Asus X401A Dead
  • lord
    • May 2011
    • 319
    • Croatia
    Re: Asus X401A Dead
    Does anybody have a schematic for this board?
    • orientalsniper
      • Apr 2013
      • 461
      Re: Asus X401A Dead
      Hard to find or doesn't exist at all, what's your problem?
      • lord
        • May 2011
        • 319
        • Croatia
        Re: Asus X401A Dead
        No voltage on the CPU coils.
        • atsio
          • Oct 2013
          • 819
          • Greece
          Re: Asus X401A Dead
          Originally posted by 3d0
          I have 2 dell motherboards with the same problem, though I was able to narrow down where the short might be by checking the coils first.
          You might already know this, I will put it in the attachment just in case someone is interested.
          Change your Northbridge.
          • atsio
            • Oct 2013
            • 819
            • Greece
            Re: Asus X401A Dead
            Originally posted by orientalsniper
            Wow, I didn't, thank you a lot. I found a short in a coil against ground, so I desoldered it and one side was shorting while the other was not, so I applied current there, but the only thing heating was the SJTNV BGA chipset. Is that a false positive?
            How many volts - current?
            • lord
              • May 2011
              • 319
              • Croatia
              #26
              Re: Asus X401A Dead
              Did you found the schematics?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                #27
                Re: Asus X401A Dead
                guys y badly need chematic for this laptop
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  #28
                  Re: Asus X401A Dead
                  Any one got a schematic for this mobo ? it starts but no picture. current consumption is fixed at 0.80 A, i'll program the bios first. Since all the coils have neccesary voltages, i think the problem is chipset, if bios is ok.
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3627
                    • slovakia
                    #29
                    Re: Asus X401A Dead
                    have this one. bad bq247 charger ic. just short the 19v on dirst mosfet from source to gate
                    • spidey
                      climbs
                      • Dec 2012
                      • 644
                      • Cyprus
                      #30
                      Re: Asus X401A Dead
                      Programming bios solved the issue. Laptop starts now, installed win 8.1 without any problem.
                      • wickywicky
                        • Nov 2014
                        #31
                        Re: Asus X401A Dead
                        i have this laptop which is also dead.
                        How did you reprogram the BIOS?
                        • orientalsniper
                          • Apr 2013
                          • 461
                          Re: Asus X401A Dead
                          You have to desolder it first and use a LPT or USB Bios programmer, make sure you have a SOP8 converter if it uses DIP8.
                          • the-sky-blue
                            • Dec 2013
                            • 48
                            • salfeet
                            #33
                            Re: Asus X401A Dead
                            hello
                            asus x401a schematics in attachment
                            • canali
                              • Oct 2014
                              • 194
                              • turkey
                              #34
                              Re: Asus X401A Dead
                              hello friends asus x401 vga image.lcd panel did not have any help
