Acer A315-41G similar to AN515-42, AC OK Battery OK but not charging
This topic has been answered.
  • titomno2
    • Aug 2020
    • 103
    • France
    Hi guys,
    I currently trying to figure out why the laptop of my friend did not charge.
    It is a Acer AN515-42 (Ryzen 5 2500U), I manage to make it works on AC and battery but no charging.
    At first it was not working on Battery, I discovered that PQ201 was knocked off and replace it => work on battery precharged on another computer.
    I also checked the small resistors between PQ312 and PQ201 and even if they are ugly values are OK.
    My issue, when I plug the charger computer off, it drains 0.25A during few seconds with amber light on (charging) then amber light blinks and 0.00A drain.
    I measured the mosfet PQ305, PQ306 and PQ312 and did not find any short (from my perspective).
    On infrared camera during the 0.25A consumption I can see PQ305 getting hot, PU301 and PD301 also.
    Voltage of the battery was 15.79V and when it "charges" voltage between PQ305 and PQ306 is 15.90V (once charging stops the battery voltage remain at 15.79V).
    I checked the 100 Resistor and read 10Ohms => OK
    I checked the 0 Resistor and read 0.1 Ohms => OK
    I' am a bit confused to determine if the intersil chip 88739A is good (seems to).
    What can I check, I already tried to replace the PU301 but the one from the doner board was out of order (to reaction at all, so I swapped back with the old one (and computer works but did not charge).
    The battery works (drain and charge on another acer computer and yes it is the same part number AC14B8K.
    Any help or advice will be highly appreciated.
    Thanks guys for any help you may provide to me.​
  • Answer selected by titomno2 at 08-01-2024, 11:13 AM.
    titomno2
    • Aug 2020
    • 103
    • France
    So this is the last update and for a good reason. 😉
    With the help of every one and especially mon2, I was able to solve issues one after the other.
    So I made more deep research* and discovered even if the A315-41G motherboard is almost the same as the AN515-42, the battery used is not (it is a 2 cells AP16M5J).
    Even if the BIOS is exactly the same version and the same for at least AN515-42 and A315-41G !!!
    I have been fooled by my friend that have made the mistake to buy a wrong battery that works for AN515-42 AC14B8K 4 cells (but with exactly the same shape and same wiring !).
    So I have buy a the correct one 2 cells on ebay and plugged in => works (great without adapter)
    Once in windows level of battery indicated is 45% => Low but OK as the computer is powered properly.
    Plugged in the ac adpater => heard a bip that I did not heard previously and amber lighted up right away and not blinking.
    Check on the power supply => current draw is over 1.5 amps over the nominal consumption and thermal camera confirm the mosfets heating up (and not to much).
    Now the level is 65% and increasing.
    So for me this subject is closed and learn a lesson, never trust your friend (especially when he is not knowing what he his doing).
    Have a nice evening and take care 😀
    *deeper search also started as the keyboard mapping on A315-41G and AN515-42 is not the same also !
    • mon2
      • Dec 2019
      • 14694
      Remove all power. Meter in lowest resistance mode. Measure the resistance between pins 14 & 15 on the charger IC PU301. You are checking the resistance of the current sense resistor. Measure this directly at the charger IC. Post your measurement.
      Next, short your meter probes. Post the resistance measurement with the probes shorted.
      • titomno2
        • Aug 2020
        • 103
        • France
        Hi Mon2
        I cannot choose the range for the resistance on my meter (it cycle itself from MOhms to Ohms).
        I measured directly on the IC but is quite hard as the pitch between pads is very tiny.
        I measured between PC319, pins are very small to have a proper measurement, but according to the boardview it should be the same.
        Between pins 14 & 15 I read 2.2Ohms to 2.3Ohms.
        When I short the probes the readings are between 0.0Ohms and 0.1Ohms.
        I understand it is the CSON for CHARGER, but don't know if the value is correct or not (seems low for me).
        I put an extract of boardview to be certain I did it properly.
        The board wzas out, I removed Battery, AC and the RTC Battery also. Waited few minutes to be sure to have a complete discharge.
        As english is not my mothertong, feel free to ask for clarification (my wording is sometimes messy, sorry for that).
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Resistance between CSON/CSOP is correct. Check resistance between ACN/ACP also in same way.
          • titomno2
            • Aug 2020
            • 103
            • France
            Hi mcplskf123, could you help me to identify the pins on the chip, in the board view I'm not findinf ACN or ACP (I have ACIN_CHG, ACLIM_CHG).
