Lenovo Legion 5 Pro - NM-D601 REV1.0 Turns off with battery conected
  • judamex
    Active Member
    • Jan 2021
    • 186
    • Mexico
    I have a Lenovo Legion 5 Pro laptop - NM-D601 REV1.0 when I connect the battery it turns off after 5 minutes of use, if I don't connect the battery the laptop can keep working perfectly, I have already checked the charging voltages and they are fine, no I know if any mosfet is not working well, how can I know?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Check resistor value on SRP/SRN line of charging IC.
    • judamex
      Active Member
      • Jan 2021
      • 186
      • Mexico
      i chek the value
      Resistor value
      PR5410 - SRP = 10 ohm
      PR5416 - SRN = 10ohm
      PR5413 - BATSRC = 10ohm
      PR5410 TO GND (terminal RED to GND, BLACK to pin) pin 1= 16.89 kohm, pin2= 87.2kohm
      PR5416 TO GND (terminal RED to GND, BLACK to pin) Pin 1 = 16.93 kohm, pin 2 = 86.8 kohm
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        SRP/SRN communication is fine. Have you tried with another battery? Which charging IC is used?
        • judamex
          Active Member
          • Jan 2021
          • 186
          • Mexico
          Yes, it seems to have good readings, the laptop is practically new, it came out of the box with that error, it uses the BQ24780S charging IC
          • mon2
            • Dec 2019
            • 14803
            Remove all power. No battery. Investigate the battery mosfet @ PQ5403.
            Meter in resistance mode.
            Measure the resistance (not diode mode) across this mosfet:
            source (1-2-3) & drain (5-6-7-8)
            source (1-2-3) & gate (4)
            gate (4) & drain (5-6-7-8)
            Post each measurement. Checking for a low resistance which means the mosfet is leaking. Be sure to post the resistance and the units of measure (ohms; kohms; Mohms, etc.).
            • judamex
              Active Member
              • Jan 2021
              • 186
              • Mexico
              OK the measurement of PQ5403 on ohms:
              RED terminal to source (1-2-3), BLACK terminal to drain (5-6-7-8) = 19.30 kohms
              RED terminal to source (1-2-3), BLACK terminal to gate (4) = 115.4 kohms
              RED terminal to gate (4), BLACK terminal to drain (5-6-7-8-) 1.1Mohms and up
              • mon2
                • Dec 2019
                • 14803
                For a mosfet, these are considered to be very low resistance measurements:
                Suggest to flux and remove this mosfet. Allow it to cool down on your work table. Then measure the mosfet part again while it is on your work bench. Confirm if the resistance remains this low. If yes, this part is considered to be defective and should be replaced by a known good device.
                This is a very common N-channel mosfet that can be replaced by many others.
                Part # AONS32314.pdf (aosmd.com)
                • judamex
                  Active Member
                  • Jan 2021
                  • 186
                  • Mexico
                  I already measured the mosfet outside the board and if their values changed:
                  RED terminal to source (1-2-3), BLACK terminal to drain (5-6-7-8) = .952 Mohm
                  RED terminal to source (1-2-3), BLACK terminal to gate (4) = 4.93 Mohm
                  on the motherboard it maintains the same measurements
                  RED terminal to source (1-2-3), BLACK terminal to gate (4) = 115.4 kohms​
                  • mon2
                    • Dec 2019
                    • 14803
                    This battery mosfet is fine but still leave it off the board for now.
                    Test the resistance across the other mosfets using the same method:
                    a) test PQ5404 and also PQ5406 (suspecting that only one of these are actually soldered on the board)
                    b) test PQ5407
                    c) test PQ5402 and PQ5401 - if not done already.
                    Someone is causing this event when the battery & power adapter are both connected to the board. No power & no battery during the resistance mode of checking.
