms in each. All of the usb ports can read without problem. I have a flash disk with led light, for bios update. All of them are working.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Going by the report in post#3,usb lines has issue. however,the measurement at post#5 are perfect and doesnt indicate a defect.
            Try disconnecting the webcam(as it uses usb lines)+ the usb sub board. Does it makes any difference?
            • Archimedes
              • Jul 2024
              • 10
              • Turkey
              Now I am using minimum possible parts. The motherboard alone without the usb & audio output board, no ssd, no wifi board, no internal screen, no backup battery, nothing on it, but only the cooling fans, the power button, one ram and the power supply connected and also an external hdmi screen. It must display at least few words after the bios boot. In this motherboard just after the AMD HD7850M GPU chip is replaced with a new one I am detecting with my fingers a heat more than normal in the power chips area located in the down part of the both sides. Pls. See attached photos. I couldn't find the boardview details with voltages in the Badcaps for this motherboard (Inventec Louis V1.1 6050A2489901 MB-A02)​ but I have the schematics.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                The marked area is supposed to be warm only when vcore circuit is working as this is low voltage but high current rail-so will generate heat.
                • Archimedes
                  • Jul 2024
                  • 10
                  • Turkey
                  The long black plastic isolation tape under this area is no longer flat as in the photo, it is now swollen with many bubbles, there is definitely too much heat than before.Many components on the board are not numbered it is very difficult to locate them in the schematics. I couldn't find the boardview file (cad) for this motherboard in the internet. If anyone can help me out on where I can find this, I'd be very appreciated.
                  • Archimedes
                    • Jul 2024
                    • 10
                    • Turkey
                    May be ISL 95836 HRTZ is the suspect IC. Some pins are short circuited. I will order one. In the datasheet it is written "ISL95836 provides a complete solution for microprocessor and graphic processor core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers."
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      You can replace the ISLXXX Ic for your own satisafaction but i'm almost sure it wont solve the problem.
                      • Archimedes
                        • Jul 2024
                        • 10
                        • Turkey
                        When measuring the detail voltages on the motherboard with ram, cpu and power button mounted only, little later the fans slowed down, the DJ-jack light was on unusually long, then there is no power at all and there is no DC-jack light either. It seems that in this new issue now there is a short circuit on the motherboard. 19.5V drops to 0.5V when plugged in. Same result with another power adapter. Now this is a new situation to solve before the blank screen issue. Why this happened? Any idea what to follow first?
                        • Archimedes
                          • Jul 2024
                          • 10
                          • Turkey
                          There was a short circuit in a mosfet in the hot area, I replaced it, I also replaced the ISL 95836 IC. Power came back but still the blank screen continues.
                          • madan1
                            DALI SUB E-12F class D, fluctuating power rail
                            by madan1
                            Good day everyone.
                            I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                            The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                            The normal value of the positive and negative power rails is +/- 43V.
                            The positive rail stays...
                            10-15-2025, 10:33 AM
                          • dicky96
                            What 'class' is this Hill Audio DX3000 Amplifier?
                            by dicky96
                            Hi guys, this is general query really
                            So I have a Hill DX3000 3KW audio amplifier here.
                            It has a topology/design like a class A/B but all the banks of output transistors (10 transistors in each 'side' of the channel) are NPN.
                            I was wondering what class this is. It doesn't fit the description of class A.
                            It also doesn't match class A/B or B amplifiers as all the examples I see have a complimentary output stage desigs (NPN/PNP) and clearly is not G, H or D
                            I looked for 'class A push pull' but that didn't tell me anything either
                            05-04-2022, 04:20 AM
                          • Stachujones
                            Dell XPS 13 9370 unknown USB devices in device manager
                            by Stachujones
                            Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
                            Device manager says "unknown device, failed to request device descriptor"
                            Can somebody point me in right direction what to check?
                            I updated bios to the newest version and thunderbolt controller firmware still no luck
                            04-05-2025, 07:35 AM
                          • japlytic
                            Certain "Class 2" HDMI cables can be marginal at 4K 60 Hz
                            by japlytic
                            For some time, a "Class 2" HDMI cable (part number BN39-01583B) supplied with a Samsung 4K 60 Hz display sometimes causes the display to overlay a few horizontal lines of flickering pixels of random colours and sometimes drops out, particularly on content requring HDCP.
                            Since changing the cable to a thicker Class 2 unit, this problem has not occured again - do you know of other marginal "Class 2" HDMI cables supplied with displays?
                            09-06-2023, 08:50 PM
                          • apostsamking
                            dell latitue e5450 AC Adaptor unknown
                            by apostsamking
                            Hello everyone hope all is well. Pls I bought this second hand dell latitue e5450, I realize that the battery cannot be charged because it says ac adopter unknown at bios. I tried several chargers but still I get the same messageAC Adaptor unknown. So I open the laptop up checked the motherboard and i realised that the diod PD5 is fried so I changed, but I still get the same message, changed even the charging ic still the same message AC Adaptor unknown. Can any one help me?
                            02-19-2023, 03:45 AM