            • mon2
              • Dec 2019
              • 14694
              These 2 pins are also known as CSIP and CSIN. Standing for 'current sense input positive' and 'current sense input negative'. The positive pin is where the current enters the circuit and negative is where it leaves in the power path. Between the 2 pins will be a very low resistance resistor known as the current sense resistor. The charger IC is monitoring the voltage that enters and the voltage that leaves and expects a very very small voltage drop. Based on this voltage drop, the charger IC can gauge the amount of load or the current draw imposed by the power rail. If the voltage drop is too high, this equates to too high of a current use so power down the rail's mosfets.
              So with no power, measure the resistance between pins 32 & 31 but do so directly at the charger IC pins.
              • titomno2
                • Aug 2020
                • 103
                • France
                Thank you mon2,
                I have also a reading of 2.1 to 2.2Ohms between pin 31 & 32.
                • mon2
                  • Dec 2019
                  • 14694
                  This resistance path check is OK and matches the schematics.
                  Carefully measure the voltage to ground of each pin on the dual diode @ PD301. When both, the adapter and battery are connected, the higher voltage of these 2 power sources should appear on pin # 1 to power the charger IC.
                  Confirm the details of this dual diode which may be leaky.
                  To check in another way, remove all power -> meter in DIODE mode. Red meter probe on pin # 3 and black meter probe to pin # 1. The diode should conduct. Reverse the direction of the probes and the diode should block (OL).
                  Do the same with pins # 2 & # 1 - same results should follow if the diode is working.
                  • titomno2
                    • Aug 2020
                    • 103
                    • France
                    With adpater (19.3V on stabilized power supply) and battery (15.22V).
                    Battery plug in => 75mV on #1.
                    Plugin the AC adpater => 19.03V for few seconds then drop to 18.83V (during 0.25A consumption) and goes back to 19.03V when returning to 0.00A.
                    Removing the adapter => 15.22V (voltage of the battery).
                    To complete the figure I have made the measurment in diode mode (everything unplugged):
                    #3 to #1 0.333V
                    #1 to #3 OL
                    #2 to #1 0.333V
                    #1 to #2 OL
                    I assume the dual diode is fine.
                    I replaced the PQ201 from a doner board as I wasn't able to start on a charged battery (don't think it could have a direct influence on charging behavior).
                    Hope it is helping you to guide me to find the culprit.
                    Thanks again, explanation are very clear for me.
                    • mon2
                      • Dec 2019
                      • 14694
                      Confused about the above.
                      If battery is @ 15v22 and the adapter is @ 19v3, then pin # 1 should be ~19 volts.
                      If adapter is removed, pin # 1 should be ~15 volts.
                      Confirm the above details again. Pin # 1 is the output of the dual diodes and the highest voltage should be output to power the charger IC.​
                      • titomno2
                        • Aug 2020
                        • 103
                        • France
                        Sorry,
                        When on battery alone it is 15.22V (value could be lower over time as the battery is discharging).
                        When I put the adapter the voltage go up to 19.03V and reduced to 18.85V during the few seconds (only during the few seconds I see a current consomption of 0.25A and mosfet PQ305 getting slightly hot in the same time of the ic chip).
                        Pïn one is the output of the dual mosfet (see picture).
                        What I find confusing and may be it did not help you is when I plug only the battery only (alone) I have nothing (no voltage neither on pin 1 nor on pin 2 (as I assume only the pin 3 as the adapter voltage).
                        But once I have plugged in the adapter and remove I have this time the 15.22V of the battery continuously.
                        May be I am wrong but my first idea is that I should have the 15.22V right when I plug the battery ?
                        Feel free to ask any clarification.
                        • mon2
                          • Dec 2019
                          • 14694
                          This behaviour is not correct for this dual diode. The battery voltage should travel through the diode when it is the only power source. Replace this dual diode with another. It is a common part used by many vendors.
                          To confirm, the battery voltage MUST be present on pin # 2 and the same voltage should be present @ pin # 1. Something wrong with this diode (most likely) or the traces from the battery to the pin # 2 of this part. You can perform a diode (continuity) check between pin # 2 and the contacts of the battery connector (do not attach the battery in such a test).
                          • titomno2
                            • Aug 2020
                            • 103
                            • France
                            Just tested the continuity between the pin #2 and the positive battery terminal (0.1Ohms, so It is OK).
                            Changed the dual diode with one from other board and the behavior is exactly the same.
