Acer A515-51 - C5V01 LA-E891P Rev 1c
  • coffeebreath
    • Jul 2024
    • 20
    laptop lights wont turn on, wont power on. When plugged in I get 0.4v-0.8v directly from the DC jack plug on the motherboard. 19v from the charger.
    Thank you.
  • mon2
    • Dec 2019
    • 14669
    Measure the voltage to ground on each side of the DCin power jack EMI coil(s) @ PL101 / PL102. Post each measurement. You should see 19v pass through.
    • coffeebreath
      • Jul 2024
      • 20
      PL101: 0.4 -0.8v. All my power adapters keep tripping I think. Light blinks
      PL102 doesn't exist. Doesn't look like it's ever existed
      • mon2
        • Dec 2019
        • 14669
        Remove all power / no battery.
        Meter in resistance mode. Measure the resistance to ground of PL101 - check both sides of this coil. What is the resistance? You can use a metal shield on the board for ground.
        • coffeebreath
          • Jul 2024
          • 20
          PL101 - 13.87
          • mon2
            • Dec 2019
            • 14669
            Need the units of measure from your meter. Is it ohms? kohms? Mohms? Share a pic of the meter face if available when you are testing this resistance.
            • coffeebreath
              • Jul 2024
              • 20
              20k
              • mon2
                • Dec 2019
                • 14669
                So the measurement is 13k88 = 13,880 ohms. No short here.
                Noting this, if your power adapter is not defective and the DCin power connector also not defective, you should have the power adapter voltage available on each side of this EMI filter.
                Confirm the power adapter is ok when it is not mated with the board. Suspect now is that your DCin power connector may be defective.
                • coffeebreath
                  • Jul 2024
                  • 20
                  The DC jack is connected via removable cable. I remove the cable and test it and I get 19v from the motherboard connector. The cable seems fine.
                  I have tested it with multiple chargers now.
                  • coffeebreath
                    • Jul 2024
                    • 20
                    • mon2
                      • Dec 2019
                      • 14669
                      Ok. Locate the 2 x DCin mosfets. Still with no power -> measure the resistance to ground of each of PQ303 (5-6-7-8 = Drain pins). What is the measurement in ohms? This is the main power rail for the logic board.
                      Your issue is when you mate a working power adapter to this logic board so someone in the power path is shorted and causing the adapter voltage to tank.
                      The next step is to check the resistance across both of these mosfets as follows:
                      source (1-2-3) & drain (5-6-7-8)
                      source (1-2-3) & gate (4)
                      gate (4) & drain (5-6-7-8)
                      Post each measurement. If your meter reports 'OL' = over limit, then switch to a higher resistance scale till you have a reading. Checking for a low resistance = defective mosfet.
                      • coffeebreath
                        • Jul 2024
                        • 20
                        source (1-2-3) & drain (5-6-7-8) - 20k - 13.27
                        source (1-2-3) & gate (4) - 20k - 0
                        gate (4) & drain (5-6-7-8) 20k - 13.20
                        I think i measured it right.
                        Theres only one PQ303
                        • mon2
                          • Dec 2019
                          • 14669
                          Which mosfet was measured? Each of the measurements - especially the source - gate is showing a leak.
                          If you are comfortable, flux and remove this mosfet and allow it to cool on your work table. Then measure this part again while it is on your bench. This mosfet appears to be defective.
                          • coffeebreath
                            • Jul 2024
                            • 20
                            The one circled in red, that one was tested.
                            • mon2
                              • Dec 2019
                              • 14669
                              Flux and remove it - very carefully. Do not allow for the hot air to enter the edges as this can cause the multilayer PCB to flake up the multiple layers of the laminate. Keep in tight circle and enough heat without scorching the board.
                              The source & gate measurement is showing a dead short. Be sure the meter is not showing OL for over limit. You can confirm by using a higher meter resistance scale -> still 0 ohms?
                              • coffeebreath
                                • Jul 2024
                                • 20
                                source (1-2-3) & drain (5-6-7-8) 20k - 14.40
                                source (1-2-3) & gate (4) 20k nothing
                                gate (4) & drain (5-6-7-8) 20k nothing
                                I must have done something wrong?
                                • mon2
                                  • Dec 2019
                                  • 14669
                                  This is a low resistance for a working mosfet. This mosfet should be replaced.
                                  While this mosfet is off the board, measure the resistance to ground of the drain pins (5-6-7-8). This is to confirm that the main power rail of the board is not shorted. What is the measurement?
                                  You can either find a replacement mosfet from a donor board or order fresh compatible ones from Digikey / Mouser / Arrow and perhaps Mobile Sentrix (Toronto). Post back if you need help to locate a replacement from the stores.
                                  • coffeebreath
                                    • Jul 2024
                                    • 20
                                    i measured the pads 5-6-7-8 on the motherboard where the mosfet used to be. im getting 0 at 20k
                                    • mon2
                                      • Dec 2019
                                      • 14669
                                      To confirm, you have one of the meter probes on any of the pins on the PCB where this mosfet was (ie. 5 6 7 or 8 is ok) and the other meter probe is to ground. Is this correct? If yes, then you have a hard short on the main power rail.
                                      • coffeebreath
                                        • Jul 2024
                                        • 20
                                        Thats correct
                                        • Ludmilaharhordina
                                          ACER A315-53G C5V01 LA-E892P rev2A the laptop turns on, but the display does not show
                                          by Ludmilaharhordina
                                          good afternoon.
                                          need help.
                                          the laptop turns on, but the display does not show.
                                          the laptop came to me from another workshop. visually broken USB 3.0 and soldered BIOS flash drive.
                                          I unsoldered USB 3.0 and flashed several different BIOSes, but it did not help.
                                          +VCC_CORE 0V
                                          +VCC_GT 0V
                                          +VCC_SA 1.03V
                                          +0.6VS_VTT 0.6V
                                          +1.0VALW_PRIM 1.0V
                                          +1.0V.VCCSTU 1.0V
                                          +VCCIO 1.OV
                                          +1.0VS_VCCSTG 1.0V
                                          +1.2V_VDDQ 1.21V
                                          +1.8VALW_PRIM 1.81V
                                          +1.8VS 1.81V
                                          +3VLP 3.27V
                                          +3VALW...
                                          04-02-2025, 08:51 AM
                                          09-06-2024, 05:27 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