                    • judamex
                      Active Member
                      • Jan 2021
                      • 186
                      • Mexico
                      b) test PQ5407
                      I test out of the board
                      PQ5404
                      RED terminal to source (1-2-3), BLACK terminal to drain (5-6-7-8) = 1.052 Mohms
                      RED terminal to source (1-2-3), BLACK terminal to gate (4) = 4.5 Mohms
                      PQ5406
                      RED terminal to source (1-2-3), BLACK terminal to drain (5-6-7-8) = 1.080 Mohms
                      RED terminal to source (1-2-3), BLACK terminal to gate (4) = O.L (It does not give me any measurement, neither in Ohms nor in Diode, it opens the mosfet but it does not give me any measurement)
                      PQ5407
                      RED terminal to source (1-2-3), BLACK terminal to drain (5-6-7-8) = 0.800 Mohm
                      test on the board
                      PQ5402
                      RED terminal to source (1-2-3), BLACK terminal to drain (5-6-7-8) =0.6 Mohm
                      RED terminal to source (1-2-3), BLACK terminal to gate (4) =1.1Mohm
                      PQ5401
                      RED terminal to source (1-2-3), BLACK terminal to drain (5-6-7-8) = 0.6 Mohm
                      RED terminal to source (1-2-3), BLACK terminal to gate (4) = 1.1Mohm
                      • mon2
                        • Dec 2019
                        • 14803
                        Missing for each mosfet are the 3rd measurement:
                        • judamex
                          Active Member
                          • Jan 2021
                          • 186
                          • Mexico
                          Sorry i forget take this measurement
                          Out of the board (change the reading place to an isolated and clean place and the measurements changed)
                          PQ5404
                          RED terminal to source (1-2-3), BLACK terminal to gate (4) = O.L It doesn't give me measurement even in diode mode
                          RED terminal to gate (4), BLACK terminal to drain (5-6-7-8-) = O.L It doesn't give me measurement even in diode mode
                          PQ5406
                          PQ5407
                          test on the board
                          PQ5402
                          RED terminal to gate (4), BLACK terminal to drain (5-6-7-8-) =O.L
                          PQ5401
                          RED terminal to source (1-2-3), BLACK terminal to gate (4) = 1.1Mohm​
                          • judamex
                            Active Member
                            • Jan 2021
                            • 186
                            • Mexico
                            I'm starting to suspect the charging IC
                            • mon2
                              • Dec 2019
                              • 14803
                              If you have the tools and spare part available, worth the effort to test with a known good charging IC.
                              • judamex
                                Active Member
                                • Jan 2021
                                • 186
                                • Mexico
                                I am going to replace the charger IC with one that I have in good condition, I will update if everything works
                                • judamex
                                  Active Member
                                  • Jan 2021
                                  • 186
                                  • Mexico
                                  UPDATE:
                                  I replaced the 24780S charging IC with another one from a healthy device, and it did the same, it turned off after a little use with the battery connected, only with a charger it passed all the benchmarks
                                  • mon2
                                    • Dec 2019
                                    • 14803
                                    So it works only if the battery is disconnected with the power adapter as the only source?
                                    Carefully, measure the voltage to ground of each pin on this charger IC with only the power adapter connected.
                                    Then repeat with both, the power adapter and battery are connected.
                                    Post all of your measurements. We may have to call in a priest but let us try this approach first.
                                    • judamex
                                      Active Member
                                      • Jan 2021
                                      • 186
                                      • Mexico
                                      I performed the following measurements, noticing several details, such as that only with the battery connected the equipment stayed on for no more than 40 seconds.
                                      Take 3 different measurements that appear in the table, only with charger (on), only with battery (off), and with battery+charger (On)
                                      If any of these measures do not help me, I will have to call the priest himself.
                                      • mon2
                                        • Dec 2019
                                        • 14803
                                        Can you confirm the gate voltage of PQ5407 WITH battery & power adapter? It does not look right.
                                        Click image for larger versionName:	gate_voltage.pngViews:	0Size:	50.3 KBID:	3306120
                                        A few other points:
                                        1) remove all power -> measure the resistance of the 4k resistor @ PR5405. Confirm this resistor matches the schematic value of 4k. Concern is that in your measurements, the CMSRC voltage to ground is lower than the power adapter voltage.
                                        2) double check the BATTERY only measurement for pins 1 & 2 on the charger IC.
                                        3) repeat the measurements WITH BATTERY & power adapter for pins 1 & 2 on the charger IC. Pin # 2 (ACP) should be a higher voltage than pin # 1 (ACN). In either case, the voltage measurements should be very close to each other. Note the voltage drop across ACP and ACN junction when using only the power adapter. Higher voltage difference when the battery is used or when both battery & power adapter is used.
                                        With no power to the board and no battery, confirm the resistance from pin # 2 (ACP) directly on the charger IC to the current sense resistor @ PR5401. Then repeat the same test with pin # 1 to the same current sense resistor. Both checks should be ~0 ohms. Touch your meter probes together and this is the same resistance measurement you should have for this current sense resistor path.
                                        Also, I think that for the BATTERY only, the pin # 19 measurement was missed in the above table. It should be the same voltage as pin # 20.
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          11-04-2025, 05:14 AM
                                          Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 05:00 AM
                                          Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          Lenovo Legion Legion 5 15ITH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Legion 5 15ITH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 15ITH6H boardview and Legion 5 15ITH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                        • twonk9098
                                          Lenovo Legion 5 high fan spin turns off after 34 seconds
                                          by twonk9098
                                          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                          I have tried a few new bios but exactly...
                                          07-14-2024, 11:19 AM
