dell alienware la-l762p
  • kjchatman
    • Dec 2012
    • 213
    • united states
    does anyone have a schematic for the dell alienware LA-L762p board? The board measuring a direct path to ground on coil pl501. i'm not sure which rail it is or if it is even shorted
  • mon2
    • 14721
    What is the exact resistance? Direct path = 0 ohms = yes a short.
    • kjchatman
      • Dec 2012
      • 213
      • united states
      it's 0 ohm. shouldn't i know the voltage before i inject?
      • mon2
        • 14721
        Not needed but keep your injection voltage @ 1 volt or lower. Then check who is heating up. Hope it is only a cap.
        • kjchatman
          • Dec 2012
          • 213
          • united states
          i'm not seeing anything heating up at 1 volt. i found a schematic and +5VALWP is the rail
          • mon2
            • 14721
            Post and link the schematic in the schematics forum. What is the current draw when you inject this voltage? With 0 ohms to ground, someone is shorted and they will heat up. If needed, increase the current setting of your power supply. A setting of 3A-5A should be ample. Be sure it is not the CPU (ie. remove the heatsink to check).
            Perhaps one of the USB loadswitches / Vbus caps are shorted?
            • kjchatman
              • Dec 2012
              • 213
              • united states
              i found the shorted cap after ramping the voltage and ampage and will post the schematic in the schematic forum
              • mon2
                • 14721
                Yours is one of the ideal cases we can all hope for. Bad caps indeed.