                            Something I was thinking of is that resistor of the battery temp reading seems damaged not in good shape, should I change them. Could it be an issue of reading the battery temperature sensor that stopped the charging ?
                            As the ic can not read the temperature sensor it shut down everything to avoid damage ?
                            • mon2
                              • Dec 2019
                              • 14694
                              Something I was thinking of is that resistor of the battery temp reading seems damaged not in good shape, should I change them. Could it be an issue of reading the battery temperature sensor that stopped the charging ?​
                              YES!! That should be the # 1 step. As Louis shows in his countless videos, always inspect the board for puke / cat urine, etc. that may have caused parts to be defective.
                              • titomno2
                                • Aug 2020
                                • 103
                                • France
                                So I changed the 3 resistors PR202 (100Ohms) PR203 (1kOhms) and PR204 (200kOhms) (I'm confuse the pdf indicate 200kOhms on the PR203, but I read 1kOhm on the resistor removed and the same value on the resistor from the doner board).
                                Whatever the behavior of the board is still the same.
                                I have notice #2 in PR203 have the 3.3V only fews seconds and drop at 156mV when charge stop and orange light start to blink.
                                PR201 is 100Ohms, PR202 is 100Ohms.
                                Did not find any component on which the Louis Rossman cat may have piss on :-D.
                                I think the issue is not far but I running out of new Idea.
                                Is to bad because the computer start on battery, on ac, on battery and ac but doesn't charge which is a bit disappointing.
                                • mon2
                                  • Dec 2019
                                  • 14694
                                  What is the voltage to ground of the gate pin # 2 of PQ201 ?
                                  • titomno2
                                    • Aug 2020
                                    • 103
                                    • France
                                    With battery plugged in and ac adapter, I measured 2.947V steady on pin #2 of PQ201.
                                    The value not vary much whatever the consumption is (0.25A or not).
                                    • titomno2
                                      • Aug 2020
                                      • 103
                                      • France
                                      I have order the ISL chip (just in case) and also the mosfet for PQ201 (as I am not very confident with the doner board health).
                                      PQ201 are cheap, but on two other motherboard a defective one was preventing the board from booting up (seems a quite fragile part).
                                      Until parts receiption I will wait for any comment from you guys if I have anything to check again to fix this charging issue.
                                      On windows the batttery reading are OK and the plugin logo show up when I plug the charger but no charging rate visible (which is ok as we can see on the different measurement).
                                      Thank you.
                                      • mon2
                                        • Dec 2019
                                        • 14694
                                        Measure the voltage to ground of the following points of interest with both, the power adapter & battery connected:
                                        ACIN_CHG ; pin 1 on PU301
                                        AC_OK ; pin 2 on PU301
                                        ASGATE ; pin 30 on PU301
                                        If the power adapter is above a certain threshold voltage on pin # 1 (ACIN_CHG), then AC_OK will be floating and should be a logic '1' state and ASGATE will be boosted to drive the 2*DCin mosfets.
                                        • titomno2
                                          • Aug 2020
                                          • 103
                                          • France
                                          ACIN_CHG ; pin 1 on PU301 => I read 2.206VDC (quite stable)
                                          AC_OK ; pin 2 on PU301 => I read 3.26 to 3.27VDC (fluctuating)
                                          ​ => I read 24.44VDC (Boosted OK)
                                          Fun fact (or not) I have made the measurement a first time with battery RTC plugged in, Battery plugged in and power adapter (the amber light is blinkin right away).
                                          I the RTC is not plugged in I have the 0.25A consumption for few seconds and amber light steady before going donw to 0.00A and blinking amber light.
                                          But it doesn't change the measurements (except on mV scale, which I think we could ignore)
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • DenK
                                            Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                                            by DenK
                                            Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                                            1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                                            12-06-2024, 01:29 AM
                                          • survivalbloke
                                            Acer Predator Helios 300 - will not power up if battery is CONNECTED
                                            by survivalbloke
                                            This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                                            06-25-2025, 12:20 PM
                                          • ahmarzo
                                            Acer TMX314-51 laptop battery problem
                                            by ahmarzo
                                            I have acer laptop tmx314-51 with part no 6050A3020501.
                                            The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                                            But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                                            I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                                            The schematic is not available...
                                            04-11-2025, 09:14 AM
                                          • mkdj
                                            ASUS X571 no power : battery issue?
                                            by mkdj
                                            Mark and model: ASUS X571
                                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                            Tests already made:
                                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                            - I have removed...
                                            07-14-2025, 09:16 AM
