acer 5920g
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    acer 5920g
    hi, i have a acer 5920g with a short.
    when i plug ac, blue light are ok,but when press power on, lights turns on then immediately off.
    if i check the most important pl resistor i see the pl16 related to ddr2 1.8volt is shorted both side.
    in the schematic, page 36, i start from pl17 and 19v are on both side. then i go to pq39 and has 19v to drain and 0 v to gate and 0v to source.
    i then moved to pu9. pin 1-7 0v. pin 8 = 5v and pin 9-10 0 volt.
    pin 11-13 0v, pin 14 = 5 volt, pin 15 5v, pin 16-19 0 volt and pin 20 5 volt.
    pr132 (related to pin 13 of pu9 has 3.4v from one side and 0 to the other.
    dunno if ok but impedance mseasure -30.00 putting multimeter scale to 200k. inverting black and red of multimeter give me no value.
    pc127, pc130, pc131, pr135, pc129 are all shorted.
    where can i focus to spot the bad part of the laptop ?
    tnx for all the help
    for the schematic, just get it here:
    http://www.google.it/url?sa=t&rct=j&...,d.Yms&cad=rja
    PS: using a multimeter, if i press power botton, i get for 1 second voltage to all the most important part ; also on pl16 i have voltage output as 1.8 volt.
    i have also noticed that after keep ac plugged for a while , Sio chip "U10" is getting a bit warm.... can be that the cause of all the problem ? maybe both this ic and also some short on ram circuit?
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: acer 5920g
    after some repair, now i have no short but still no power. all volgate go up then down when pressing power botton. the only voltage that didnt come on is the 1.05 volt from PU6. i have 5v coming with power botton only on pin 2,9,13. on pin 16 i have 10volt. no other voltage. on pin 15 (mainon) i have from 0.1volt to 0.5 volt. but mainok is also present on 1.8v ddr PU9 pin 12 and here too i have 0.5v when pressing power botton, and 1.8v come frome coil for 1 second at least. pin9 Syson from pu9 is 3.3 volt when pressing power botton.
    where can i focus?
    ps: pu6 seems a bit hot, but cant tell if that is normal or not.
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      Re: acer 5920g
      i have ordered pu6, but meanwhile as i said on pin 15 (en/psv) i have from 0 to 0.1 0.3 volt when pressing power botton. pr57 is the same voltage.
      when pressing more time power botton, kb io controller get hot. have to change it too ?
      edit: ordered the winbond from italy so should get it asap
      • atsio
        • Oct 2013
        • 819
        • Greece
        Re: acer 5920g
        What did you do to remove shortage at 1.8VSUS? You must have 19V at VIN of PU6. What is the voltage on PL4? What is the voltage on PR134 and resistance to ground on pin15 of PU6?
        • dellxps15
          • Feb 2014
          • 1588
          • italy
          Re: acer 5920g
          pl4 is 19v both side. vin of pu6 pin 16 has 10volt, but on pr58 i have 19volt one side and 10v to pu6 side.
          on pr134 i have from 0 to 0.5 volt when pressing power on.
          on last post i said pin 15 of pu9 (mainon) but mainon was pin 11, so did a mistake in reporting back.
          i was measuring short with power ac adapter connected.
          tnx very much for reply.
          Edit: pr58 what kind of resistor is this? 0402 1m but on ebay there are many with different value...
          • atsio
            • Oct 2013
            • 819
            • Greece
            Re: acer 5920g
            PR58 is an 1Mohm pull up resistor 0402 type. Unsolder it and measure it.
            If I undestand you correctly you have a short on MAINON.
            • dellxps15
              • Feb 2014
              • 1588
              • italy
              Re: acer 5920g
              if i remove pr58 i wont get Vin on pu6....
              now vin is 19volt in entrance of pr58 and 10v outside it.
              • atsio
                • Oct 2013
                • 819
                • Greece
                Re: acer 5920g
                What I am saying is to unsolder it and check it with multimeter if it's value is OK (1Mohm)
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  Re: acer 5920g
                  without desolder i put multimeter in 2000k scale and it read 983 so it should be ok...
                  • atsio
                    • Oct 2013
                    • 819
                    • Greece
                    Re: acer 5920g
                    Yes it's allright.
                    You didn't answered me. You got a sort on MAINON?
                    • dellxps15
                      • Feb 2014
                      • 1588
                      • italy
                      Re: acer 5920g
                      no short on mainok. i have also no 1.8_mxm volt and on pq38 pin N°3 i have 0 volt (mainD) and 19v on pin 1-2-5-6 so pl19 is 0volt. is it normal ?
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        Re: acer 5920g
                        Check voltage on pins 94, 16 and 73 of U10
                        • dellxps15
                          • Feb 2014
                          • 1588
                          • italy
                          Re: acer 5920g
                          pin 16: 0.03v; 0.12v when pressing power botton
                          pin 73: 0.5v ; 3.5volt when pressing power botton.
                          pin 94: 0.5v ; 3.5 volt when pressing power botton.
                          are you sure pin 73? i see poweron ok on pin 74 on diagram
                          pin 73 is pin in and is susc
                          pin 74 0v with and without pressing power botton however
                          • atsio
                            • Oct 2013
                            • 819
                            • Greece
                            Re: acer 5920g
                            I think you should change U10.
                            • dellxps15
                              • Feb 2014
                              • 1588
                              • italy
                              Re: acer 5920g
                              ok, it's already on it's way to my house. ill get it today or tomorrow
                              tnx very much for help
                              • dj_ricoh
                                • 2073
                                Re: acer 5920g
                                take the CPu out and test without.
                                see if it stays on
                                easy to take out.
                                • dellxps15
                                  • Feb 2014
                                  • 1588
                                  • italy
                                  Re: acer 5920g
                                  without cpu is the same
                                  • tata123
                                    • Nov 2013
                                    • 104
                                    Re: acer 5920g
                                    maybe its a Problem with the black caps near the Intel Northbridge the 330!!
                                    Are there 5 caps with the nr. 330?
                                    • dellxps15
                                      • Feb 2014
                                      • 1588
                                      • italy
                                      Re: acer 5920g
                                      their ok, or at least no shorted.
                                      • tata123
                                        • Nov 2013
                                        • 104
                                        Re: acer 5920g
                                        I know the Problem with Acer Aspire 7530G and its the same problem, Notebook starts and and turn off with Black screen!!
                                        Check the capacitator when you turn it on, and when the notebooks turn off itself!!
                                        Its a Typical Capacitator problem...
                                        • EbrahimSiami
                                          Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                          by EbrahimSiami
                                          I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                          **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                          **What I have tried so far:**
                                          1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                          07-02-2025, 02:31 PM
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
